SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Guides (For How-to guides, NOT how-to questions)
Reply
Thread Tools
  #1
Old 05-26-2007, 02:11 PM
trevor404's Avatar
trevor404 trevor404 is offline
Addicted
trevor404 is on the right road
Default *PICTURES* Remove , replace fuel pump and fuel filter, no floor cutting!!
This is a step by step on how to remove your fuel pump and fuel filter. Because the fuel pump is an in-tank unit you will have to drop your fuel tank out of the car.You will need:
a) jack stands
b) a floor jack
c) various tools which will be covered in the rest of this post
d) basic mechanical knowledge
e) new fuel pump, new fuel filter (unless recently replaced), and a new fuel pump strainer.
So here we go... keep in mind i live outside of town so your car may not be so muddy underneath.
Step 1) Make sure your tank is as empty as possible. But if you can't empty the tank, like me because my car actually died, then you can siphon the tank. This will be explained in step 4. Start by parking your car, preferably on cement or pavement, and put it in gear (manual transmission). Then put the e-brake on, and then put blocks of wood in front of the front tires for added safety from the car rolling off the jack stands.
Step 2) You will need the floor jack and jack stands for this step. I used the point shown in picture (1) to jack my car from. Once you have placed the floor jack on a strong point, jack it up on one side to your desired height and place a jack stand under the car on the same side. I placed my jack stands under the lower suspension linkage, shown in picture (2), and didn't have any problems. Then repeat the process on the other side of your car until both sides have jack stands under them.
Step 3)Lay under your car and look at the rear passenger side of the gas tank and you will a small hose and a large hose. You can see this in picture (3). The small hose is your tank vent hose and the large one is the tank filler hose. Use a flat-bladed screwdriver to loosen the clamp on the small hose. Do the same on the large hose. You can see a tank strap bolt at point (a).
Step 4) If you still have lots of gas in your tank (I had a 1/2 tank) then you can siphon it out. I siphoned the tank through my tank vent hose which you will have to seperate from the metal piping as seen in picture (4).The siphon I used is shown in picture (5). If you don't know how to siphon then look it up on the internet.
Step 5) Remove the hose going to the back of your fuel filter. Your filter is in front of your gas tank on the passenger side and should look like the one in picture (6). The hose will have a clip on it that you can open with a flat-bladed screwdriver. If you are replacing your filter too then remove the clamp until it seperates so you can pull the filter out of it's bracket.
Step 6) Place a floor jack under your tank with a piece of wood between the jack and the tank so you do not damage your gas tank. Put the jack in from the drivers side so the tank can tip out towards the passengers side, as it will cathc on the drivers side exhaust piping. Remove your tank strap bolts. To find these follow the straps under your gas tank towards the back of the car. Spray them with some kind of lubricant first such as WD-40. DO NOT use a 12 point socket to remove the bolts. I did this and I rounded off the head on one of my bolts. I then had to use a grinder to cut off the head of the bolt which wasted alot of time. Keep in mind that I live in Alberta, Canada so rust is everywhere around here. Hopefully your bolts are clean and rust free so they come out easier than mine did.
Step 7) Assuming your bolts came out, slowly lower you floor jack a few inches at a time while checking the passengers side regularly to make sure that no hoses are going to catch. As you lower the tank push it gently towards the front of the car to seperate the tank filler hose and vent hose from the cars metal piping. Lower the tank as far as you can without risking a plastic hose breaking off of the top of the tank. Then proceed to remove the plastic hoses and electrical clip from the top of the tank. The tank with all plastic hoses removed can be seen in picture (7).The rubber ended hoses seen at point (a) will seperate from the white plastic vent. Just gently pull and twist until they come off.
Step 8) You should see a ring surrounding the the pump sending unit as outlined in red in picture (8). It will have several tabs sticking straight up. Place a flat bladed screwdriver against one of the tabs and hit the screwdriver with a hammer so that the ring rotates counter-clockwise. (I think that it rotates counter-clockwise, you will be able to tell fairly quickly if it doesn't move.) Be careful not to stab yourself or break off the electrical connection with the screwdriver if it slips off of the tab.
Step 9) Once the ring is removed, CAREFULLY remove the assembly from your tank without breaking any plastic or bending your fuel level arm. The removed assembly can be seen in picture (9). You can also see the pump in the picture.
Step 10) Remove the 2 electrical connectors from the top of the pump itself. They should be a black and a red wire. Note which way they were attached to the the pump. Remove the pump strainer from the bottom of the pump. Hopefully you bought a new one so that you don't have to be too careful with this step. You can remove it by pulling on it or prying it off with a screwdriver. I set myself back a few days at this point by breaking my strainer and not having a new one handy. Now carefully remove the pump from the assembly. I had to insert a screwdriver at point (a) in picture (10) and pry on it to get the old pump out.
Step 11) Put in the new pump and hook up the electrical connectors. Then put the new strainer on the pump as the old one was. If your fuel pump came with a new tank seal o-ring then replace that at this time. Then carefully put the pump assembly back into the tank positioned the same way as it was before you took it out. Tighten the locking ring back onto the top of the pump assembly so that it is secured in the tank. Then slide you tank back under the car and lift it on top of the floor jack. Hook up all of your plastic hoses and the electrical connector clip on top of the tank. DOUBLE CHECK to make sure that you have everything hooked up. Jack the tank back into place and hook up your tank filler and tank vent hose. Then put your tank strap bolts back in. I bought new strap bolts and the clips that they bolt into just to be safe. I would have bought new straps but my left one is $20 and my rightone is $120! Figure that one out. YOU'RE DONE! Lower your car off of the jack stands and refill your gas tank if you had to siphon it out. It may take a few seconds for the car to get fuel to the motor while you are cranking it. If everything worked out then you should be driving your car away as a happy, or very frustrated, individual.
If you have any questions just ask or email me at trevor_bayne@hotmail.com
Enjoy!
The Following 3 Users Say Thank You to trevor404 For This Useful Post:
FOMOCOTOSHO (11-18-2009), johndallara (03-16-2009), n8rsk8r (09-29-2007)
  #2
Old 05-26-2007, 09:54 PM
Shoman594's Avatar
Shoman594 Shoman594 is offline
Moderator
Shoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to all
Default
Nice work Trevor, the write up you did is even better.
Thanks!!
__________________
Ryan
Founder - BringbacktheSHO.com
Chicago SHO Club - SHOCAGO.com
1989 Light Titanium 40k Miles (Cabin Fever)
1989 Orange & Red with a little green #32 (Raphael)
1996 Charcoal Grey 1st 5-Speed Conversion (SOLD)
  #3
Old 05-26-2007, 10:13 PM
SASHO91's Avatar
SASHO91 SASHO91 is offline
Zoom Zoom
SASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid one
Default
Awesome write-up...
Allthough, I still support the access panel 100%. I'll never drop another SHO tank.
__________________
Josh
99' Miata- 270whp & 2250lbs... "Fun" covers it.
08' F-150 Crew Cab 5.4 DD
  #4
Old 05-27-2007, 04:28 PM
1993MTXSHO's Avatar
1993MTXSHO 1993MTXSHO is offline
Its a Taurus...
1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of
Default
its probably not a bad idea to clean the tank out while you have it out, I just had major problems with my mustang because of crap in the tank. Buy some gas tank cleaner pour it in and swish it around to clean all the junk out. Great writeup though, this should get a sticky
__________________
1993 mtx 100k green/tan (up on blocks... again)
1994 mtx 136k green/tan (now green/black, thanks to the atx) (3.2 swapped and now the new DD) SOLD
1993 atx 169k green/black (was DD, now parted/junked)
1994 atx 159k green/tan (parted/junked)
1994 mtx 131k green/tan (parted/junked)
  #5
Old 05-28-2007, 12:13 AM
trevor404's Avatar
Addicted
Default
Yeah i'm not going to lie, I felt like cutting a hole in my floor a few times during the process. But it could have been worse. The one thing I would be worried about is the floor panel leaking water and rusting out my floor. But I suppose if you seal it up with weatherstripping or silicone or something then it shouldn't be a problem.
  #6
Old 05-28-2007, 03:52 AM
F-22 Raptor SHO's Avatar
F-22 Raptor SHO F-22 Raptor SHO is offline
Moderator
F-22 Raptor SHO is a jewel in the roughF-22 Raptor SHO is a jewel in the roughF-22 Raptor SHO is a jewel in the rough
Default
Very nice. before anyone trys to undertake this project in this fashion, they need to realize that if you have SFC's, your tank wont drop.
__________________
White 9D1 minus. Silver Award Winner, 16th Annual SHO Convention. Kalamazoo, Michigan 2007
"The armies of heaven were following him (Christ), riding on white horses and dressed in fine linen, white and clean". Revelation 19:14
More Pictures of my ride
Whats that yellow Check Engine Light Mean?
SHO Torque Specs
  #7
Old 05-28-2007, 11:03 AM
mrecoolgar's Avatar
mrecoolgar mrecoolgar is offline
SHO NUP
mrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to all
Default
Ford got smart with the Contour and added an access under the rear seat.
Nice 'how to'.
__________________
Current Rides
SHOs: 1989 Currant Red-Titanium, 1989 Titanium-Titanium, 1989 Oxford White-Titanium, 1990 Electric Red-Sandlewood, 1991 Deep Jewel Green-Mocha, 1996 Rose Mist-Graphite
Others: 1968 Cougar XR7, 1988 Mazda RX7 Vert, 1989 Cougar XR7 SC, 1995 Contour SE My Lil-Sho, 1997 Ranger XLT, 2005 F150 King Ranch 4WD
  #8
Old 05-28-2007, 12:25 PM
Bringetto Bringetto is offline
What broke now?
Bringetto is on the right road
Default
very nice write up
loving the mudflaps too, where can you find those?
__________________
  #9
Old 05-28-2007, 12:26 PM
What broke now?
Default
nice write up
and nice mud guards too, where can i find some like that?
  #10
Old 05-28-2007, 05:20 PM
keny_kimmel's Avatar
keny_kimmel keny_kimmel is offline
ETSN Kimmel(SS)
keny_kimmel is unknown at this point
Default
True if you have the SFC the tank wont drop but doesnt the access door project involve cutting. Cutting makes sparks with a wheel. How can you make the door without cutting with a wheel or torching?
__________________
1994 ATX KM Metalic Blue. I am a United States Sailor. I will support and defend...
ETSN Kimmel(SS)
  #11
Old 05-28-2007, 11:04 PM
revhardSHO revhardSHO is offline
Registered
revhardSHO is spectacular!revhardSHO is spectacular!
Default
The new way of cutting through the floor is much easier and faster. Both can pose a danger to the mechanic.
I have been installing fuel pumps through floor ever since I found out about it. MUCH easier, less hassles. Especially if you have a rusty car.
__________________
93 MTX - Green
Subframe Connectors (SHO Source)
MagnaFlow Y-Pipe
96 Brakes HPS pads
Stainless lines
HD Motor mount
Upgraded headlight harness
Chopped rod shift
TPR Bushings everywhere
larger sway bars
  #12
Old 05-29-2007, 01:23 AM
SHO Continental's Avatar
SHO Continental SHO Continental is offline
Moderator
SHO Continental is a splendid oneSHO Continental is a splendid oneSHO Continental is a splendid oneSHO Continental is a splendid oneSHO Continental is a splendid oneSHO Continental is a splendid oneSHO Continental is a splendid oneSHO Continental is a splendid one
Default
Is that a build sheet in picture 8?
__________________
Matt A
['95 Jewel/Mocha]
SHOCal | California SHO Club
  #13
Old 08-18-2007, 09:13 AM
shovermont's Avatar
shovermont shovermont is offline
unleasing my 91
shovermont is on the right road
Default
with my fuel tank cutout i have that i bought my SHO with, has saved my ass a few times already. i have had the fuel pump out three times in 4 months, and 2 days ago i had to replace it cause it died, 20 minutes with the modification and i just sat comfy in my backseat, really worth cutting out and making a door.
__________________
Quote:
Originally Posted by Racer X
*edit*
I should check the date of some of these threads before I post..
The $200 dollar SHO is up and running, off the road for the winter and very excited about next spring and summer. Modifications..
  #14
Old 09-29-2007, 02:35 AM
n8rsk8r's Avatar
n8rsk8r n8rsk8r is offline
Hey Where's my post?
n8rsk8r is a jewel in the roughn8rsk8r is a jewel in the roughn8rsk8r is a jewel in the roughn8rsk8r is a jewel in the rough
Default
Quote:
+1 good eye
Thanks for the write up!
  #15
Old 11-03-2007, 06:21 PM
spaul2005 spaul2005 is offline
Registered
spaul2005 is on the right road
Default
good job im doing my replacement right now.
  #16
Old 02-07-2008, 11:26 AM
Storm-Chaser Storm-Chaser is offline
Registered
Storm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud of
Default
Anyone know what year Contours have the access panel, off hand? Did they use an access panel, or a large grommet-plug?
Quote:
Nice 'how to'.
__________________
Carlisle registration #5306
Memorable quotes from the past . . . .
Quote:
Originally Posted by hawkeye18 View Post
I SWEAR TO GOD, I am going to pistol-whip the next person who says the word "shenanigans"!
Quote:
Originally Posted by Russsho View Post
My wife is not going to be pleased.
Reminds me of the time she opened the dishwasher and found my intake, in pieces, inside it.
Quote:
Originally Posted by AutoSHO View Post
I realize this might be a stupid question, but what is the coolant level?
St. Louis SHO.com
  #17
Old 03-14-2009, 09:51 PM
Tecchie Tecchie is offline
Registered
Tecchie is on the right road
Default
*Beating the Dead Horse with a rusty wooden mallot* (think about that one....)
Yes, what year(s) did Ford start to do that with the access panel in the floor for the fuel pump... I'd like to see if I could adapt one to fit my Sho.. :P
  #18
Old 03-14-2009, 09:57 PM
ManySHOs's Avatar
ManySHOs ManySHOs is offline
ManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid one
Default
Quote:
I used tin snips.
Ian
__________________
93M Tortoise Slow
02M Audi A6 2.7 TT Sport package
Quote:
Originally Posted by Shoaz View Post
Yeah, Hennessey making noise about the SHO is about as exciting as Earl Scheib saying he'll paint one up all special and everything.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
