SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 12-01-2012, 06:16 PM
iSpyder iSpyder is offline
Registered
iSpyder is on the right road
Default Crankshaft Position Sensor help
What I thought would be a simple job of replacing the crankshaft position sensor has turned into a huge headache. I can't get the single bolt holding it to the block removed and I think it may be rounded off fairly good at this point. Anyone had this problem or have any suggestions on how I can get this bolt removed? There is much room in there but I was thinking about loosening the subframe bolts on that side to try and gain some additional room to hammer on a smaller socket. Anyone ever tried this on the CKP sensor before?
__________________
Erik Johnson
Current:
1989 Currant Red
1997 Mitsubishi Eclipse Spyder GST
1999 Vibrant White SHO - Welded, Gen II ATX Cooler, Eibach's w/ Gen IV struts, Gen III RSFB's, Borla exhaust
2004 Audi S4 6SP
Prior:
1991 Oxford White SHO+ (R.I.P)
2001 Audi S4 (stolen, recovered, rebuilt and now living in sunny CA)
  #2
Old 12-01-2012, 07:07 PM
Irish Pride's Avatar
Irish Pride Irish Pride is offline
Irish Inside
Irish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond repute
Default
Sorry, i didnt see what section this was posted in. I know nothing about the V8s.
__________________
South East SHO Club
SESHO Decals
1991 SHO + - White/Black. Fully Modded.
1989 SHO - 1 of 318 in White. 3.3 HC, Ported Heads, Tri-Flows, BBBs, EH Runners. New restoration project.
The following user says thank you to Irish Pride for this post:
iSpyder (12-01-2012)
  #3
Old 12-01-2012, 07:38 PM
kevinspann's Avatar
kevinspann kevinspann is offline
87 Octane
kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!
Default
Good luck. The bolt also has a tendency to break off, so be aware of that.
__________________
15s in 2015
  #4
Old 12-02-2012, 08:55 PM
Registered
Default
Still no luck getting this bolt off. Tried cutting a groove into the head to then use a flat head screwdriver but it still isn't moving.
Quote:
Is this speaking from experience? If so how did you go about fixing the problem after this happened? This bolt doesn't want to budge and if it does I have a feeling I could be in store for the same problem.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
