SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 12-16-2008, 11:37 PM
jimtash's Avatar
jimtash jimtash is offline
Registered
jimtash is spectacular!jimtash is spectacular!
Default What are the symptoms of a timing belt off a tooth or two?
I'm asking because the motor in my '89 has this harshness and viration to it. Everything checks out fine as far as cylinder firing and such. No codes. Replaced the injectors with refurbished one's, plugs are good as are the wires.
I installed it as a replacement motor several years back and it's nowhere near the level of the original motor in terms of smoothness. At idle, the motor literally shakes back and forth and I can feel a vibration coming from it. I have been completely baffled as to why it does it but now I'm thinking that the timing belt is off a tooth or two. What symptoms would be present if say the timing belt was installed incorrectly.
Thanks.
  #2
Old 12-17-2008, 01:17 AM
SHO_DOODmorrris's Avatar
SHO_DOODmorrris SHO_DOODmorrris is offline
Owner & Fanatic
SHO_DOODmorrris is a jewel in the roughSHO_DOODmorrris is a jewel in the roughSHO_DOODmorrris is a jewel in the roughSHO_DOODmorrris is a jewel in the rough
Default
that could be it but check your crank pully. i owuld think a bent/separating pully could cause that
__________________
-Mitch
1989 Red on Black AKA The Red Bomb
Mods: Holset HX35W Turbo, Greddy type RS BOV, Tial 38mm wastegate, Clutchmasters stage 3, TwEECer R/T, Intrax on Tokico's, 80mm MAF, Black leather, Plus Hood, Rod Shifter, 190 LPH FP
Mods to come: Paint.
Member #2 of the I'm Younger Than My SHO Club (IYTMSHOC)
Quote:
Other than shit, it's what Sam is full of.
Youngest boosted SHO owner/builder
  #3
Old 12-17-2008, 09:36 AM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
Agreed. Could be timing belt. Does it run hot?
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
  #4
Old 12-17-2008, 09:45 AM
itwonder itwonder is offline
Registered
itwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid one
Default
Set to TDC using the white notch in the edge of the crank pulley (may need to clean to find it, and don't use the orange notch by mistake) matched to the zero mark on the lower timing cover. Remove the upper timing cover and see if the dots on the front of the pulleys match the reference marks on the shield.
__________________
Bob
1992 Black/Black
Original Owner - 245K
Squashed by falling tree, fate TBD
  #5
Old 12-17-2008, 10:06 AM
jimtash's Avatar
Registered
Default
Quote:
It doesn't run hot but I did have to replace the radiator twice in it since installing this engine due to leaks.
I just remember what the original engine was like. Quiet, smooth and could feel the torque. This engine is noisy, vibrates, is harsh and doesn't have the seat of the pants torque in it like the other. That's why I think the cam or crank timing is off because if it was mechanical, the engine would have self destructed a long time ago.
Wierd thing is that I was using a larger throttle body and because the butterfly would constantly stick in it, I put the original back on. This in itself cut down on the vibrations about 50%. The rotational vibration was so bad that it would cause the steering wheel to shake.
The only way I can describe it is the engine behaves as if it has a high performance cam in it.
  #6
Old 12-17-2008, 10:41 AM
93rev2sev's Avatar
Registered
Default
have you double checked your firing order? I would.
  #7
Old 12-17-2008, 10:50 AM
jimtash's Avatar
Registered
Default
I've done it all. New plugs, new wires, checked the codes and nothing changed. Everything is where it's supposed to be as far as I can tell. This problem has plagued the engine from the get go.
  #8
Old 12-17-2008, 11:10 AM
hawkeye18's Avatar
hawkeye18 hawkeye18 is offline
Sorta cares
hawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond repute
Default
no, he means the plug wire order. The Chilton manual (and the Haynes too IIRC) have the order of the plugs wrong, and will cause you to reverse 5 and 4, causing all sorts of driveability issues.
__________________
Jason H ('95 ATX, '13 Focus Titanium)
My radar sees farther than your SHO can drive on a tank.
  #9
Old 12-17-2008, 11:15 AM
NCTaurusSHO NCTaurusSHO is offline
Unregistered
NCTaurusSHO is a jewel in the roughNCTaurusSHO is a jewel in the roughNCTaurusSHO is a jewel in the roughNCTaurusSHO is a jewel in the rough
Default
may be who ever installed the motor mixed up the injecor harness plugs with the one ones that go for the interior harnes plugs and the pcm harnes plugs located under the thermostat housing they can be mis matched
  #10
Old 12-17-2008, 11:20 AM
jimtash's Avatar
Registered
Default
Quote:
Plug order is correct.
Everything is as it should be that's visible and easy to access.
I replaced the fuel injectors myself and the harness is correct. The car runs and drives fine. No missing at all. The engine just has this nasty vibration in it and is harsh.
  #11
Old 12-17-2008, 01:20 PM
AREA 91's Avatar
AREA 91 AREA 91 is offline
Registered
AREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud of
Default
Having the T belt off a tooth or two can cause a rough running engine. Does the engine feel like it has power up top, but is lacking down low? Or vice versa.
Double check your timing. It's fairly easy.
__________________
Quickest V6 Yamaha on the Forum!!!
WELCOME TO AREA 91
91+ Green Not Stock!
12.74 ET & 114.25MPH
257 WHP All Motor 336 WHP on N20
91 Mocha Frost 210WHP 210WTQ
I am the PA SHO SHOP
  #12
Old 12-17-2008, 09:37 PM
jimtash's Avatar
Registered
Default
Power up top. When the secondaries kick in, they are un-noticable and yes, they are working.
The old engine was totally the opposite and when the secondaries kicked in, I felt it.
  #13
Old 08-07-2011, 07:25 PM
kevinspann's Avatar
kevinspann kevinspann is offline
Need Motivation
kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!
Default
Was your timing off? My car seems the same way.
__________________
15s in 2015
  #14
Old 08-07-2011, 10:27 PM
rubydist rubydist is offline
Registered
rubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud of
Default
one of the cars I bought had the rear head timing off 2 teeth (late, iirc) and it ran hot, would not pass emissions due to high nox (due to running hot) and was significantly down on power.
__________________
96 Pearl White Mark VIII 4.6 dohc
90 Red RX-7 convertible project.....
96 White w/ Grey F250 4x4 OffRoad extended cab
98 Green Mountaineer awd 5.0 - for sale!
03 Tan Subaru Outback 3.0
former SHOs include 94 re atx, 94 wh atx x2, 93 gr atx, 94 bl mtx, 97 bk, 98 bk, 95 gr atx->mtx, 93 bl mtx, 93 bl atx, 95 bl atx, 95 gr atx, 92 wh mtx
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
