SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 08-24-2006, 06:32 PM
mishman mishman is offline
Registered
mishman is on the right road
Default crank position sensor
I'm doing a front 60k right now, and was wondering where the best place to buy a CPS was? Autozone has one for $89. I don't want to buy from a dealer because I am trying to save some money. How long do these crank sensors usually last? I was thinking about not replacing it at first, but realized that was a bad idea after seeing how much work it is to get to it.
__________________
95 MTX SHO 112,000
  #2
Old 08-24-2006, 06:56 PM
Minnesho's Avatar
Minnesho Minnesho is offline
i was wrong
Minnesho is infamous around these parts
Default
Quote:
Your doing a front 60k, but might not replace the sensor because its too hard to get to? if you're doing the rest of the 60k already, the sensor is right there man. the only additional thing to do to get to the sensor is pull the crank sprocket.
  #3
Old 08-24-2006, 11:04 PM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
Default
Quote:
You don't even have to do that. Just rotate the crank so that the CPS is aligned with one of the slots in the vane wheel. Use a 1/4" drive with a 1/4" socket and a Phillips head bit to be able to provide enough torque and pressure to remove the two screws that retain the CPS without stripping them.
A trick to help install the new sensor is to drop a length of 2-conductor speaker wire from the top of the intake manifold, on the forward/front side of the fuel rails, down past the water pump (much easier with the pump out for replacement). Now remove the white clip from the sensor connector and tie the speaker wire ends through the slot in the connector. Now carefully pull the connector and cable up through the intake. Slide the white clip back on the connector and attach the connector to the other half of the cable. Rotate the crank back the TDC position before installing the timing belt.
Options to buy? Ther are others (RockAuto.com, NAPA, CarParts.com, etc.). Just shop around.
Wells SU242 AutoZone/AZ.com $56.99
Borg-Warner CSS54 O’Reilly $55.99
__________________
Helping to keep the SHO on the road,
Scott
1991, 433K miles, and rolling...
In-car Track Video: Laps at TWS
  #4
Old 08-25-2006, 12:13 AM
Xs SHO 1's Avatar
Xs SHO 1 Xs SHO 1 is offline
Unknown
Xs SHO 1 is on the right road
Post
If you're going to do all that work, you might as well replace the $7 main front seal, so you will need to remove that crank dampner and sprocket....
  #5
Old 08-25-2006, 02:50 AM
LeddZepp8687's Avatar
LeddZepp8687 LeddZepp8687 is offline
The Keg Rider
LeddZepp8687 will become famous soon enough
Default
:bsflag:
I just bought one from autozone on monday. I just Looked at the reciept. Cost me $60.21, and thats with tax.
I dont know why prices would vary, But I am postive this is what I paid.
__________________
1994 SHO- EH Manifold, BBBs, Magnaflows, Walbro FP, FWI, Taylor wires, Tokicos, Moogs, Brakes, sticky tires, Hi-Stall.
2005 Ford Escape XLT- 3.0 Duratec, 4X4, Flowmaster catback, K&N Intake.
  #6
Old 08-25-2006, 03:46 AM
K-Dawg's Avatar
K-Dawg K-Dawg is offline
Registered
K-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond repute
Default
Yep, I just bought one from Autozone for $56 something plus tax. That reminds me, I need to go pick it up.
__________________
Kelvin
Former SHO Driver
  #7
Old 08-25-2006, 06:41 AM
Endri_SHO's Avatar
Endri_SHO Endri_SHO is offline
SE 300 , S 500
Endri_SHO is on the right road
Default
and also i bought one at the dealer for $ 98 + taxes
__________________
92 Green/Black MTX. (SOLD)
93 White/Black ATX junked GONE :(
93 Black/Green/MTX. SOLD
95 Silver/Gray/MTX, totaled after 2 months :(
93 Silver/Black/MTX
91 Mercedes 190E JUNKED
93 MERCEDES 300SE, BLACK/BLACK :( SOLD
"94 MERCEDES S420 WHITE/BLACK, SNOW FLAKE ( TOTALED)
98 MERCEDES S420 BLACK/BLACK THE BEAST
  #8
Old 08-25-2006, 09:44 AM
SHO Type U SHO Type U is offline
Registered
SHO Type U is on the right road
Default
I've called different AutoZones giving me a wide range of prices from $56 to $100, I went with the one at $56+ tax. Why does the price vary from store to store? They must have classified it wrong.
__________________
'91 Mocha
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
