SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Suspension, Brake Systems, & Body
Reply
Thread Tools
  #1
Old 05-28-2002, 12:38 AM
jcostantino jcostantino is offline
Registered
jcostantino is on the right road
Rebuild brake proportioning valve?
I have a sticking brake bias valve, is it possible to rebuild it? I believe the pins are frozen into the valve itself.
Jeff
__________________
1995 ATX - In Now: Braided Brake Lines, Lo-Tek Triple Gauge Pod with Water temp, Oil Pres and Volts, GM Front Strut Tower Brace, Coneless, K&N Panel Filter, / Coming Soon: Subframe Connectors, Subframe Bushings, 96 Brake Upgrade / Eventually: Koni's and Intrax's / New Parts: Thermostat, ATX Rebuild, TPS (1999), CKP, CPS, Fuel Pump, ICM, Plug Well Gaskets, Plugs & Wires, Battery Cables, Battery (2001), Heads Leak Tested, Head Gaskets, Radiator, Thermostat, Timing Belt, ICM (Stolen) (2002)
  #2
Old 05-28-2002, 11:33 PM
RStalveyARFF RStalveyARFF is offline
too many shos
RStalveyARFF will become famous soon enoughRStalveyARFF will become famous soon enough
you can get new valves I believe. They screw into the proportioning valve block. Either that or go junkyard shopping. Any taurus has the valves.
__________________
1991 White/Mocha 3.2 & N2O
1991 Green/Mocha + 3.2 (1 of 95)
1994 MTX Green/Mocha
1997 Ebony Satin/Gray
2000 Suzuki GSX-R 750
2003 Yamaha RX-1
2004 F350 Lariat PSD A5
2010 Polaris Sportsman 550
  #3
Old 05-29-2002, 11:55 AM
Registered
I'll see if I can find a used valve around town here... I guess that I'd just need to clean it up real good and replace the o-rings..
Jeff
  #4
Old 05-31-2002, 08:33 AM
Bizzy's Avatar
Bizzy Bizzy is offline
Dragon Leader
Bizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond reputeBizzy has a reputation beyond repute
Quote:
jcostantino:
Jeff
Firstly, I wouldn't buy a used one. They're only about $80 from Ford Parts Network new. You'll play hell in getting one that isn't rusted all to crap unless it's from a southern kept car.
Secondly, there was a federal law passed that stipulates that it's illegal for a bone yard to sell them used. It's a safety issue.
If you really insist on getting a used one, I've got one you can have for parts or whatever. Just email me your addy. The outer connecting rod and bracket are pretty much toast, but the valve itself is good.
__________________
(. (. Biz*(;*
Official SHOForum Wet Blanket and Killer of Naughty Threads
Life isn't ups and downs, hills and valleys, but rather 2 railroad rails running parallel -- There's always something GOOD in your life and always something BAD in your life -- Something to ask God for help with, something to praise & give thanks to Him for.
  #5
Old 05-09-2003, 01:26 AM
pete c pete c is offline
Registered
pete c is on the right road
I took my proportioning valve apart today. One side seems to work fine. With the valve screwed all the way in you can depress the plunger maybe a sixteenth of an inch. When this is done the flow, using compressed air, is greatly increased. The other side does not move more than a few thousandths when screwed all the way in and flow increase is negligible. The problem is with the valve, not the body, sonce it works the same, either side.
I inspected each valve and found that with the good one, the aluminum piece at the end slides with respect to the sleel sleeve with the 2 holes. This movement appears to be what allows fluid flow. With the bad one, there is no similar movement.
I worked it around with carb cleaner and brake cleaner, but there appears to be no improvement.
I stopped by the local ford dealer and he says the prop. valve is no longer available.
I will take a look at ford parts network.
Any of you guys out there that have installed plugs wanna part with your valves? If so, PM me please.
Thanks,
Pete
__________________
Fugly black 93 MTX. In the process of installing kybs/moog coils.
  #6
Old 05-09-2003, 10:39 AM
Don89SHO Don89SHO is offline
Registered
Don89SHO is on the right road
I replaced mine on Monday along with the brake line. My brothers discount from the Lincoln Dealership he works at made it $60. I replaced the rotor (down to rivets)and caliper the week before cause the drivers rear brake was not releasing cuss . His attempt to "fix" the proportioning valve (wacking the pistons w/a mallet to unfreeze them) didn't work. My advise, Bizzys absolutely right, just replace it; Cheap, Available and the same amount of work. Besides, its your brakes, if one thing needs to work right on your car, its them.
<small>[ May 09, 2003, 10:42 AM: Message edited by: Don89SHO ]</small>
__________________
1989, K&N filter, 2.5" CATBack, 9.75" SouthBend Ralley Clutch & Fidanza Flywheel Combo
  #7
Old 05-09-2003, 11:41 AM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
It can be eliminated by flaring the ends of the brake lines and inserting a coupler. Do not do this if there is no ABS.
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
  #8
Old 05-09-2003, 02:48 PM
NorthernSHO NorthernSHO is offline
Registered
NorthernSHO is on the right road
Quote:
SHOZ123:
My thoughts exactly. I had mine removed about two months ago as mine was good and frozen and had my friend Thomas cut it out and insert a coupler. No more proportioning valve and no more worries. The car stops just as well if not better than it ever has. thumb
__________________
1994 Red ATX
Rebuilt Tranny with Transgo
Full 60k complete Sept 2002
Ran 15.51 @ 92mph the day before the tranny went...doh!
Dynoed 181hp & 178lb. ft. torque stock
Upgrades:
Tinted 15% all around
80mm MAF with Ted B. LPM
96 Brake Upgrade with Removed Brake Bias Valve
155lph Walbro Fuel Pump
Removed Fender Box with K&N Panel Filter
Summit Turbo Mufflers and Tips
Full Length SFCs
Winter Project: 1994 Mazda Miata with Mustang 5.0L V8 and T5
  #9
Old 05-10-2003, 11:34 AM
djsSHO's Avatar
djsSHO djsSHO is offline
Ford Nut
djsSHO is on the right road
Does anyone have the part # so when I go to the dealer I don't have to deal with a blank stare if the counterhelp is less than informed?
TIA!
__________________
Derek S.
'10 SHO Atlantis Green
'94 MTX SHO 131K
'94 ATX SHO 130K
'06 Mustang GT 6K
'03 24V Taurus 83K
'93 ATX SHO 147k - Gone
'03 Sonic Blue SVT Focus 14k - Gone
  #10
Old 05-10-2003, 12:18 PM
Ishodu's Avatar
Ishodu Ishodu is offline
Moderator
Ishodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid one
E6DZ-2B547-A
Is what Josh has for Sale at Shonutpreformance
<small>[ May 10, 2003, 12:19 PM: Message edited by: ishodu ]</small>
__________________
95 MTX
2011 SHO Convention Best of SHOw and Best Engine and SHOw and Go winner.
3.2 High Comp forged pistons and Custom Cams plus more.
312hp 266tq
Drag Vid
Carbon Fiber or Fiberglass hood with out latch reinforcement or hood pins you and your family could be on borrowed time!
  #11
Old 05-12-2003, 11:23 AM
djsSHO's Avatar
Ford Nut
Thank you very much!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
