SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 07-12-2007, 05:57 PM
itwonder itwonder is offline
Registered
itwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid one
Default Ultra Gray or Ultra Black RTV for Oil Pan?
Is there a consensus as to which one works better for the oil pan seal, Ultra Black RTV or the Ultra Gray "rigid high torque" RTV? The black calls for tightening finger tight, waiting for it to set, then torque to final value. The gray calls for torque to final value right after installation. Both have been mentioned in prior posts. Both are sensor safe.
__________________
Bob
1992 Black/Black
Original Owner - 245K
Squashed by falling tree, fate TBD
  #2
Old 07-12-2007, 09:18 PM
jayro's Avatar
jayro jayro is offline
Registered
jayro is awesome!jayro is awesome!jayro is awesome!jayro is awesome!
Default
I used the blackstuff that came with my rod bearing kit when I did mine. No leaks so far.
Jeremy
  #3
Old 07-13-2007, 03:17 PM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
likewise.
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
  #4
Old 07-14-2007, 10:39 AM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
Default
I used the black but on the V8 the gray is what came from the factory. Supposedly the gray is for close tolerance machined surfaces?
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
  #5
Old 07-14-2007, 10:44 PM
Registered
Default
Quote:
Likewise the factory stuff on my V6 appears to be gray...but it may or may not be the same as Permatex Ultra Gray. According to the data sheet, the gray is a heavier body RTV and can be torqued to final value immediately. I imagine that characteristic appeals to repair shops. Permatex lists both as suitable for oil pans.
  #6
Old 04-05-2011, 06:44 PM
kevinspann's Avatar
kevinspann kevinspann is offline
Need Motivation
kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!
Default
Bump
Bob, what did you end up using?
I used the ultra black the "wrong" way (tightened pan all the way and called it good) and it leaked.
__________________
15s in 2015
  #7
Old 04-05-2011, 06:54 PM
Racer X's Avatar
Racer X Racer X is offline
SHO Pilot
Racer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond reputeRacer X has a reputation beyond repute
Default
I've used the black with good results more than a few times. My MTX doesn't leak a drop!
(kidding, used it on the oil pan)
__________________
1994 Taurus SHO 3.2L MTX
- Modded some more.
Quote:
Originally Posted by Mels View Post
I'd rather make a paper airplane out of my money and toss it off a bridge into the water than waste it on any Accel ignition product - at least I'd be able to enjoy watching it do what I'd intended it to...
  #8
Old 04-06-2011, 12:05 AM
Registered
Default
I used the Permatex Ultra Black, and followed these instructions, excerpted from their TDS dated 2006, except as noted:
5. Apply a continuous and even bead of silicone to one
surface (the OP), first tracing the internal areas (around inside of bolt holes) of the gasket
configuration, then all surrounding bolt holes.
6. Assemble parts immediately while silicone is still wet.
7. Finger tighten flange only until material begins to seep
out the sides of the flange.
8. Allow to set for at least two hours (I waited about 4 hours by circumstance) and re-torque at least
one quarter to one half turn (I torqued to specified value).
9. For best results, allow to cure overnight (oil drain plug removed so air can circulate).
During dry fitting, I rubbed a Sharpie on the rubber gaskets, and the ink transferred to the OP flange when I held it in place. That way I knew exactly where the RTV bead need to go to meet the rubber gasket.
Seemed to work! No leaks, knock on wood.
The following user says thank you to itwonder for this post:
kevinspann (04-06-2011)
  #9
Old 04-06-2011, 08:42 AM
JRA2000TL's Avatar
JRA2000TL JRA2000TL is offline
The Complainer
JRA2000TL has much to be proud ofJRA2000TL has much to be proud ofJRA2000TL has much to be proud ofJRA2000TL has much to be proud ofJRA2000TL has much to be proud ofJRA2000TL has much to be proud ofJRA2000TL has much to be proud ofJRA2000TL has much to be proud of
Default
I also used the black RTV when I did bearings on my 95 MTX. No leaks from the pan.
__________________
Quote:
Originally Posted by SuperHO View Post
Do yourself a favor-ball up your fist, punch yourself in the nuts, and then after you replace your timing chain tensioners, go back to that mechanic and smack him in the face with the used tensioners.
Stop being afraid of screwing something up, roll up your sleeves, grab your nuts and get dirty.
09 Corolla S (blk/blk)
95 SHO MTX (wht/tan)
89 SHO (red/gray) still leaks oil
06 Honda Aquatrax F-12X
90 SHO (slvr/blk) SOLD,crushed
93 SHO ATX (wht/tan) SOLD
  #10
Old 04-06-2011, 09:23 AM
89SHOMAN666 89SHOMAN666 is offline
SHO NUT!
89SHOMAN666 is spectacular!89SHOMAN666 is spectacular!
Default
I personally like the Ultra Copper RTV whenever the bond is between aluminum & aluminum (valve covers/head) or aluminum and another metal like the oil pan to block. It provides a dissimilar metal contact which is always preferable for long term sealing ability. The same principle is behind why it is preferable to use a copper anti-seize on spark plugs installed in aluminum heads.
Another great sealant for the oil pan is "hylomar". But the Permatex version is inferior to the original UK brand.
My 2 cents...
__________________
Peter AKA 89SHOMAN666 - PA Modified SHO Museum (Not Open To The Public)
89 SHO 100K T/B S/C
89 SHO 100K B/B
90 SHO 112K R/B S/C
90 SHO 122K W/M T/C
91 SHO+ 109K G/M Wet NOS
91 SHO 88K W/B S/C
94 SHO ATX 52K G/T
95 SHO ATX 100K W/G
95 SHO MTX 156K R/G
95 SHO MTX 160K W/G S/C
Junked: 2X-91, 92, 93, 94; Sold: 89, 91+; Parts: 94
94 F250 IDI Turbo E4OD 136K DD, 97 F350 PSD Stick 260K 15" Lift B/T
The following user says thank you to 89SHOMAN666 for this post:
jon93 (04-06-2011)
  #11
Old 04-06-2011, 10:50 AM
jon93's Avatar
jon93 jon93 is offline
BAMF
jon93 is a jewel in the roughjon93 is a jewel in the roughjon93 is a jewel in the rough
Default
What he said ^
Permatex Hylomar is like KY, dries up too fast and then your left standing there with sticky fingers wondering why you paid out the butt for a crappy product.
__________________
'91 3.0 MTX
'95 5.0 Mustang GTS
'07 5.4 F150
The following user says thank you to jon93 for this post:
89SHOMAN666 (04-06-2011)
  #12
Old 04-06-2011, 12:22 PM
AREA 91's Avatar
AREA 91 AREA 91 is offline
Registered
AREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud of
Default
I have installed many pans with the Ultra Black.
No leaks.
I also agree with peter on the copper anti sieze!
__________________
Quickest V6 Yamaha on the Forum!!!
WELCOME TO AREA 91
91+ Green Not Stock!
12.74 ET & 114.25MPH
257 WHP All Motor 336 WHP on N20
91 Mocha Frost 210WHP 210WTQ
I am the PA SHO SHOP
The following user says thank you to AREA 91 for this post:
  #13
Old 04-06-2011, 12:40 PM
kevinspann's Avatar
Need Motivation
Default
I will be using the ultra black (I did the first time as well) but I will try following Permatex's directions for it this time.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
