SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Electronics & Audio
Reply
Thread Tools
  #1
Old 08-05-2012, 02:26 AM
SHOGUN1989 SHOGUN1989 is offline
Registered
SHOGUN1989 is unknown at this point
Unhappy Car shuts off while driving
My 1989 SHO shut off on me while driving at 50 miles an hour. The check engine light came on and it would not turn over when I tried to restart it. It restarted after 50 mins. I had in the shop for two days and diagnostics came up with nothing. Has anyone had this problem and if so what could be done for a fix.
  #2
Old 08-05-2012, 11:02 AM
mrecoolgar's Avatar
mrecoolgar mrecoolgar is offline
SHO NUP
mrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to all
Default
CPS - crank position sensor.
Your described symptoms indicate cps failure.
__________________
Current Rides
SHOs: 1989 Currant Red-Titanium, 1989 Titanium-Titanium, 1989 Oxford White-Titanium, 1990 Electric Red-Sandlewood, 1991 Deep Jewel Green-Mocha, 1996 Rose Mist-Graphite
Others: 1968 Cougar XR7, 1988 Mazda RX7 Vert, 1989 Cougar XR7 SC, 1995 Contour SE My Lil-Sho, 1997 Ranger XLT, 2005 F150 King Ranch 4WD
  #3
Old 08-05-2012, 01:36 PM
someguy35's Avatar
someguy35 someguy35 is offline
Sci-Fi nut
someguy35 will become famous soon enough
Default
This is exactly it. I had the same thing happen to my 93. Battery and all electrical worked, just wouldn't fully turn over.
__________________
Owned: 1993 White Taurus SHO ATX. Currently own: 2005 Silver VW Jetta 2.5
  #4
Old 08-05-2012, 02:04 PM
Registered
Default
Thank you mrecoolgar and someguy35. Can I get the part now at a regular ford dealer? or do I have to special order the part through after market SHO stores? Thanks again guys!!
  #5
Old 08-05-2012, 04:44 PM
93markVIII 93markVIII is offline
Registered
93markVIII will become famous soon enough
Default
the CPS isn't SHO specific. we pulled one of an 89 cougar xr7 the other day.
oreillys, advance, and autozone all have them on their website.
ford part number: E9SZ12A112A
tascaparts.com still lists it as available.
__________________
1996 Lincoln Mark VIII LSC
191k miles, Cobra wheels and brakes.
1993 Lincoln Mark VIII
204k miles, still on air
1969 Mercury Cougar
The following user says thank you to 93markVIII for this post:
someguy35 (08-05-2012)
  #6
Old 08-05-2012, 05:38 PM
SHOdded SHOdded is offline
Registered
SHOdded is a jewel in the roughSHOdded is a jewel in the roughSHOdded is a jewel in the roughSHOdded is a jewel in the rough
Default
Make sure the water pump hasn't leaked out all over the sensor, causing the failure. It is common to do both water pump and sensor if water pump has not been replaced in quite a while, just because you have everything apart already.
  #7
Old 08-05-2012, 10:46 PM
snowwind1990 snowwind1990 is offline
Registered
snowwind1990 is on the right road
Default
now now remember my 1989 on the trip to Cal. did the same thing and it was the fuel filter.......then it did it again and it was the ethanol and warm temps that caused the stall and wait for reset.......26 times in 136 miles.......
Marlene and Snowwind1990
This too was the early failure of the water pump...........ouch,
__________________
1st SHO...1989 Currant Red "Carmen"
2nd SHO 1992 Royal Blue "Pretty Boy"
SOLD/SAVED by Imaperson "Bart" 1991 Blackin/Blackout @223 K....modded
"Snowwind" 1990 White @320K
"Lucille"SOLD 6/17/02 to Gil Shoemaker,now owned by Mike Murphy
SOLD to Imaperson"TUX" full name "Nippon Tucks" 1989 Black/Grey Full Leather Factory Stock Fully Loaded @181K
Last edited by snowwind1990; 08-17-2012 at 07:41 PM. Reason: I had to correct my error
  #8
Old 08-07-2012, 05:40 PM
RonPorter's Avatar
RonPorter RonPorter is offline
Old Dude
RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!RonPorter is brilliant!
Default
Sounds like the typical CPS. AFAIK, I was the first to get this back in '90, and not even the Ford dealer figured it out......until ALL the other ignition parts were replaced!!
I was ready to torch the car at that point!!
__________________
Past: New '89, New '99, '95 & '94 MTX, White '89
Now: '89 SHO, Currant Red, 10K miles, all stock "The Garage Queen"
2003 Focus SVT 116K miles
2006 Grand Prix 17K miles (wife's car)
2002 Grand Marquis 122K miles (work mule)
  #9
Old 08-17-2012, 07:39 PM
Registered
Wink Apology
Indeed, indeed,....the water pump is a culprit to be reckoned with. Tux has been subjected to the awful spew and stumble legacy of the leaking pump that fouls the CPS sensor temporarily. The heat dries the sensor, then you are good to go.. No fuel related delivery this time. I humbly submit I diagnosed incorrectly and stand before you wrong. I have never been subjected to this well know failure of the h2o pump in 23 years of SHOownership............I feel your pain.
drip.
drip.
drip.
  #10
Old 08-19-2012, 05:55 PM
RonPorter's Avatar
Old Dude
Default
Personally, I don't buy the "water pump leaking" theory.
The unit is sealed. I had the water pump done at a 60K YEARS after the first CPS died, and the WP they pulled out still wasn't leaking. But I had it replaced anyway.
  #11
Old 08-21-2012, 06:05 PM
Registered
Default
Well guys, I've changed the CPS and the Fuel Filter and after a few days of running great the car started to do the same. It stalled for a few seconds while I was driving at 65 mph with the check engine light and then started back while still driving. This is driving me nuts. The water pump is not leaking and the car otherwise runs great. What do you guys think I should try next? I've had my 89 SHO for 20 years and she's been a reliable beast to me all these years. Thank you guys for all your help!!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
