SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 12-31-2005, 08:35 PM
SHOspazz92's Avatar
SHOspazz92 SHOspazz92 is offline
Banned
SHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond repute
Default Stretched throttle cable.
In the recent weeks my SHO has felt a little sluggish, But in a sense that it feels like it has the power, but just not tapping in to it. I was looking around in the engine, and notice my throttle calbe has some slack on it. How much slack is supposed to be on the throttle calbe? Not much I imagin in order for the TB to open up all the way, But I dont really know. What do you think?
-Sam
P.S., Car has its second 60k done, is well maintained, etc etc.
-Sam
__________________
92 3.0 MTX - Autocross prepared - 13.1@107
2013 BRZ Limited - Daily Driver
12 Mazdaspeed 3 - Her Daily Driver / Auto-X toy.
Spending money I don't have, to buy parts I don't need, to impress people I don't know since July of 2002! Welcome to SHOforum.
  #2
Old 12-31-2005, 09:42 PM
jedhead's Avatar
jedhead jedhead is offline
Registered
jedhead is a jewel in the roughjedhead is a jewel in the roughjedhead is a jewel in the rough
Default
Look in the throttle body while someone presses the gas pedal to check to see if you are getting WOT. If you need a throttle cable, you will need to source one from a junk yard.
Bob
__________________
1991 SHO
2006 Cadillac STS-V
2003 Honda Accord EX
1973 Datsun 240Z
SHOCal
Car Domain
  #3
Old 01-01-2006, 01:50 AM
F-22 Raptor SHO's Avatar
F-22 Raptor SHO F-22 Raptor SHO is offline
Moderator
F-22 Raptor SHO is a jewel in the roughF-22 Raptor SHO is a jewel in the roughF-22 Raptor SHO is a jewel in the rough
Default
not likely the junk yard cable will be much better than what you have. I put a couple of spacers behind the gas pedal.
__________________
White 9D1 minus. Silver Award Winner, 16th Annual SHO Convention. Kalamazoo, Michigan 2007
"The armies of heaven were following him (Christ), riding on white horses and dressed in fine linen, white and clean". Revelation 19:14
More Pictures of my ride
Whats that yellow Check Engine Light Mean?
SHO Torque Specs
  #4
Old 01-01-2006, 08:28 AM
Porkchop's Avatar
Porkchop Porkchop is offline
The Black Sheep
Porkchop is on the right road
Default
I know someone who used clamp on fishing weights to take up the slack in his cable. It worked until he found one from a JY to replace it with. Its worth a shot!
__________________
Brian * Grn96Taurus * SHOForum Comedian & Moderator
"The wicked flee when no man pursueth, but the bold are as righteous as a lion"
New: 2006 Black/Black Pontiac Grand Prix GXP LS4 - Magnaflow SS catback, DDM 5000k Headlight & Foglight HID's
EX's: 1998 SHO - Roush, Flowmasters...the works
1996 GL - Roush, SHO mufflers... the half works
  #5
Old 01-01-2006, 10:23 AM
jelloslug's Avatar
jelloslug jelloslug is offline
Digital
jelloslug is a beacon of lightjelloslug is a beacon of lightjelloslug is a beacon of lightjelloslug is a beacon of lightjelloslug is a beacon of light
Default
Make sure your gas pedal are is not bent, that's what was wrong with mine.
__________________
1990 SHO
A few mods: 3.2 conversion, High flow y-pipe, Quaifed tranny, SHOrt shifter, TPR bushings, H-brace, adjustable rear control arms. It's getting better!
Check out how nasty my SHO was when I got it!
New interior! Not so nasty now!
New and improved! Now with 100% more blue!
Want to install a digital cluster in your car?
  #6
Old 01-02-2006, 08:44 PM
Porkchop's Avatar
The Black Sheep
Default
Quote:
Pushing down too hard again huh
  #7
Old 01-03-2006, 03:34 PM
kevingotashotoo's Avatar
kevingotashotoo kevingotashotoo is offline
200 or so ponies
kevingotashotoo is on the right road
Default
i just found out i have the same problem,this might be contributing to my topend loss of power over 4000 rpm
  #8
Old 01-03-2006, 04:04 PM
laxmax327 laxmax327 is offline
Registered
laxmax327 is on the right road
Default
its not hard, just take a look inside the throttle body, the butterfly should be opening up completely under wot. if not then either your pedal or the cable is messed up.
  #9
Old 01-03-2006, 04:16 PM
LOUDSHO92's Avatar
LOUDSHO92 LOUDSHO92 is offline
SHOForum Sponsor
LOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud ofLOUDSHO92 has much to be proud of
Cool
I got mine from the junk yard and it was much better.
They changed them for 93-95. The 92 are the same as Gen1s.
__________________
92 White SHO
-Performance: Turbo 297hp 279ftlb
-Drivetrain: CM Clutch,SHONut Mounts,QUAIFE
-Suspension: SS Coilovers, 24/26mm,Poly,Gen3,H-Brace, Subframe
-Brakes: Cobra front, 11.6 rear
-Looks: Sound System,Speedhut,Pilot Fogs,Clear Corners,Gen2 Console, CF Cowl Hood & Trunk
SHO Source
  #10
Old 01-03-2006, 11:54 PM
SHO92's Avatar
SHO92 SHO92 is offline
Registered
SHO92 will become famous soon enoughSHO92 will become famous soon enough
Default
The cable should have some slack on it if you push it down with your finger where it meets the TB. Since the only sping in the system is at the TB itself, when you push on the cable anywhere else, you will just be pushing on a slack cable.
As others have said, the only way to tell is to look at the throttle blade while someone else pushes the pedal to the floor.
__________________
Bill Murray
'93 Oxford White - weekend driver/track slut
'06 Nighthawk Black Pearl RSX Type-S - daily corner carver (and apparently a track prep'd SHO eater ;)
Cardomain Page
  #11
Old 01-06-2006, 01:03 PM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
Default
There are universal cables here. This may help.
http://www.lokar.com/index.htm
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
