SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 08-16-2008, 12:32 PM
ThatShoGuy's Avatar
ThatShoGuy ThatShoGuy is offline
Registered
ThatShoGuy is on the right road
Default how can i test EVAP CANISTER PURGE VALVE
i really think this is causing my evap large leak code.. i got the code for this yesterday and i cleared it and then i got the code again today after tryin to figure out my issue..
code for that is p0443 was getting teh p0455 havent gotten it again yet.. im wondering if the 443 is causing the 455 i got 3 used valves i picked up at the pick n pull today i tested there ohms all with in the 30-38 ohms or the 30-90
passed this with all 3 newer ones i havnt checked the one on the car yet since its still hot after driving it..
CANISTER PURGE VALVE RESISTANCE
l Measure EVAP canister purge valve resistance.
l Is resistance between 30 and 90 ohms or 30 and 38 ohms (Continental, F-Series/E-Series)?
Yes
For Escort/Tracer, Mustang, Thunderbird/Cougar, Ranger, Aerostar:
GO to «HW3».
All Others:
GO to «HW4».
No
REPLACE damaged EVAP canister purge valve. RESTORE vehicle. GO to «HW42».
i do have the sevice manual but i have trouble finding things on it
__________________
This is my 97 sho **RUNING FOR THE TIME **
97 sliver sho bought for 4,500.
cam failed and been fixed and welded..
now she has a NOS short block,heads with 4k on them running used head gaskets and head bolts! as off 7-15-08 had 250miles on it 2-25-09 9kmiles and on 3-27-2011 has nearly 30k with a dead trans...
  #2
Old 08-16-2008, 01:55 PM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
Default
If the resistance is OK then the next thing is the valve getting juice when it should?
It appears there should be 12V on it all the time and the valve coil would be grounded by the PCM. You should check to see that there is 12V at the plug. Then you could ground the gray/yellow wire on the plug and this should open the valve.
Cell 26-004 and 26-005 in the electrical manual show the wire diagram and power source for it.
You should also check for continuity on the gray/yellow ground wire back to the PCM
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
  #3
Old 08-16-2008, 02:25 PM
ThatShoGuy's Avatar
Registered
Default
ill look into this more if i get my code back i thru a used part on there and cleared the code gonna see if that it comes back..
i didnt even know i had thos diagrams i was looking thru them since i notices and they are hard to figure out well kind of guess its gonna take more pratice.
thanks
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
