SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 05-18-2008, 12:20 PM
GreenPlus's Avatar
GreenPlus GreenPlus is offline
Registered
GreenPlus is unknown at this point
Default Intake manifold gaskets
I have a 91 Green Sho Plus and it runs hot and burns coolant. My first impression is that it has a blown HG, but there is no coolant in the oil or oil in the coolant. Is it possible that the car would smoke due to bad intake manifold gaskets. The previous owner had it off and I havent really had a chance to tinker with the car yet.
  #2
Old 05-18-2008, 01:16 PM
SASHO91's Avatar
SASHO91 SASHO91 is offline
Zoom Zoom
SASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid one
Default
You can still have a blown headgasket that doesn't leak into the oil/water passages.
__________________
Josh
99' Miata- 270whp & 2250lbs... "Fun" covers it.
08' F-150 Crew Cab 5.4 DD
The following user says thank you to SASHO91 for this post:
GreenPlus (05-18-2008)
  #3
Old 05-18-2008, 01:18 PM
LOUDSHO92's Avatar
LOUDSHO92 LOUDSHO92 is offline
SHOForum Sponsor
LOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud of
Cool
The intake manifold gaskets rarely go bad.
Have you changed the thermostat?
__________________
92 White SHO
-Performance: Turbo 297hp 279ftlb
-Drivetrain: CM Clutch,SHONut Mounts,QUAIFE
-Suspension: SS Coilovers, 24/26mm,Poly,Gen3,H-Brace, Subframe
-Brakes: Cobra front, 11.6 rear
-Looks: Sound System,Speedhut,Pilot Fogs,Clear Corners,Gen2 Console, CF Cowl Hood & Trunk
SHO Source
  #4
Old 05-18-2008, 02:39 PM
GreenPlus's Avatar
Registered
Default HG
Ya, I replaced the thermostat. I guess I'll have to pull the heads then. Any tips on removing the exhaust bolts?
  #5
Old 05-18-2008, 02:44 PM
K-Dawg's Avatar
K-Dawg K-Dawg is offline
Registered
K-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond repute
Default
SHOs very rarely blow headgaskets. Get a pressure tester on the cooling system and find out where your leak is. You probably have a leaking hose or radiator.
__________________
Kelvin
Former SHO Driver
  #6
Old 05-18-2008, 03:27 PM
yzstud's Avatar
yzstud yzstud is offline
< my kawi
yzstud is a jewel in the roughyzstud is a jewel in the roughyzstud is a jewel in the roughyzstud is a jewel in the rough
Default
Quote:
as stated before, you can have blown headgaskets that won't leak into the cylinders, and the IM gaskets are reusable and lifetime correct?
check for coolant leaks on cold days, they are probably leaking past them crappy ass clamps or at the end tanks on the radiator
__________________
  #7
Old 05-18-2008, 03:28 PM
RAYJAY's Avatar
RAYJAY RAYJAY is offline
WHO ME ?
RAYJAY is a jewel in the roughRAYJAY is a jewel in the roughRAYJAY is a jewel in the roughRAYJAY is a jewel in the rough
Default
smell the over flow jug if it smells like hydro carbons the head gasket / head is bad,
and yes if you over heat the motors the head gaskets will go bad
and i have seen a lot of the 3.2 with rear blown head gaskets, I have one of them
here is a picture of the head washed away in the seal area
Jeff
__________________
1994 3.2 ATX DEEP JEWEL
1994 BLUE/GREY atx KONI /EIBACH TPR BUSHINGS H BRACE ATX
  #8
Old 05-18-2008, 03:33 PM
yzstud's Avatar
< my kawi
Default
its just like any other cars, overheat it, run it too long and run the risk of a blown head gasket
  #9
Old 05-18-2008, 06:11 PM
Devin's Avatar
Devin Devin is offline
3.0ld
Devin is awesome!Devin is awesome!Devin is awesome!Devin is awesome!Devin is awesome!
Default
The intake manifold gaskets can have the paint chip off and at that point most people replace them or at least repaint them.
  #10
Old 05-18-2008, 08:59 PM
GreenPlus's Avatar
Registered
Default
Thanks guys for all the advice. When I say it burn coolant I mean there is visible white smoke coming out the exhaust. I was just hopng that there was something else that could cause it.
  #11
Old 05-18-2008, 09:13 PM
SHO_DOODmorrris's Avatar
SHO_DOODmorrris SHO_DOODmorrris is offline
Owner & Fanatic
SHO_DOODmorrris is a jewel in the roughSHO_DOODmorrris is a jewel in the roughSHO_DOODmorrris is a jewel in the roughSHO_DOODmorrris is a jewel in the rough
Default
intake gaskets are reusable! SHIT lol. just waseted some money...
-M
__________________
-Mitch
1989 Red on Black AKA The Red Bomb
Mods: Holset HX35W Turbo, Greddy type RS BOV, Tial 38mm wastegate, Clutchmasters stage 3, TwEECer R/T, Intrax on Tokico's, 80mm MAF, Black leather, Plus Hood, Rod Shifter, 190 LPH FP
Mods to come: Paint.
Member #2 of the I'm Younger Than My SHO Club (IYTMSHOC)
Quote:
Other than shit, it's what Sam is full of.
Youngest boosted SHO owner/builder
  #12
Old 05-19-2008, 08:23 AM
Phoenix's Avatar
Phoenix Phoenix is offline
SHOHOLIC
Phoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond reputePhoenix has a reputation beyond repute
Default
Im kinda stunned to see that no one specified that weather your intake gasket is blown or not , it wont affect any coolant issues simply because the SHO has no coolant passages in the intake....
__________________
2002 Taurus with 3.2 MTX Cammed and modded @ 241 WHP N/A.
UPLOAD ALL YOUR SHO PICTURES: Shospeed.com
Currently working on: 92 SHOGUN
  #13
Old 05-19-2008, 11:04 AM
shoclown shoclown is offline
shoclown
shoclown will become famous soon enough
Default
use a block tester.. napa etc sells them for around 14.00. it is a plastice turkey baster looking thing that when fillled with the chemical it comes with if you have any combustion gasses in the rad it turns the chemical a different color.
so you fill up the tool run car to a normal temp and put tool in the rad cap hole and let it run for a couple min..works great very easy to use and is very reliable(as long as you dont suck antifreeze in it) make sure coolant leval is 1/2 low then test.
For the money it is a GREAT TOOL THE CHEMICAL WILL LAST QUITE A WHILE IF KEPT ACORDING TO DIRECTIONS ETC.
  #14
Old 05-19-2008, 12:02 PM
Devin's Avatar
3.0ld
Default
Phoenix: we mentioned them but I think most posters indirectly ignored them for that exact reason.
  #15
Old 05-19-2008, 12:39 PM
Phoenix's Avatar
SHOHOLIC
Default
Quote:
Roger
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
