Register |
FAQ |
#1
i have been reading on the forum this morning on how to install electric water temp and electric oil pressure gauges. but i am still confused as to where the best place to tap into the coolent line to get a temp reading. if someone has some insight or a picture of this it would be greatly appreciated.
also where to put that sender for oil press. Thanks -Dan
__________________
![]() 1993 Red/Mocha MTX 2004 STi |
#2
For the water temp sensor, find your stock sensor located to the left of the thermostat. This is where you will need to make a "T" so that you can hook up both sending units.
For the Oil pressure, you need to make a "T" where the stock sensor is. The stock oil pressure sensor is located on the back side of the engine towards the driver's side. That weas a pretty quick rundown, but that's the basics of the install. If you do a little digging useing the search function, you can come up with pictures of both. That's how I found out how too hook mine up 3 years ago! Enjoy you NEW guages, that are actually accurate.
__________________
Quickest V6 Yamaha on the Forum!!! WELCOME TO AREA 91 91+ Green Not Stock! 12.74 ET & 114.25MPH 257 WHP All Motor. 336 WHP on N20, 91 Mocha Frost210WHP 210WTQ, 1967 Chevy Impala, 2 Door Hard Top 1977 Harley Davidson FLH 1965 Chevy II Drag Car |
| Thread Tools | |
If you wish to help keep SHOforum running please click the donation button below
