SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 03-23-2012, 01:06 PM
green94mtx green94mtx is offline
Registered
green94mtx is unknown at this point
Default 94 mtx hesitation/lugging/cutting out below 4k
I did a search and couldn't find much, When i'm accelerating, it cuts out/lugs/hesitates mostly from 2500-3500 rpm. WHat could this be? Doesn't matter if i'm 1/2 throttle or WOT. Doesn't seem to happen below 1/2 throttle though (light acceleration). New crank sensor, new plugs, new intake & TB gaskets. Tried another used MAF and that didn't do anything, i cleaned it very throughly too. Any info would be greatly appreciated. Thanks
  #2
Old 03-23-2012, 02:07 PM
rubydist rubydist is offline
Registered
rubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud of
Default
pull the codes first.
my guess is that the tps is bad, but you need to pull the codes rather than guess.
__________________
96 Pearl White Mark VIII 4.6 dohc
90 Red RX-7 convertible project.....
96 White w/ Grey F250 4x4 OffRoad extended cab
98 Green Mountaineer awd 5.0 - for sale!
03 Tan Subaru Outback 3.0
former SHOs include 94 re atx, 94 wh atx x2, 93 gr atx, 94 bl mtx, 97 bk, 98 bk, 95 gr atx->mtx, 93 bl mtx, 93 bl atx, 95 bl atx, 95 gr atx, 92 wh mtx
  #3
Old 03-23-2012, 02:51 PM
Registered
Default
Will do. I will let you know what i find. No CE light, but it's worth a try!
  #4
Old 03-23-2012, 02:57 PM
itwonder itwonder is offline
Registered
itwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid one
Default
KOEO and KOER tests. Pull codes.
__________________
Bob
1992 Black/Black
Original Owner - 245K
Squashed by falling tree, fate TBD
  #5
Old 03-23-2012, 03:05 PM
Vnuk1's Avatar
Vnuk1 Vnuk1 is offline
Mr. Mayhem
Vnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond reputeVnuk1 has a reputation beyond repute
Default
Quote:
Just because there is no CEL, doesn't mean there aren't any codes...
__________________
"Proud to be a Veteran"
2006 Chevrolet Silverado Crew Cab 1500
2003 Crown Victoria Police Intercepter SOLD
1993 MTX Red on Silver SOLD
1993 MTX Red on Black SOLD
SHOForum Guidelines
SHOForum TOS
Matt@fastfordsofmn.com
  #6
Old 03-23-2012, 03:26 PM
Registered
Default
Quote:
THat's why i said it's worth a try lol
  #7
Old 03-23-2012, 07:11 PM
Registered
Default
These are the 2 codes
122 Throttle Position Circuit lower than minimum volt.
157 Mass Air Flow Circuit lower than minimum volt.
  #8
Old 03-23-2012, 07:44 PM
Vnuk1's Avatar
Mr. Mayhem
Default
Unplug your MAF and drive it with it unplugged.
  #9
Old 03-23-2012, 08:07 PM
Registered
Default
What good will that do me?
  #10
Old 03-23-2012, 10:25 PM
Vnuk1's Avatar
Mr. Mayhem
Default
Don't ask questions, just do it.
  #11
Old 03-23-2012, 10:38 PM
Registered
Default
I unplugged the MAF before starting the car. CEL immediately came on. Started driving and it ran how it was supposed to! I was able to go 30mph in 3rd and give it roughly 3/4 throttle and it accelerated with no cutting out at all! Then drove another mile or so and it started doing it again....... ugh ******* SHOs
  #12
Old 03-23-2012, 11:54 PM
Vnuk1's Avatar
Mr. Mayhem
Default
When you replaced the MAF with another are you sure of its being a known working sensor? Do you have a known working TPS to swap in?
  #13
Old 03-24-2012, 12:04 AM
Registered
Default
Well i bought it at a junkyard for $15... So, i'm not sure on that one. And i do not..
They're not too expensive. Should i try metering the voltage?
  #14
Old 03-24-2012, 12:05 AM
Registered
Default
ok, so either the tps is bad, or the ground to the circuit is bad - the tps and the mafs share the same circuit, and since both are being reported as bad it suggests a ground or power issue.
trace the wiring and make sure all connections are good, especially the ground. if that doesn't do any good, then replace the tps, reset the codes, and try again.
  #15
Old 03-24-2012, 12:09 AM
Vnuk1's Avatar
Mr. Mayhem
Default
Do what he said and check your wires first, maybe you have a fubared wire or ground.
  #16
Old 03-24-2012, 12:19 AM
Registered
Default
THanks guys. I'll keep you updated
  #17
Old 03-27-2012, 07:19 PM
Registered
Default
Bought a new TPS just to see, and it didn't change anything. And i unplugged the MAF and it didn't change anything. Must've been a coincidence the other day. Where can i find the ground for that circuit?
  #18
Old 04-09-2012, 04:12 PM
Registered
Default
Where can i find the ground for that circuit? Still driving the car this way..........
  #19
Old 04-13-2012, 02:05 PM
Registered
Default
Update on SHO issues. The new TPS got rid of the 122 code. The 157 MAF code is still there. And now i have a new code 214. And still dealing with the severe bucking under acceleration. Unplugging the MAF doesnt do anything. But now that 214 Code bring me to think Cam Sensor? Crank sensor was done last year along with aux wire from DIS to negative terminal. Any info would be greatly appreciated. Thanks guys.
I have a spare DIS i might try since its easy. Also, i heard i can unplug cam sensor and drive it that way just without a tach (and may take several times to start) thoughts?
  #20
Old 04-13-2012, 03:37 PM
msteiny's Avatar
msteiny msteiny is offline
Registered
msteiny is on the right road
Default
Hows your fuel pressure?
Check to see how well your DIS is grounded and try re-gooping the back with di-electric compound also making sure the connectors are making contact.
  #21
Old 04-13-2012, 06:48 PM
jedhead's Avatar
jedhead jedhead is offline
Registered
jedhead is a jewel in the roughjedhead is a jewel in the roughjedhead is a jewel in the rough
Default
You may have a vacuum leak. I would get some spray starting fluid, start the car and while it is idling spray around the intake between the air cleaner to the intake manifold. If the idle jumps up, that is where your vacuum leak is. I had a similar problem that was caused by crack in the pipe between the MAF and throttle body.
Bob
__________________
1991 SHO
2006 Cadillac STS-V
2003 Honda Accord EX
1973 Datsun 240Z
SHOCal
Car Domain
  #22
Old 04-13-2012, 06:59 PM
Registered
Default
Quote:
Bob
I replaced ALL intake gaskets and recently inspected intake hose. All is good. I've also already done the carb cleaner/starting fluid test with no results. It did this before and after replacing the gaskets btw
  #23
Old 04-14-2012, 06:06 PM
Registered
Default
Unplugged the cam sensor and it didn't change anything. I pulled the DIS module and cleaned everything up and put di-electric compound on it. And have a good ground for the DIS as well. I have a spare DIS, should I try that next? Btw I still have the maf code as well
  #24
Old 04-15-2012, 11:30 PM
Registered
Default
Update, spare DIS didnt change anything. Is it possible that the wiring going to the connector plugs for the DIS are bad?
  #25
Old 04-17-2012, 09:37 PM
Registered
Default
Update on my 94 mtx. Backfires alot when taking off from a stop (have to ride the clutch a bit, to prevent this), Stumbles severly when accelerating, tach does NOT drop, only stumbles under 4000 rpm (still seems a bit underpowered after 4k, but runs how it should), unplugged cam sensor and nothing changed, unplugged MAF and nothing changed, crank sensor is less than a year old and properly gapped, brand new TPS, good ground to DIS and also tested good, still have intermittent codes 157 & 214. Ground at intake is good. Just reset the codes today and went for a drive, same 2 are coming back. Please help guys.. I'm getting desperate here.
  #26
Old 04-24-2012, 01:29 PM
Registered
Default
Ended up being plug wires... I was so hung up on what the codes were.. I feel dumb haha, thanks for the help guys!!
  #27
Old 04-24-2012, 04:31 PM
Blackdr16's Avatar
Blackdr16 Blackdr16 is offline
93 SHO kid
Blackdr16 is on the right road
Default
Glad you found it. :D Sometimes its the simple things we tend to overlook the most
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
