SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Emergency Issues - Help & Maintenance
Reply
Thread Tools
  #1
Old 03-22-2007, 11:47 AM
mylaw mylaw is offline
The Sho Time
mylaw is on the right road
Default EGR failure symptoms !
I changed DPFE sensor and cleaned the nostrils in the intake they were plugged and car still idles low and stalls when cold .. Lack of power..
I did the suck test on the egr hose and the engine did not change at all .. Faulty EGR?
Can anyone shed some light on this .... Thank You
__________________
93 Greeen 3.2 ATX SHO
The Sho Time
theshotime@hotmail.com
  #2
Old 03-22-2007, 12:22 PM
jedhead's Avatar
jedhead jedhead is offline
Registered
jedhead is a jewel in the roughjedhead is a jewel in the roughjedhead is a jewel in the rough
Default
Did you pull codes? My failing EGR only causes some light pinging at 2000 - 3000 rpm other wise no other problems. Your problem maybe related to something else.
Bob
__________________
1991 SHO
2006 Cadillac STS-V
2003 Honda Accord EX
1973 Datsun 240Z
SHOCal
Car Domain
  #3
Old 03-22-2007, 12:30 PM
The Sho Time
Default
332, 326, codes
the egr i believe is stuck closed !
  #4
Old 03-22-2007, 01:27 PM
St Louis SHO's Avatar
St Louis SHO St Louis SHO is offline
Rollin' coal
St Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond reputeSt Louis SHO has a reputation beyond repute
Default
EGR stuck open would cause the problems you describe. Did you check the vacuum at the valve to make sure the Sol. isn't stuck open?
James
__________________
00 Trans Am 'vert - LS1, SLP lid, long tubes, 3.73's, 3200 circle D converter, 222/224 cam, 17x9.5 Speedlines, 275/40 Cooper Zeon RS3-A's
04 Cadillac CTS-V - LS6, Cammed, coil over'd, Long tubes, Cat back'd, CAI'd and tuned. - Now with less body damage!
04 Dodge Ram 2500 - CTD - Faster than Most SHO's, and better em pee gee's too!
00 Ford Excursion
I'd say I was here for the whores, but I've been there and done that.
  #5
Old 03-22-2007, 01:37 PM
The Sho Time
Default
I did the suck test and the engine idle did not change ! How do I check the SOl
  #6
Old 03-22-2007, 02:07 PM
Rollin' coal
Default
pull the vacuum hos off of the egr valve and see if it has suction at idle
  #7
Old 03-22-2007, 02:12 PM
The Sho Time
Default
it does not have suction at all at idle
  #8
Old 03-28-2007, 02:18 PM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
Default
Then sounds like the valve itself has debris or something keeping it open. When started cold and letting it idle does the pipe going to the EGR valve get hot?
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
  #9
Old 03-28-2007, 02:59 PM
The Sho Time
Default
I fixed everything. I welded the crank timing gear to the crank set the timing because it was way off.
Car seams to be running really good now...
Thanks for all your help evryone////
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
