SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 02-18-2006, 07:40 AM
95SHOgirl's Avatar
95SHOgirl 95SHOgirl is offline
Registered
95SHOgirl is on the right road
Default Car dies while driving and won't restart
Ok guy's and girls,
My mom's 95 ATX SHO dies while driving down the road. I have to pull the car over to the side of the road and let it sit for 20-30min and she starts back up again. The car will only run for about 5 miles before the same situation happens over again. The car will not start, but cranks, until 20-30min has passed. This sounds like an ignition module, fuel pump or CPS problem. Could I be right?
Thanks
95SHOgirl
__________________
-99 ATX3.4L DOHC SMPI 32-VALVE V8 ENGINE, FX speed mufflers
View pictures of my SHOgirl
  #2
Old 02-18-2006, 09:09 AM
LJRuddy's Avatar
LJRuddy LJRuddy is offline
Pop lock n drop
LJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond repute
Default
Yep... CPS
__________________
96 ATX 245k - A.K.A. The Vomit Comet
  #3
Old 02-18-2006, 11:55 AM
TheMoneyPit-95ATX TheMoneyPit-95ATX is offline
Registered
TheMoneyPit-95ATX is on the right road
Default
CPS no doubt. Been there...done that.
  #4
Old 02-18-2006, 02:04 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Pluggin' away
Rockledge will become famous soon enoughRockledge will become famous soon enough
Default
Pull the codes: http://www.thorssell.net/hbook/eectest.html
__________________
'94 MTX
  #5
Old 02-18-2006, 02:51 PM
SHO_Driver SHO_Driver is offline
Registered
SHO_Driver is on the right road
Default
Quote:
Originally Posted by Rockledge
Agreed. Could be a fuel pump issue as well, so pull the codes.
__________________
1990 Red on Black
217K kms
New Red, Shaved Emblems
Walbro 190 lph
Gen III rear SFB's
Rebuilt MTX
Josh T's 400hp+ flywheel
Discontinued SHONut clutch
Airbox Removed
  #6
Old 02-18-2006, 03:34 PM
kickeralpine kickeralpine is offline
Registered
kickeralpine is on the right road
Default
mine was doing the same and cps was to blame
  #7
Old 02-18-2006, 06:13 PM
SHOtimer's Avatar
SHOtimer SHOtimer is offline
#2910
SHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of lightSHOtimer is a beacon of light
Default
I would imagine that the water pump is leaking onto the CPS causing it to act like that. A educational saturday afternoon and you would be good as new.
Doug
__________________
95 ATX - 261k
95 Lincoln Mark VIII - 144k
90 Dodge Dakota - 102k
99 MBZ 230 Kompressor - 149k
  #8
Old 02-18-2006, 06:36 PM
Gez89SHO Gez89SHO is offline
LEGO SHO
Gez89SHO will become famous soon enough
Default
This might be fuel pump more than CPS, the CPS is a more random failure type. The fact that the car works for 5 miles then stops, then works later only to stop about 5 miles later points more to the problem being the pump. Maybe the fuel pump gets hot, then stops, then after it cools down, the cycle begins again. I would check for fuel pressure.
__________________
Gezim
Former 1989 Currant Red,sold 6/12
2006 M3 aka 3.2 upgrade
my Clutch swap guide
gzim.freeservers.com
  #9
Old 02-18-2006, 07:45 PM
SHOtimer's Avatar
#2910
Default
Quote:
That is what happens to the CPS when the coolant is dripping on it.
Doug
  #10
Old 02-18-2006, 08:12 PM
JATRAMMELL JATRAMMELL is offline
93 Red ATX
JATRAMMELL is on the right road
Default
During my 10+ years of owning my SHO I have three problems that give similar indications:
1. Fuel pump. Mine only happened during hot weather and would result in the 20-30 min shutdown until the fuel pump cooled off. Sad to say I didn't know it was the fuel pump! Car would start but would only spit and spew and would die when put in gear. Burned out my first starter with this problem and probably contributed to the premature death of others.
2. Water pump leaking on CPS. Took Ford 14 days to figure this one out. Fortunately, it was under warranty and they gave me a rental car. Didn't do much for my confidence in their mechanics! Indication was a few drops of coolant on my garage floor. Wouldn't start the next day after sitting overnight. Unless the leak is massive, I don't think the car will usually shutdown while driving; more likely after driving and sitting.
3. Bad CPS. Car shuts down when it takes a notion and will not start; no sputtering or spewing when trying to start.
If your car is sputtering and spewing when you try to start it, I would favor the fuel pump; if not, most likely the CPS.
Good luck.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
