SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 07-14-2007, 07:51 AM
Kens1992mtxSHO's Avatar
Kens1992mtxSHO Kens1992mtxSHO is offline
Kens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud ofKens1992mtxSHO has much to be proud of
Default Engine runs cold, then hot, then cold again
My engine has suddenly started running much colder than normal. Under highway speeds the temp gauge sits at the "L" in NORMAL. When I get off the highway the temp gauge goes up to the "O" or the "R". One instance it went up to "N". My SHO didn't do this prior to my Y-Pipe install on Tuesday.
I'm guessing it's the thermostat going bad. What else will cause such rapid temp fluctuations?
Thanks guys,
Ken
EDIT: I have checked coolant levels and everything is OK. No oil in reservoir tank either.
  #2
Old 07-14-2007, 09:27 AM
excidere's Avatar
excidere excidere is offline
lost
excidere will become famous soon enoughexcidere will become famous soon enough
Default
You might also make sure that the fan is kicking on like it should, which that could be relay/motor problem, or a thermostat problem. My old '95 did that and the reason it was so low on the highway was that the air was pushing through the radiator anyways, and then at a stop or low speed there was not enough air getting through to cool efficiently.
In my particular case the fan motor had burnt up, so I replaced it and all was good!
__________________
Twitter
'07 Chevy HHR LT 75k - Family Friendly
'90 Black on Black MTX 121k - http://www.shoforum.com/showthread.php?t=73819
'96 Camry XLE v6 180k - Daily Driver
  #3
Old 07-14-2007, 09:28 AM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
Default
The thermostat has the ultimate responsibility for controlling the temperature of the engine coolant. If it is running too cold when moving, the thermostat is likely not moderating the coolant flow properly. However, if the engine is running hot only when not moving, the radiator fan operation should be checked.
__________________
Helping to keep the SHO on the road,
Scott
1991, 430K miles, and rolling...
In-car Track Video: Laps at TWS
  #4
Old 07-17-2007, 10:05 AM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
Co-signed thermostat problem.
It's probably sticking in both open and closed positions...pressure gets high enough from heat and it pops open...all the way...and sticks there. Engine cools down and thermo stays open...until...it gets cool enough to pop it closed again where the cycle will repeat.
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
