SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Electronics & Audio
Closed Thread
Thread Tools
  #1
Old 04-14-2007, 04:02 PM
hypnotic hypnotic is offline
Registered
hypnotic is on the right road
Default IRCM/CCRM details
So the ccrm that came on the car when I bought it broke, it had a letter M on it and I have now found out that is the right one for my 93 mtx. I bought a module with a J on it from a junk yard and it works but my car isnt recognizing the new cps it seems like. I just wanted to know what will go wrong if I do not have the right ccrm.
-craig
__________________
Craig
90 SHO Red/Black SOLD!!
93 SHO Green/Mocha MTX SOLD!!
90 GMC Sierra 33s, 3" lift, 350
  #2
Old 04-14-2007, 04:06 PM
1993MTXSHO's Avatar
1993MTXSHO 1993MTXSHO is offline
Its a Taurus...
1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of1993MTXSHO has much to be proud of
Default
from what i always knew was the J was for autos but then i read some mtx's had it, I also read that they all work on any car. Id try to get one with an M on it and see if that helps. My mechanic said i couldnt use the one with the J and made me go get one with an M so who knows.
__________________
1993 mtx 100k green/tan (up on blocks... again)
1994 mtx 136k green/tan (now green/black, thanks to the atx) (3.2 swapped and now the new DD) SOLD
1993 atx 169k green/black (was DD, now parted/junked)
1994 atx 159k green/tan (parted/junked)
1994 mtx 131k green/tan (parted/junked)
  #3
Old 04-14-2007, 04:13 PM
whiteman_01's Avatar
whiteman_01 whiteman_01 is offline
Registered
whiteman_01 is a jewel in the roughwhiteman_01 is a jewel in the roughwhiteman_01 is a jewel in the rough
Default
I had a J in my car when i got it. Well i had some problems and i replaced i with an M. It was not the problem, but i have had no ill effects of switching the two.
__________________
Joe
96 Medium Graphite, NESHO MTX swapped,
Quaife, Eibach Springs, SHOrty shifter,
CM3 clutch, EGR delete, 3rd cat delete,
Air pump delete, Secondaries deleted,
13" Cobra fronts, 11.6" rear
  #4
Old 04-14-2007, 04:21 PM
Registered
Default
thanks I appreciate it. I have just had so many problems with this car I am trying to rule out everything.
  #5
Old 04-14-2007, 04:37 PM
1993MTXSHO's Avatar
Its a Taurus...
Default
Quote:
well id say replacing it with one thats got the same letter of yours is your best bet then, that way you knows for a fact its the same
  #6
Old 04-14-2007, 04:39 PM
NWGRN94MTX's Avatar
NWGRN94MTX NWGRN94MTX is offline
Moderator
NWGRN94MTX is a beacon of lightNWGRN94MTX is a beacon of lightNWGRN94MTX is a beacon of lightNWGRN94MTX is a beacon of lightNWGRN94MTX is a beacon of lightNWGRN94MTX is a beacon of light
Default
Trust me, get an M.
__________________
SHO Source LLC a great place for SHO Parts! <---click the hot link!
"And I never pull a motor just to replace the rod bearings...that is buffoonary. Slap whoever told you that."
"Weasels and squirrels are not an endangered species" - Customer Service Department
94 MTX "It's not easy being Green." - Kermit Frog
SHOforum TOS SHOforum Guidelines
2004 & 2008 Gold award winner. Generation 2 - Modified, 2008 Best Engine
  #7
Old 04-14-2007, 09:56 PM
Storm-Chaser Storm-Chaser is offline
Registered
Storm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud ofStorm-Chaser has much to be proud of
Default
Why? Is there some benefit to having the "M" over the "J" (like the D4U1), or because it can/does create porblems having the wrong module?
  #8
Old 04-15-2007, 12:52 AM
shopartsnw shopartsnw is offline
SHO Medic
shopartsnw is a splendid oneshopartsnw is a splendid oneshopartsnw is a splendid oneshopartsnw is a splendid oneshopartsnw is a splendid oneshopartsnw is a splendid oneshopartsnw is a splendid one
Default
Just a few things to think about.
When I was a newbie, I tried an M in our 95MTX (it needs a D). The fuel pump would not work with the M, so it couldn't even start. In our case, the incompatibility saved us some hardship. I know one possible incorrect CCRM combination will let the car start, but it will not allow the cooling fan to come on. In this case, you have an engine waiting to overheat if you do not see the temp gauge spike up.
Now think about the other differences
ATX has two fans, MTX has one.
94/95 has two speed fan, 89-93 have single speed fan.
I keep hearing people say it does not matter, but I have seen evidence to the contrary. Why take a chance when you could just put the right part in?
Mike (tired from a day of wrenching - sorry for the vent)
__________________
SHOSource.com Quality, Integrity, Honesty
  #9
Old 04-15-2007, 01:58 AM
Registered
Default
I think you misinterpreted my post - I am asking because I want to truly want to know. So much of what is passed around here, is often based solely on "WOMs" (word-of-mouth), often based on something someone heard from someone else. I want to know because I have always installed the correct OEM part when I can, not just the one someone says will work ("..., trust me, it will work just fine...."). Been there, listen to that, and learned that leason the hard way long ago....
Quote:
I heard that! I spent from 1145-1600 on the lift, under the car today....
Btw, still have those rear 90-92 rotors?
  #10
Old 04-15-2007, 02:23 AM
NWGRN94MTX's Avatar
Moderator
Default
Storm Chaser,
My apologies, I should have explained better. I just don't like arguing on forums anymore. I won't argue, but I should explain.
  #11
Old 04-15-2007, 04:07 AM
TYSHO's Avatar
TYSHO TYSHO is offline
TYSHO is a jewel in the roughTYSHO is a jewel in the roughTYSHO is a jewel in the roughTYSHO is a jewel in the rough
Default
What combination is that?
__________________
89 SHO: SS Headers, SS Catless Y, DynoMax Catback, SS STB's, SS UDP's, P&P'd Intake, BBB's, Fidanza FW, Al SFB's, Reinforced Differential, Solid Mounts, TPR Bushings, Tokico/Intrax, & Blue Bottle
Your Ford Parts Source, Providing the Cheapest Cost of New Ford Parts for the SHO Community 7 years Strong! Check out the Classified Section for my Thread and let us help raise money for SHOForum!
Reinforced ATX Motor Mounts and Welded Differential Service Available
  #12
Old 04-15-2007, 12:54 PM
SHO Medic
Default
Quote:
Somehow, I knew that question would come up. At some point, I may need to do a detailed study of CCRM swaps, but I can't even think about it until Karen's race car is built (about 3 weeks).
I can remember this from memory:
M will not operate the fuel pump if it needed a D (94/95 MTX)
D seems to operate in place of an M, but I would need more detailed study to verify the cooling fan, etc.
As for the J into an M car, we have sold a couple M's to people on the forum who had Js and thier cooling fans were not coming on. I would need to reproduce the effects, but it could be a J in an M car won't operate fans, or it could be that a J in an M car will fail at some point due to some wiring difference. It could also just be a coincidence as we have also sold M's to people with bad M's. J into M is my best bet for a cooling fan issue.
I have not tried an M into a J car, but I am sure someone here has.
Sorry I couldn't be more specific.
Mike
  #13
Old 04-15-2007, 02:49 PM
TYSHO's Avatar
Default
Well, I guess I can do the testing with the "J" and "M" ones since I have both in working condition, that way we know for sure.
Perhaps some failures to operate might have been from damaged modules?
For a fact, I know the "D" code works on "J" code ATX's. However, the "J" code is also used in the regular Taurus as well during the 90's, which I have not tested with a "D" code. There's some other combos that work as well, but I would need to gather the information or have that person post them.
  #14
Old 04-16-2007, 05:21 PM
hawkeye18's Avatar
hawkeye18 hawkeye18 is offline
Sorta cares
hawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond repute
Default
Well, I don't have an M code schematic, but I do have the J and D codes.
J code:
D code:
Judge for yourself.
__________________
Jason H ('95 ATX, '13 Focus Titanium)
My radar sees farther than your SHO can drive on a tank.
  #15
Old 04-16-2007, 06:23 PM
NWGRN94MTX's Avatar
Moderator
Default
Quote:
J code:
D code:
Judge for yourself.
Thanks! Now we need a "M" pin out and we will be set.
  #16
Old 04-16-2007, 10:02 PM
hawkeye18's Avatar
Sorta cares
Default
Well, as long as a 93 MTX uses an "M" code CCRM, here you go.
Ask and ye shall receive!
Images courtesy of www.fordcds.com.
  #17
Old 04-16-2007, 11:59 PM
NWGRN94MTX's Avatar
Moderator
Default
A sticky is in order! Thanks again!
  #18
Old 04-17-2007, 11:57 AM
92inPA's Avatar
92inPA 92inPA is offline
Registered
92inPA will become famous soon enough92inPA will become famous soon enough
Default
The CCRM controls power to the fuel pump, AC and cooling fans. I tried to explain a bit of the details on my web page. For sure, as you have noted all three boxes are not fully interchangeable.
Bob's CCRM page
I own a 95 mtx (D), a 93 atx (J) and a 92 (M). In my mountain of spare parts I also have all three boxes. Maybe I should try all the combinations and report back with the results.
__________________
Bob
SOLD - 92 w/ a mod or two
traded 4 wheels for 2
  #19
Old 04-17-2007, 01:05 PM
projectSHO89 projectSHO89 is offline
SHOless In St L
projectSHO89 is a beacon of lightprojectSHO89 is a beacon of lightprojectSHO89 is a beacon of lightprojectSHO89 is a beacon of lightprojectSHO89 is a beacon of light
Default IRCM/CCRM info
(Note: I wrote this up this morning. Needs proofed. If you find a mistake or see anything questionable, please PM your comments to me, do not make an additional post. I will edit any needed changes. Thanks.)
IRCM/CCRM Functions/Pin-outs
The IRCM/CCRM performs four functions on the SHO:
1) EEC Power Switching
2) Fuel Pump Relay Switching
3) Cooling Fan Power Control
4) A/C Clutch Control
All years, all versions:
Pin 15 is ground.
Pin 16 (A/C Coil low side) is connected to pin 15 internally.
Pin 8 is ALWAYS HOT.
Pin 13 is HOT in RUN/START.
1. EEC Power Switching: When the ignition switch is turned to START/RUN, switched power is applied to the high side of the EEC POWER RELAY coil (low side is grounded). The COMMON terminal of the AC POWER RELAY is connected to pin 8. The output of the EEC POWER RELAY is supplied to the high side of the fuel pump, fan, and AC clutch coils and is distributed out pin 24 as SWITCHED B+ to the PCM and to various sensors and actuators on the engine when this relay is energized.
2. A/C Clutch Control: There are two inputs to the A/C clutch circuit and one output:
A) A/C Request signal (Pin 21). This is a switched HIGH (battery voltage) signal that is true when the EATC/HVAC control and the cycling switch have requested compressor clutch operation.
B) WAC* (WOT A/C Cutout - Pin 22). This is an active LOW (ground) signal from the PCM that is enabled when the PCM has determined that compressor operation must be disabled, i.e., under heavy acceleration.
C) A/C Clutch Coil (Pin 23). This is an active HIGH (battery voltage) signal that is true only when Pin 21 is high and pin 22 is not LOW.
Variations by Type
Fuel Pump Control
All versions provide output on Pin 5.
Type M:
(89-93 MTX) IRCM boxes contain two fuel pump relays. 89 and 90 used an external dropping resistor in the supply line for the LOW SPEED FP RELAY common (Pin 10). 91 and 92 MY vehicles have a jumper that applies full B+ to the supply of the LOW SPEED FP RELAY. All years supply B+ to the HIGH SPEED FP RELAY common via pin 12. The NO contacts of both relays are tied together internally in the box and is output on pin 5. The LOW SPEED FP RELAY is energized by the PCM by applying a ground to Pin 18 (Note: The FP TEST pin on the DLC is connected to this pin). The HIGH SPEED FP RELAY is energized by the PCM by applying a ground to pin 11.
Types D and J:
(93-95 ATX, 94-95 MTX) CCRM has a single FP RELAY. B+ power is supplied to the common terminal via pin 12. The FP RELAY is energized by the PCM (or grounding the FP TEST pin on the DLC) by grounding pin 18.
Cooling Fan
Type M:
(89-93 MTX) Single speed. Input fan power is supplied to pins 1 & 2. A single fan relay is energized by applying an active ground to pin 14. Output switched power is output on pins 3 & 4 to the electric fan.
Type D:
(94-95 MTX) Dual speed cooling fan (dual coil). Input fan power is supplied to pins 3 & 4. LOW SPEED FAN RELAY is energized by a ground on pin 14 and switches power to pins 1 & 2 which is routed to the low speed fan winding. HIGH SPEED FAN RELAY is energized by a ground on pin 17 and switches power to pins 6 & 7 which is routed to the high speed fan winding. Due to an internal switching diode, application of a low on pin 17 will result in BOTH fan relays being energized.
Type J:
(93-95 ATX) Dual fans in parallel with an external low speed dropping resistor. Input power via resistor is applied to pins 1 & 2 to the common terminal of the LOW SPEED FAN RELAY. The relay is energized by applying a ground to pin 14. Switched power is output on pins 3 & 4. Full battery power is input via pins 6 & 7 to the HIGH SPEED FAN RELAY common terminal. The relay is energized by grounding pin 17. Switched power is output on pins 3 & 4.
__________________
SHO #1 - 94 ATX aka "Princess". Replaced with a $3000 car back in 2000 before my 16-year-old turned the Princess into one.
SHO #2 - 89 "The Project" Retired at 249K miles to James' place.
SHO # 3 - Another 94 ATX - Daily driver with 238K on it.
  #20
Old 05-01-2007, 07:25 PM
Registered
Default
How about this...
I should have an M and I have a J but my fan still kicks on. I thought it wasn't supposed to?
-craig
  #21
Old 05-01-2007, 07:34 PM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
How'd it get a J? Computer swap?
Try to get the oasis report on your car.
It might be that it had a problem for the first owner that was solved at the dealer under warranty. That repair may have entailed a computer/other parts swap.
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
  #22
Old 05-01-2007, 08:12 PM
92inPA's Avatar
Registered
Default
hypnotic, Your CCRM is only partially working. Actually you only have the low fan speed working. To get the high fan speed you need to use an "M". Since you are in a southern (warmer) state, I would recommend that you get the correct CCRM. M boxes are very common, so you should have no trouble getting one.
  #23
Old 05-04-2007, 05:16 PM
Registered
Default
I plan on it, I heard it kick on the other day and wanted to let everyone know, but I guess it doesn't work properly.. just kinda.
-craig
  #24
Old 05-05-2007, 09:32 AM
SHOless In St L
Default
Guys, post troubleshooting situations in the regular forum, not in "stickied" posts.
This thread should be used primairly for reference.
Steve
  #25
Old 11-19-2007, 07:59 PM
1-5-0 SHO 1-5-0 SHO is offline
Registered
1-5-0 SHO is on the right road
Default
I have a 93 ATX. Which pin # is the wire that the computer chip sends the signal to ground out in order to open the butterflies at ~4,000 RPM? I want to install a toggle switch so that I can ground out the wire manually and have the butterflies open all the time when I want it versus having to unplug the vacuum line. That way I can switch between getting good gas mileage vs race time.
My guess is narrowed down to 22 (WOT) but might be also 14 as well. Anyone know?
__________________
I paid $150.00 for this 93 atx w/ 96,xxx miles:
  #26
Old 11-19-2007, 09:57 PM
hawkeye18's Avatar
Sorta cares
Default
Here is the PCM pinout for a 93 ATX:
As you can see, you want pin 34. It's light green and pink. Hope this helps!
OBTW, this is off the computer, not the ICRM...
The following user says thank you to hawkeye18 for this post:
1-5-0 SHO (11-19-2007)
  #27
Old 11-20-2007, 07:10 AM
SHOless In St L
Default
Since you can't follow instructions, I have locked this thread.
Start a new thread in the proper place.
Steve
  #28
Old 07-20-2008, 05:10 PM
SHOless In St L
Default Schematics added
Attached.
Click to open pdf file.
Steve
Closed Thread
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
