SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 09-26-2002, 08:24 PM
Mike92Silver Mike92Silver is offline
Registered
Mike92Silver is on the right road
Gas Pedal to close to floor!
hey guys, basically my gas pedal is freaking like 3 inches off the floor, it opens WOT, but barely, but its much farther down than the other pedals, its def not normal, im not sure if the cable is too short or what, but how do u fix this? so that the pedal is higher? it gives flooring a whole new meaning!!!!! it really sucks, any ideas?
<small>[ September 26, 2002, 08:25 PM: Message edited by: Mike92Silver ]</small>
__________________
Mike
92 modded Silver SHO
  #2
Old 09-26-2002, 09:03 PM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
Check to see that the pedal shaft is not bent and allowing slack in the cable. At rest, the upper end of the pedal's arm is seated against the cable end. The only way to change the relation of the pedal is by bending the shaft or the pivot pin or its mounts.
__________________
Helping to keep the SHO on the road,
Scott
1991, 433K miles, and rolling...
In-car Track Video: Laps at TWS
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
