SHOForum
Go Back   SHOForum > Generation 4 SHO (2010) > Generation 4 - General Discusson
Reply
Thread Tools
  #1
Old 06-12-2012, 08:16 AM
skidooinfront skidooinfront is offline
skidoo07
skidooinfront is unknown at this point
Default Dash, Jack Roush
I have the opportunity to get my car signed by Jack Roush, And they need the panel that covers the passenger air bag. Does anyone know how to remove and replace this cover at all. Thanks
  #2
Old 06-12-2012, 07:27 PM
EcoBrick Bob EcoBrick Bob is offline
Registered
EcoBrick Bob is spectacular!EcoBrick Bob is spectacular!EcoBrick Bob is spectacular!
Default
There is one sure fire way.... but I don't think you want to go there....LOL
__________________
2010 Red Candy/White EB Flex - WORLD'S FIRST 12 SECOND FLEX 12.901@106.85 MPH TORRIE TUNED
2009 Spt Red G8 GT - Headers, Cam, Wide-band TORRIE TUNED 12.078 ET @ 114.02 mph
2008 White G8 GT - Tune, Headers, CAI - 8.32ET 1/8 mi@85.66 MPH
2004 GTO - 12K Y 6 spd Sold to son - also has 04' R GTO - 55K
Son#2 - 09' G8 GT & 05' Tuned Subaru Frstr Turbo
93 SHO - Red Auto, 91 SHO - Black, 90 SHO - White, 89 SHO - Black - ALL sold
  #3
Old 06-13-2012, 07:49 AM
SHOrod's Avatar
SHOrod SHOrod is online now
Torrie Tuned
SHOrod will become famous soon enough
Default
How soon do you need the panel? It might make more sense to buy a new panel and send that in for the signature, then swap the panels at a later date. I'm not sure if many dealers would stock this item, but they can probably get them within a day or two.
-Rod
  #4
Old 06-13-2012, 08:10 AM
SHOrod's Avatar
Torrie Tuned
Default
I just checked my service manual. Below are the steps to remove the panel.
-Rod
Instrument Panel Finish Panel — RH
Removal and Installation
NOTICE: When prying on a component, a non-marring tool must be used or damage to the component may occur.
NOTICE: The RH instrument panel finish panel must be removed in the following sequence, failure to may cause damage to the RH instrument panel finish panel.
  1. Remove the RH instrument panel finish panel in the following sequence.
    1. With a non-marring tool, pry the lower LH corner of the RH instrument panel finish panel toward the rear of the vehicle to release the retaining clip.
    2. Continue to release the next lower retaining clip, followed by the others prying toward the rear of the vehicle.
    3. Release the additional upper retaining clips, starting with a corner and continuing to release the next upper retaining clip, followed the others by prying toward the rear of the vehicle.
  2. To install, reverse the removal procedure.
    1. To install, make sure to align the trim panel retaining clips to the retaining clip holes in the instrument panel.
  #5
Old 06-13-2012, 10:05 AM
DJSHO91's Avatar
DJSHO91 DJSHO91 is offline
Registered
DJSHO91 is a splendid oneDJSHO91 is a splendid oneDJSHO91 is a splendid oneDJSHO91 is a splendid oneDJSHO91 is a splendid oneDJSHO91 is a splendid oneDJSHO91 is a splendid one
Default
Quote:
-Rod
I would suggest following Rod's idea. It is not a smart idea to drive a vehicle without the airbag cover, and it may take a while to get the cover back.
__________________
D.J. Martin III
Hillsborough,NC
91'SHO-Over 230,000 miles & running strong!
2007 Mercury Milan Premier I4(wife's car)
Daily Encouraging Word
TSHOC is now on Facebook!
  #6
Old 06-13-2012, 03:01 PM
skidoo07
Default
Sweet, thanks guys. Going to find out when my buddy can take it and how long. He said he will check when he'll be in. And ill give him the panel the day before to take in. I wont drive the car till I get it back.
  #7
Old 06-16-2012, 09:57 AM
2ndSHO's Avatar
2ndSHO 2ndSHO is offline
Car Addict
2ndSHO is unknown at this point
Default
SHOrod:
have you come across the excellant instructions
http://www.shoforum.com/showthread.p...light=lockpick
for removing the panels and installing the Lockpick? If you could take the trouble to post the panel removal techniques necessary to follow the lockpick instructions without panel damage then I will be forever in your debt. Alternately, please post the part number of the book you used to produce the above drawing and instructions.
Thanks in advance!
__________________
Former SHO was '92 (had it >200k miles)
Current SHO is 2011, Black, lots of stuff, more fun than a human ought to have.
Current hobbies:
TR4 with head mods, cam and Webers (performance not bad for an LBC).
FF5 cobra replica: 392 Windsor, Dart Heads, enough power to keep me focused.
Last edited by 2ndSHO; 06-16-2012 at 10:01 AM. Reason: added hyperlink for installation instructions
  #8
Old 06-16-2012, 12:27 PM
Registered
Default
To remove panels, you need non-metal interior removal tools, especially the plastic knife looking blade. Everything is just clipped in or attached with screws (that are very visible).
It took me about an hour and 1/2 from start to finish to install Coastal Lock Pick in my Flex, being extremely careful. If I were doing these daily, I would guess it could be done in around 30 minutes.
  #9
Old 06-18-2012, 11:56 AM
2ndSHO's Avatar
Car Addict
Default
Thanks EcoBrick!
I'm one of those guys that has a bad history with snap catches, but I guess if I'm careful I won't break anything.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
