SHOForum
Go Back   SHOForum > Performance Upgrades - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Suspension, Brakes & Body
Reply
Thread Tools
  #1
Old 04-13-2006, 12:20 AM
NJSHO NJSHO is offline
Clean Your Shorts!
NJSHO is a jewel in the roughNJSHO is a jewel in the roughNJSHO is a jewel in the rough
Default Install Instructions for Cobra Calipers (long)
Ok I sense a general confusion out there about the Cobra Calipers. Too much of the info is spread out. I’m going to attempt to combine it all right here. I have not added any new info just gathered info from the forum and combined it here. None of these pictures are mine.
General Info
There are 2 options with the cobra/mach1 calipers when they are not used with the baer 12.5" kit or the midwest 12" kit:
******Cobra and Mach1/Bullet calipers are exactly the same. Cobra calipers tend to be more expensive because they are usually powder coated or engraved or something*******
1. Run '04 Cobra or Mach 1 Calipers, Unmodified Bracket, 13" Cobra Rotors and 17" rims (16's will not work.) This mod works for both gen 3 and 94/95 knuckles.
On a car with 94/95 knuckles
On a gen 3.
2. Run '04 Cobra Calipers or Mach 1 Calipers, Modified bracket, and 96-99 gen 3 11.6" rotors. This mod works 94/95 and gen 3 knuckles.
On a Gen 2.
Fits under slicers
How to do it
Option 1. 13" Cobra Rotors.
Things you will need:
1. Loaded '04 Cobra or Mach 1 front calipers. Stangstore.com usually has the Mach 1 calipers for around $200 shipped. See Here
2. Banjo Bolt from your current calipers. (Replacements can be had at any store see here)
3. New copper crush washers. (Same as #2 here)
4. Existing Bracket Bolts
5. Cobra Rotors
6. Drill bit slightly larger than wheel stud diameter. (Drill press would be helpful)
Steps.
1. Remove current bracket with caliper attached.
2. Remove current rotor
3. Lay current rotor over cobra rotor and line up the hub holes. Rotate the old rotor until you have meat to drill into. Drill new bolt pattern into rotor. Conversely you could just open the existing holes up to accommodate the different bolt pattern. This can be done because the rotor is hub centric and not lug centric.
See all the holes. This is a 2 piece rotor for the 12.5 baer setup.
4. Install 13" '04 cobra rotor.
5. Install '04 cobra/mach1 caliper bracket. Torque bracket bolts to 85 ft-lbs.
6. Attach caliper (bleed screw up.)
7. Get crush washers ready
8. Remove line from old caliper, throw away old crush washer, put new crush washers on and tighten existing banjo bolt into '04 cobra/mach 1 caliper.
9. Repeat for other side and bleed brakes.
Option 2. 11.6 gen 3 rotors
4. 11.6 gen 3 rotors]
5. Existing Bracket bolts.
6. Angle Grinder
7. Machine Shop help. If you want to do it yourself see the next couple parts
8. Z size drill bit
9. M12x1.75 tap
Steps:
1. First thing to do is to have the bracket modified. There are two was to do this:
A. Mill the bracket flat, move the mounting hole up .7" and grind away some of the knuckle, so that the bracket sits flat when it is bolted on.
Grind Knuckle Here. Also you can see how the bracket is machined flat. The hole is moved up .7", Drilled with a Z sized drill bit, Tapped with a M12x1.75 tap.
Gen3's might have to grind the areas circled in red.
B. Mill the bracket flat, movie the mounting hole up .7" and notch/chamfer the bracket so it clears ears on knuckle pictured in Step A.
I dont know how thick that notch is, so take a guess and see if it works.
The rest of the steps are similar no matter if you notch the bracket or not.
2. Remove current bracket with caliper attached.
3. Remove current rotor
4. Grind Knuckle if applicable (no notched brackets)
5. Install 11.6 rotor
6. Install modified '04 Cobra/Mach1 bracket. Make sure it sits flat and is not put at an angle by the ears of the knuckle. Tighten bracket bolts to 85 ft-lbs.
6. Install '04 Cobra/Mach 1 Calipers with the bleed screws pointing up.
7. Ready new crush washers.
8. Remove line from old caliper and discard crush washers.
9. Put new crush washers on line and attach line with existing banjo bolt to the '04 Cobra/Mach 1 caliper.
10. Repeat on other side and bleed brakes.
The nice thing about the 11.6 setup is that all you need to upgrade to the 13" is some 17's and 13" rotors. Just make a spacer out of some material to put around the original hole and bolt it up.
If you muck up the brackets you can get new ones from fastpartsnetwork.com but they are more than half the price of the loaded calipers from stangstore.com. I cant find the link to them and they are not where you think they would be. As soon as I find it I will post
it.
Edit: Stangstore.com looks dead. I found this link. I have not purchased from them so I have no idea how their service is:
http://www.wakeperformance.com/produ...roducts_id=274
__________________
'91 White/Black
'05 Daytona Blue Performance Edition Z (stock)
"Difficult takes a day, impossible takes a week..." Jayz
The Following 10 Users Say Thank You to NJSHO For This Useful Post:
03cobraSHO (03-22-2009), dohcsable (04-03-2012), Ex3Cutioner8 (03-19-2011), mosho93 (05-04-2011), Northwestvoodoo (06-16-2008), Shoman594 (08-14-2008), SHOmethewayhome (09-03-2009), shonuffmine (11-30-2009), SHOspazz92 (12-26-2011), SHOtime2511 (06-20-2008)
  #2
Old 04-13-2006, 01:11 AM
DDakRT's Avatar
DDakRT DDakRT is offline
Registered
DDakRT is a splendid oneDDakRT is a splendid oneDDakRT is a splendid oneDDakRT is a splendid oneDDakRT is a splendid oneDDakRT is a splendid oneDDakRT is a splendid one
Default
Wow. Vote for sticky!
Thanks you so much for putting that together. It's very much appreciated.
__________________
<{Kris}>
1994 Moonlight Blue / Mocha MTX. Mostly stock, high mileage rust bucket
2005 Acura TL 6-speed
  #3
Old 04-13-2006, 01:12 AM
Sh03d's Avatar
Sh03d Sh03d is offline
Sho Ed
Sh03d is on the right road
Default
Now this is going in my favorites list. Good job!
__________________
89 HD/HC 3.3 MTX ALIVE!
92 Kawasaki Ninja ZXR 600 Sold.
Car-3.3HD/HC, Bizzy'd Trans, BBB, Extrude hone runners, Ported, 155lph pump, Stage 2 SPEC, Gen3 bushings, TPR, Moogs/Tokicos, Y-pipe, Rod shifter, 2.5" exhaust, Police grill, Plus hood and running strong.
On the table-Stage 1 cams, TwEECer.
Sold!
  #4
Old 04-13-2006, 01:22 AM
SinisterSHO's Avatar
SinisterSHO SinisterSHO is online now
Rust free
SinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud ofSinisterSHO has much to be proud of
Default
Some what on topic. Does anyone know if the banjo bolts are the same for the GT calipers as the Mach1/Cobra calipers?
__________________
Steven
1992 SHO Black/Black - no sunroof. Kevin Spann likes this
1995 SHO White/Mocha - track car, long and distinguished mod list
2002 GTP Silver/Charcoal - daily duty
  #5
Old 04-13-2006, 01:30 AM
Shoaz's Avatar
Shoaz Shoaz is offline
Studly dood
Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!Shoaz is brilliant!
Default
Dang, dude, way to make a thorough post...
__________________
Ready for the zombie apocalypse.
  #6
Old 04-13-2006, 01:38 AM
K-Dawg's Avatar
K-Dawg K-Dawg is offline
Registered
K-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond reputeK-Dawg has a reputation beyond repute
Default
Also, they don't have to be a 04 Cobra, any year Cobra will do (I think). And don't forget that the right goes on the left and left goes on the right.
__________________
Kelvin
White 91 MTX
  #7
Old 04-13-2006, 02:09 AM
blue2ndgen blue2ndgen is offline
Registered
blue2ndgen is on the right road
Default
Well Thank You. That takes a load off my mind. Now to find out the cheapest place to buy parts.
__________________
95 MTX
  #8
Old 04-13-2006, 02:41 AM
Registered
Default
whats the difference btween mach 1 and cobra calipers. just the cobra logo? It looks like they are shaped a little different.
  #9
Old 04-13-2006, 08:16 AM
Clean Your Shorts!
Default
The banjo bolts for the 94/95/gen 3 sho/Cobra/Gt calipers all have the same part number.
There is no difference between Cobra and Mach1, except that the Cobra are generally painted or engraved or something. I looked around everywhere and stangstore had the cheapest price. If you want fancy looking calipers try discbrakerus.com. As far as left going right... just make sure the bleed screws are pointing up and your golden.
  #10
Old 04-13-2006, 08:43 AM
zak zak is offline
Registered
zak is a jewel in the roughzak is a jewel in the roughzak is a jewel in the roughzak is a jewel in the rough
Default
Option 2, using 11.6 brake rotors with Cobra calipers, will reduce your front brake swept area to a level less than the stock 94/95 ~ 11.0" inch brake setup. In other words, that option wil result in brakes having poorer fade resistance than Gen 3, or 94/95 front brakes. It was originally designed by Tom to enable mounting of 16 inch drag slicks on a temporary basis, when normally running the 13 inch Cobra front rotors.
  #11
Old 04-13-2006, 09:14 AM
PaulRuffo's Avatar
PaulRuffo PaulRuffo is offline
Registered
PaulRuffo is on the right road
Default
The rotors need to be re-drilled for the taurus bolt pattern? Or is there a place that sells them in the proper pattern a taurus?
__________________
Paul
1994 SHO
2000 BMW M5
  #12
Old 04-13-2006, 09:17 AM
Clean Your Shorts!
Default
There are a larger selection of pads avail. for the cobra calipers to combat fade (ie hawk hp+ and blues.) In addition, the caliper is lighter (half the weight of 95) and made of aluminum which would better disapate heat and lead to less fluid boil.
Why wouldn't a caliper designed for high performance cars (corvettes and cobras) have more swept area than one that isnt (ie. 95 caliper.) Im not trying to be confrontational I would just like to know why.
Seeing as how the reason for going with larger brakes is the greater ability to manage heat and not to cut stopping distance, it doesn't make sense why they would go with a smaller swept area.
Cobra rotors have to be redrilled or just have the holes enlargend. Since the rotor is hubcentric the stud holes dont have to be perfect. I will add that to the instructions
  #13
Old 04-13-2006, 09:41 AM
shomesomesho's Avatar
shomesomesho shomesomesho is offline
G-force addict
shomesomesho is spectacular!shomesomesho is spectacular!shomesomesho is spectacular!
Default
Thanks for the thorough instructions.
I vote this be upgraded to STICKY status!!
__________________
5.0 AutoXer. 510HP, 2750 lb, FTD x 4
Former SHO AutoXer - SHO AutoX Vid
Current - Mustang AutoX Vid
Packwood National Tour - Sat, Sun
  #14
Old 04-13-2006, 09:56 AM
wood_e's Avatar
wood_e wood_e is offline
The dude
wood_e is on the right road
Default
Sticky This!
__________________
John Wood
2007 Ford Focus ZX3 MTX (15k) FOR SALE
1993 Lincoln Mark VIII (127k) - LMS Chip - 99 4r70w w/3000 stall converter & BOC separator kit - CAI - Muffler delete - 1.25" drop Tokicos - Solid 1 3/8" RSB
In progress: 3.73 t-lock
1999 Saab 9-3 (107k) - $750 project...
long ago - 1995 Emerald Green Metallic ATX (147k) *original ATX* SOLD
  #15
Old 04-13-2006, 10:04 AM
Rust free
Default
All the Cobra calipers are the same from 94-04, the Mach 1 calipers are the same, minus the Cobra logo. Also, Bullitt calipers are also the same, but have the running pony logo.
  #16
Old 04-13-2006, 10:54 AM
zak zak is offline
Registered
Default
NJSHO, no flames intended, just trying to educate you in the event that you end up behind me at Lime Rock one day ;-). You are correct, the Cobra caliper is lighter and >might be< stiffer than the 96+ SHO caliper (the later is pin drive, and cast iron, which improves stiffness, but that engineering & material stiffness is offset by a wider pad). It is important to realize what we are talking about is NOT pad area, it is the area that the width of the pad sweeps on the rotor as it rotates. The 96+ Gen 3 SHO pad is 2.1 inches wide, while the Cobra pad is 1.7 inch wide.
When you put a Cobra caliper on a 13 inch rotor, the pad "sweeps" the outside and inside of the rotor, on both front wheels, for a swept area of approximately 238 square inches.
When you move the same Cobra caliper, with its 1.7 inch wide pad, to an 11.6 inch rotor it only has a swept area of about 212 square inches, a 10% decrease.
The stock 11.6 inch rotor and caliper give 251 square inches, or about 5% greater than the Cobra caliper on 13 inch Cobra rotor. Am I saying that these are better than 13 inch Cobra's? No, here the smaller difference in swept area is offset by the thicker Cobra rotor (1.1, vs. 11.6 @ 1.0 inch if memory serves). Also, the cooling vanes inside the Cobra rotors will be rotating faster as the tips are more outboard, pumping air through the rotor at a higher volume than the 11.6. Finally, the 13 inch rotor weighs more, giving it more thermal mass and taking longer to heat up.
Swept area is the overwhelming driver as to how well a brake system avoids fade. It is the rotor that transfers 95% of the heat out, not the caliper or pad as some posted on the temp forum. Don't take my word for it, get Fred Phun's Brake Handbook, or read the posts by a Ford brake engineer (Jeff F) on this thread:
http://www.corner-carvers.com/forums...read.php?t=104
One other nuance of this upgrade I've not seen mentioned yet: the 99+ PBR calipers (Cobra, Bullit, Mach I) use 40.5 mm twin pistons, while older PBRs (94-98 Cobra) use 38 mm pistons. This will effect brake balance, a set of calculations that also need consideration for the 11.6/Cobra caliper combo. IIRC, the 40.5 twin pistons on 13 inch rotor give about the same bias as the 11.6 stock setup, but its been awhile since I did the math on this one.
Just trying to add useful information to this thread - anyones choice for a brake upgrade, that goes beyond the "bling" factor, should consider all the variables.
One more minor note, Hawk Blues are avialable for the 96+ caliper (now that I think about it, same caliper as 94/95, different bracket)
- zak
  #17
Old 04-13-2006, 01:47 PM
K-Dawg's Avatar
Registered
Default
Zak, thanks for including that helpful information.
  #18
Old 04-13-2006, 04:46 PM
ohioshodude's Avatar
ohioshodude ohioshodude is offline
SHO'ld fogy
ohioshodude is awesome!ohioshodude is awesome!ohioshodude is awesome!ohioshodude is awesome!
Default
Quote:
there is a slight difference in calipers from 94-04. the 94-98's have 38mm bore pistons and the 99+ have the larger 40mm bore.
__________________
1995 Boss mustang
1993 red/gray ATX
1991 Mocha/tan
2003 DBP Mercury Marader
2004 F150 red regular cab short bed FX4
  #19
Old 04-13-2006, 06:28 PM
LeddZepp8687's Avatar
LeddZepp8687 LeddZepp8687 is offline
The Keg Rider
LeddZepp8687 will become famous soon enough
Default
Nice write up, I second (or third if somone already secondeded this) a sticky
I will say one thing, Boy do my Mach 1s on 11.6s feel amazing!!
__________________
1994 SHO- EH Manifold, BBBs, Magnaflows, Walbro FP, FWI, Taylor wires, Tokicos, Moogs, Brakes, sticky tires, Hi-Stall.
2005 Ford Escape XLT- 3.0 Duratec, 4X4, Flowmaster catback, K&N Intake.
  #20
Old 04-13-2006, 10:17 PM
ManySHOs's Avatar
ManySHOs ManySHOs is offline
ManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid one
Default
Quote:
40.5mm to nitpick.
Seriously though; I'm waiting for someone to pick up the Brembo calipers from the Cobra R and use them on the 13" rotor. Supposedly all 99+ 13" Ford Mustang rotors are the same (apparently made by Brembo in Italy). i.e., the Brembo 4 pot caliper and the PBR 2 piston use the same rotor. The link that John (zak) posted was really informative.
I've looked into this a few times but I already have the TCE/wilwood setup. I just sent Todd more $$$ to upgrade to forged calipers (41mm pistons IIRC) and a 1.1" 2 piece rotor. I am sticking with a 12.2 rotor so I have the option of running 16's in the future. As-is, the Ford rotors are one piece. However, Todd does have a 2 piece replacement setup that should work nicely with the Ford/brembo caliper for anyone who will never run 16's again. If the brembo caliper can be obtained economically, it might be worth something to look into.
I just rambled, sorry. Brakes get me excited for some reason.
Ian
__________________
93M Tortoise Slow
02M Audi A6 2.7 TT Sport package
Quote:
Originally Posted by Shoaz View Post
Yeah, Hennessey making noise about the SHO is about as exciting as Earl Scheib saying he'll paint one up all special and everything.
  #21
Old 04-14-2006, 12:21 AM
Rust free
Default
The 00 Cobra R calipers are too wide. My friend bolted them onto another car with the standard Cobra upgrade and tried fitting his wheel over it. There was close to an inch gap between the rim and the hub.
  #22
Old 04-14-2006, 03:21 PM
K-Dawg's Avatar
Registered
Default
What kind of wheels did he use?
  #23
Old 04-14-2006, 03:49 PM
Rust free
Default
Some five spoke RS Limited wheels. Not the ones that are alawys on ebay [mase], but those didn't fit either.
  #24
Old 04-14-2006, 05:56 PM
ManySHOs's Avatar
Default
Good info; I figured that they would be a good deal thicker than the PBR's. What type of rim was he using? It probably doesn't matter much as our choice of FWD rims probably won't offer enough clearance for such a huge gap.
EDIT: Maybe not. The MN12 T-bird/SC site showed this upgrade on one of their cars. The car was running Cobra R rims but I don't know if they were the T -bird 5x108 or if it had converted Mustang hubs. I have to check now..
Ian
  #25
Old 04-14-2006, 06:03 PM
ManySHOs's Avatar
Default
Ok, new post, enough editing of the old.
http://www.mn12performance.com/mn12h...ke_upgrade.htm
The car isn't running Cobra style rims. They are ugly though.
It says that the upgrade will work with 5x108 rims. However, the car pictured could have Mustang hubs but those do not look like 'stang rims. Can anyone ID them? They appear to be Ford Motorsport rims of some sort. I'll google them to find out more..
By the way, the info is at the bottom of the page.
EDIT: I suppose they are Mustang bolt pattern (5x 4.5") because one of the pictures shows the rotor mounted and it's not redrilled to 5x108.
Ian
  #26
Old 04-14-2006, 06:15 PM
Rust free
Default
Those are the FR500 wheels that I have only seen available for Mustangs. My guess would be that the RWD car has a different offset for the rims, allowing the wider caliper to fit.
  #27
Old 04-15-2006, 10:32 PM
JEM JEM is offline
Registered
JEM is a jewel in the roughJEM is a jewel in the roughJEM is a jewel in the rough
Default
For what it's worth: a couple of the local Shelby Club guys have very similar Fox Mustangs, one has the Brembo Cobra R setup and one was the prototype for the new Baer C5 'Vette caliper kit.
Both car owners agree that there's no significant difference in feel or performance between them, but the C5 setup has minimal wheel clearance issues and gets considerably better pad life in track use.
Fox/SN95 Mustang wheels are typically a 24mm offset, less than a big SHO wheel; not all will clear the Brembos. The new S197 Mustang uses more offset I think (was looking at a set of aftermarket 18x9s for that car that are 36mm offset) but still 5x4.5BC.
  #28
Old 04-26-2006, 03:53 PM
Rust free
Default
This thread contains good information about the Banjo Bolts for different calipers, including the Cobra/Mach 1/GT.
http://www.shoforum.com/showthread.php?t=59722
Also, I didn't see it mentioned, but my Mach 1 calipers did not come with bracket bolts. I know my 93 bolts wont work, but does anyone know the correct size and/or part number for these?
  #29
Old 04-27-2006, 09:10 PM
matasho's Avatar
matasho matasho is offline
bigshotsho93
matasho is spectacular!matasho is spectacular!matasho is spectacular!
Default
we tried the mase and the other five spoke both were the same offset and the spoke thickness is about the same. if anyone wants the 00 cobra brembos to fit on a SHO they are gonna need a wheel with an offset that will make the wheel/tire stick out past the fender lip about 1''. (not cool) unless a widebody car used them. its just that the brembo caliper is just as wide on both sides of the rotor so some serious spacers will be needed.
  #30
Old 05-07-2006, 03:03 PM
MI-SHOFEAR's Avatar
MI-SHOFEAR MI-SHOFEAR is offline
I'LL SHO YOU
MI-SHOFEAR is on the right road
Default
This is a goos thread
JEff
__________________
________________________________
___________________________________________
94 MTX. STOCK?? HAHAHA!!!
The NEXT Project
More pics of my SHO HERE
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
