SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 04-07-2003, 04:40 PM
SHOman247 SHOman247 is offline
Registered
SHOman247 is on the right road
Where to buy SHO parts
anyoine know where i can buy SHO parts...like rod bearings...belts...plug wires...and other parts..any autoparts stores carry SHO parts? Any info is much appresiated..thank you...
__________________
Quote:
Originally Posted by Chris Cicotte
Greg, you race your car way too much.
Quote:
Originally Posted by pete c
If you want to be a SHO owner, but are unable/unwilling to do 99% of the wrenching yourself, you will be screwed, in the arse, hard and dry without the benefit of a reach around.
91 SHO Plus oxford white 118k
This car is going to make a mechanic out of me
TCCA - Tman
Shoforum - Shoman247
Roseville, MI
  #2
Old 04-07-2003, 04:48 PM
Mike Kopstain's Avatar
Mike Kopstain Mike Kopstain is offline
Registered
Mike Kopstain is a jewel in the roughMike Kopstain is a jewel in the roughMike Kopstain is a jewel in the rough
My obvious favorite: www.midwestsho.com
www.shonutperformance.com
www.shoshop.com
www.spmotorsports.com
www.iptech.tv.com
__________________
Audi A8L
BMW 550i Sport w/ 6 speed manual
Volvo XC90 - My wife chose it, I swear!
  #3
Old 04-07-2003, 04:49 PM
twr's Avatar
twr twr is offline
whoohoo
twr is spectacular!twr is spectacular!twr is spectacular!
www.fordpartsnetwork.com for plugwires and plugs
www.shonutperformance.com has hard to find parts
Napa sells the rod bearings
Autozone sells the main bearings and alot of the gaskets
Between those four you can just about everything.
__________________
Terry
2008 Impreza STI, yeah it's already got a few modifications..
  #4
Old 04-07-2003, 04:53 PM
Registered
Thanks guys...especially my fellow TCCA'er
  #5
Old 04-07-2003, 05:39 PM
CALL AAA's Avatar
CALL AAA CALL AAA is offline
Yes THE callaaa
CALL AAA will become famous soon enoughCALL AAA will become famous soon enough
Hey, I'm a TCCAer, too! I have all of 5 posts.
Anyways, about how much do rod bearings cost. What else should be replaced while I'm under there?
Thanks
__________________
Tony
'02 Audi S6
'09 Jetta TDI
'12 Audi S5
  #6
Old 04-07-2003, 05:54 PM
stevetatro's Avatar
stevetatro stevetatro is offline
Registered
stevetatro is on the right road
The Clevite rod bearings from NAPA (#CB1435P I think) are about $7/set. You need 6 sets.
You'll want to replace the oil pan gasket. You'll also might need to fabricate a new oil pickup tube gasket, as I think the part is obsolete.
Since you'll have the y-pipe off, it would be an excellent time to upgrade!
Oh, and you might want to replace the oil ;^)
__________________
Steve Tatro
stevetatro@hotmail.com
Red/Black '93 with 197k miles
Cincinnati, Ohio
  #7
Old 04-07-2003, 06:19 PM
twr's Avatar
twr twr is offline
whoohoo
Quote:
stevetatro:
You can get the Felpro V6 MTX Oil Pump Gasket Kit (Called Timing Cover Set) - includes oil pump-to-block gasket, oil pickup gasket, front oil pan seal, and front main seal. Obsolete from Ford, but available from Felpro.
  #8
Old 04-07-2003, 11:35 PM
Yamaha V6's Avatar
Yamaha V6 Yamaha V6 is offline
SHO Enthusiast
Yamaha V6 will become famous soon enoughYamaha V6 will become famous soon enough
FYI, the FelPro kit's front crank seal has been oversized & damaged on 3 of my attempts so far vs. the normal smooth installation of the E9DZ-6700-B Ford crank seal. Since the front pan seal is the only one included, and you pull the whole pan off, I don't see the benefit of the extra pieces (other than the oil pump & pickup tube gaskets themselves). You still have to / should get the rear pan seal as well.
Just an opinion, of course.
I remember when the guy first came up to my garage with the Fel-pro "timing cover set" package. I was like, "GIMME THAT!", and promptly emailed Josh T the number when I saw what was inside. Fred beams...
__________________
Fred Hurder Jr
1991 Black over Mocha Gen 2 Leather, Police Grille, Plus Hood
3.2L MTX, Stage 1 Cams, Ported, Fidanza FW / Stage 3 DDPP Clutch
77mm Pro-M, High-Flow Y, Dynomax Cat-Back, Reinforced Mounts, New Shafts
Tokicos / Eibachs, AL SFBs, 11.6's Front & Rear
17x8 Black Mille Miglia MM-11 Wheels, 245/45-17 Falkens
214 whp / 201 wlb-ft
  #9
Old 04-08-2003, 09:43 AM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
Try the National 710220 part for the front main crankshaft seal as it was the OEM part and is a better fit. Look here for some common parts and their lowest cost sources.
__________________
Helping to keep the SHO on the road,
Scott
1991, 433K miles, and rolling...
In-car Track Video: Laps at TWS
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
