SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Suspension, Brake Systems, & Body
Reply
Thread Tools
  #1
Old 09-23-2006, 10:37 AM
rfiltz rfiltz is offline
Registered
rfiltz is on the right road
Default Power Steering Hose Splice
My hoses are leaking badly, 1-pint every 2-3 days! Smokes like crazy when hot. Mechanic said the high pressure hose was leaking and the return hose was swollen and leaking at the fittings.
I've had the hoses running to the cooler spliced with metal tubes. Can I do the same to the high pressure hose? Or is the pressure too high? Shop said the hose alone was like $260! Can these be fabbed up by an AC hose shop or similar?
  #2
Old 09-23-2006, 12:15 PM
projectSHO89 projectSHO89 is offline
SHOless In St L
projectSHO89 is a beacon of lightprojectSHO89 is a beacon of lightprojectSHO89 is a beacon of lightprojectSHO89 is a beacon of lightprojectSHO89 is a beacon of light
Default
The pressure is too high for splicing. Besides, it's usually the fitting the fails, not the hose itself.
Gates makes a replacement hose that are less than that. Replacement is a PITA, though.
You can look them up at http://www.gates.com/part_locator/in...cation_id=3002 since you didn't identify your vehicle completely. If an ATX, it should be 363550 (around $25). If an MTX, it should be a 359370 (around $45).
Return lines can be spliced as the pressure is low enough. The lines themselves are just bulk lines that sell for around a buck/ft at most auroparts stores.
rockauto.com usually has good prices and a 5% discount code if you can wait a couple of days. You will have to search by part number as their application guide may not show these items.
__________________
SHO #1 - 94 ATX aka "Princess". Replaced with a $3000 car back in 2000 before my 16-year-old turned the Princess into one.
SHO #2 - 89 "The Project" Retired at 249K miles to James' place.
SHO # 3 - Another 94 ATX - Daily driver with 238K on it.
  #3
Old 09-27-2006, 04:46 PM
AREA 91's Avatar
AREA 91 AREA 91 is offline
Registered
AREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud ofAREA 91 has much to be proud of
Default
Your local parts store should be able to get you the proper hose.
__________________
Quickest V6 Yamaha on the Forum!!!
WELCOME TO AREA 91
91+ Green Not Stock!
12.74 ET & 114.25MPH
257 WHP All Motor 336 WHP on N20
91 Mocha Frost 210WHP 210WTQ
I am the PA SHO SHOP
  #4
Old 09-29-2006, 03:31 AM
mosho93's Avatar
mosho93 mosho93 is offline
Registered
mosho93 will become famous soon enoughmosho93 will become famous soon enough
Default
The Return lines you can splice if you have to. But for sure not the pressure lines.
__________________
urabuS
  #5
Old 10-01-2006, 07:17 PM
Registered
Default
Thanks, it's 92 MTX. Just bit the bullet and had them replaced. $400 for 2 hoses replaced!
  #6
Old 10-01-2006, 07:31 PM
SASHO91's Avatar
SASHO91 SASHO91 is offline
Zoom Zoom
SASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid oneSASHO91 is a splendid one
Default
FWIW, when I put my AUX. P/S cooler on, i "spliced" the lines. I used barb'd connectors on both sides. I did not have a leak on the return line, however i did have a very small leak on the pressure side. It wasnt too bad... maybe a few drips here and there... but i think the hose was not sitting on the connector correctly.
__________________
Josh
99' Miata- 270whp & 2250lbs... "Fun" covers it.
08' F-150 Crew Cab 5.4 DD
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
