SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 12-28-2005, 11:25 AM
LookAtThatSHO's Avatar
LookAtThatSHO LookAtThatSHO is offline
Who's SHO Daddy
LookAtThatSHO is on the right road
Default Low Coolant Light's On
I've checked the coolant level, seems fine. My 94MTX had the same problem, but the result was a crack on the top of the coolant reservoir. I see no visible cracks in this one though? Is there something else that would trigger the light to come on? Maybe its time to flush the radiator?
__________________
1995 White/Mocha MTX: 188k
CURRENTLY FOR SALE
Mods: SHO Shop Catted Y-Pipe, Dynomax SuperTurbo Cat-Back Exhaust, Mark VIII 80mm MAF, LPM Chip, P&P Intake, BBBs, Rear Strut Tower Brace, Silencer Cone Removed, Coolant/TB Bypass, KYB Struts
1993 Black/Black MTX: 124k
Mods: K&N Air Filter
MySpace
AIM: LookAtThatSHO
  #2
Old 12-28-2005, 04:35 PM
MelectroK's Avatar
MelectroK MelectroK is offline
Registered
MelectroK is on the right road
Default
Pull it out and clean it anyways, Mine didnt look dirty but I cleaned and havent had a false warning yet.
__________________
1995 MTX Emerald/Mocha
1996 SVT Cobra Stang Laser Red/Mocha & Black
  #3
Old 12-28-2005, 06:21 PM
Randall's Avatar
Randall Randall is offline
Registered
Randall is on the right road
Default
I can also tell you that my light stopped coming on when I cleaned the two electrodes with a wire brush.
__________________
'68 Mustang GT, an ALL aluminum 351w, heavily modded AOD, axle, brakes, & frame, 11.0 second e.t.'s
'92 SHO MTX wh/bl, 186,000, '96 brakes, Eibachs & GR-2's, relayed lighting, 3.2 swap w/ 3.0 cams, rear headrests, TSW hockenheims, SHOShop catless Y, custom welded exhaust, lots of electrical mods
WOW, I need to update these pics, I am down to two cars now!
  #4
Old 01-10-2006, 11:39 AM
Who's SHO Daddy
Default
Well, I found the culprit as to what was causing the low coolant light to be triggered. A couple of downshifts into third at about 60 on a Friday night blew the radiator completely. $300 but won't have to worry about the coolant system for quite some time! It's funny though, how the shop I brought it to just 'happened' to have an SHO radiator on backorder from a previous customer who had never came to pick it up! And this is in the wayyyy backcountry of upstate NY!
  #5
Old 01-10-2006, 11:45 AM
HoustinoJillian's Avatar
HoustinoJillian HoustinoJillian is offline
name's JUSTIN
HoustinoJillian is a jewel in the roughHoustinoJillian is a jewel in the roughHoustinoJillian is a jewel in the rough
Default
i dont see how you could have checked the coolant level and it was fine? the sensor's in the overflow reservoir, if your readiator was leaking the reservoir would have been low/empty and the sensor dry. if it was submerged, and you were still getting the light, its a separate problem than the radiator blowing out. in that case you should probably still clean the sensor.
__________________
2007 Magnetic Grey Prius Package #5, purchased 2/25/09
LED tails thread
Past:
titanium 89- 193K, stock RIP 8/03
white 95 MTX- 143K, stock SOLD 6/4/05
moonlight blue 95 3.2MTX ~116K, not stock SOLD 1/23/09
  #6
Old 01-10-2006, 12:54 PM
ManySHOs's Avatar
ManySHOs ManySHOs is offline
ManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid oneManySHOs is a splendid one
Default
Quote:
Huh? Since when did downshifting blow out radiators?
Ian
__________________
93M Tortoise Slow
02M Audi A6 2.7 TT Sport package
Quote:
Originally Posted by Shoaz View Post
Yeah, Hennessey making noise about the SHO is about as exciting as Earl Scheib saying he'll paint one up all special and everything.
  #7
Old 01-10-2006, 01:16 PM
laxmax327 laxmax327 is offline
Registered
laxmax327 is on the right road
Default
lol, i was thinking the same exact thing...
  #8
Old 01-10-2006, 02:07 PM
Sh03d's Avatar
Sh03d Sh03d is offline
Sho Ed
Sh03d is on the right road
Default
Clogged and water pump going at 7000+ rpms forced to much coolant in and ka boom?
__________________
89 HD/HC 3.3 MTX ALIVE!
92 Kawasaki Ninja ZXR 600 Sold.
Car-3.3HD/HC, Bizzy'd Trans, BBB, Extrude hone runners, Ported, 155lph pump, Stage 2 SPEC, Gen3 bushings, TPR, Moogs/Tokicos, Y-pipe, Rod shifter, 2.5" exhaust, Police grill, Plus hood and running strong.
On the table-Stage 1 cams, TwEECer.
Sold!
  #9
Old 01-10-2006, 03:17 PM
name's JUSTIN
Default
not to hijack/ be off topic, just in case this turns up in a search - i had a low coolant problem that was NOT the radiator, turnes out the reservoir tank was cracked. fixed that and STILL had a leak. turns out when the tank was replaced, one of the hoses got a small leak, only showed up when the system was pressurized, and wasn't enough to cause puddling at all. now thats all buttoned up, and hopefully all is well and good.
theres 3 ways to check for a coolant leak that i know of:.
1. visual, pretty obvious, if youve got leaks/drips/puddles you know where they're coming from.
2. a UV dye kit, an additive to the coolant that does nothing to internals, but will show up under UV light to pinpoint a small leak or vapor leak that doesn't cause visible condensation or dripping
3. pressurize the system. couldnt get my hands on #2, and #1 didnt work, so i had to have it pressurized. worked right away.
hope that helped/ will hep someone in the future
  #10
Old 01-10-2006, 03:48 PM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
Default
The SHO uses the same radiator as the regular Taurus. It should run you no more than about $150.
__________________
Helping to keep the SHO on the road,
Scott
1991, 430K miles, and rolling...
In-car Track Video: Laps at TWS
  #11
Old 01-12-2006, 09:29 AM
Who's SHO Daddy
Default
Justin, I believed the coolant level was alright after adding coolant directly to the radiator until it was full. I wasn't aware that not having any coolant in the reservoir would trigger the sensor. I know now, and as of replacing the new radiator, there's definitely coolant in the reservoir
Scott, the regular Taurii radiators can be installed in the SHOs. But there are a few extra holes that need to be plugged in order for everything to work (atleast this is what the shop told me). The total cost was $140 for the radiator, $25 for the coolant, and $110 for two hours of labor. I would have easily done the job myself, but I didn't have access to a garage and it has been nearly 20 degrees outside here fore the past month.
  #12
Old 01-12-2006, 10:11 AM
name's JUSTIN
Default
ah cool, sounds like you've gotten everything more than squared away. doesnt look like you got screwed too bad for the labor, i've never heard the line about extra holes to fill up, however.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
