SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 03-02-2004, 12:33 AM
SHOtimer's Avatar
SHOtimer SHOtimer is offline
#2910
SHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of light
Schrader Valve
I think that is the proper spelling for the fuel pressure valve on the fuel rail. Well I changed my fuel filter this weekend and prior to doing anythign I depressurized the fuel system. I took the cap off of the schrader valve and gas started to come out of it. So I soaked it all up and thought that was strange. Then I changed the filter and pressurized the system without starting the car and gas was (not squirting) but significantly coming out of that valve. So, unless I have the little black plastic cap on tight it leaks gas, if the cap is on it is as dry as can be. I don't think this is normal, do I need a new valve? Are they very hard to replace? Wait, they are prolly discontinued...
Thanx, Doug
__________________
95 ATX - 261k
95 Lincoln Mark VIII - 144k
90 Dodge Dakota - 102k
99 MBZ 230 Kompressor - 149k
  #2
Old 03-02-2004, 01:21 AM
Electricat Electricat is offline
Registered
Electricat is on the right road
That cap is really intended more as a dust cover than as a seal, you need to get the valve to stop leaking.
The plunger part of the valve may just not be seated correctly, try poking at it a little and see if it closes off the leak.
If it still doesn't stop leaking, get a "Schrader valve core tool" from any auto parts store for about $2, and tighten the core a bit with it.
If it still doesn't seal, use the tool to screw the core out, and replace the core. I have used the Schraeder cores that are sold for tires as replacements on fuel systems with no apparent problem, but I'm not sure if they are ok for fuel long-term, so you may want to see if you can get one especially intended for fuel.
__________________
'95 Moonlight Blue ATX
  #3
Old 03-02-2004, 02:33 AM
NotSoSlowSHO NotSoSlowSHO is offline
Gas is $$ WALK!
NotSoSlowSHO is a splendid oneNotSoSlowSHO is a splendid oneNotSoSlowSHO is a splendid oneNotSoSlowSHO is a splendid oneNotSoSlowSHO is a splendid oneNotSoSlowSHO is a splendid oneNotSoSlowSHO is a splendid one
Quote:
Electricat:
More commonly known as a Valve stem core remover wink
__________________
~Kenny~
"SHO-less" as of June 2013
Currently occupying a mythical place known as IDAHO.
  #4
Old 03-02-2004, 02:39 AM
haydenm315 haydenm315 is offline
Registered
haydenm315 is on the right road
Quote:
NotSoSlowSHO:
Quote:
Electricat:
or the I'm gonna give you 4 flat tires and tape a bag with your valve cores to your window tool. evil_gri It hasn't happened yet. I'm still waiting for the perfect victim.
__________________
93 hwyte mtx SHO
  #5
Old 03-02-2004, 02:45 AM
Gas is $$ WALK!
rofl
Back in high school, there was this a-hole teacher that nobody liked, and well myself and a friend...
I wont say any more finger
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
