SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 07-13-2008, 03:14 PM
Twisted99 Twisted99 is offline
Registered
Twisted99 is on the right road
Default Fluid Leaking from inner tie rod boot?
I've tried to search but am having problems with the function. Anyway, the drivers side inner tie rod boot is leaking. I have had a bit of vibration from the steering. Having had a merkurxr4ti and changing the inner tie rods on it, does it make sense to change these on my 98 SHO. Is the fluid a sympton of the rod wear and or seals at the ball joint. It's leaking rather bad. I am assuming it has seals,are there any or am I looking at having to change the rack?
Thanks for your help.
Jeff
__________________
1995 Silver MTX
1998 Toreador Red
2001 Lightning
  #2
Old 07-13-2008, 09:10 PM
ruWelded ruWelded is offline
Registered
ruWelded is on the right road
Default Fluid from tie rod
If you have fluid leaking from the inner tie rod, you have a leaky seal in the rack. The SHO uses transmission fluid for the power steering system. If it has not been changed in a while it might be a gray color. Any way if the rack seal is bad you can find a rebuilt replacement at Rock Auto for $256 to $490 or e-bay.
__________________
Brad Fairchild
Lafayette, IN
2010 - Red Candy
96 ES - Resurrected - Welded - Catless - running again 08-30-05 - #538 & 542
97 SF - Resurrected - Welded - running again 10-28-07 -#836- Sold 10-04-2011
97 ES - Trashed by lack of oil changes -a carbon sludge mess - replaced engine- Welded - Wrecked 07-18-2011
97 ES e-bay steal just needed alternator - Sold
99 SF - Saved from the tick of death - Welded - running again 08-26-07 - #837 & #839
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
