SHOForum
Go Back   SHOForum > Generation 4 SHO (2010-present) > Generation 4 - General Discusson
Reply
Thread Tools
  #1
Old 12-16-2011, 07:26 AM
10SECSHO's Avatar
10SECSHO 10SECSHO is offline
Registered
10SECSHO is unknown at this point
Question 2012 Ford remote start
Did a ton of searching but have not found an answer. When I remote start the car with the Ford dealer installed unit and then open the doors the engine stalls. Is there a way around this? Also can you program the car to run longer than 10 minutes when remote started?
  #2
Old 12-16-2011, 11:06 AM
SHO U UP's Avatar
SHO U UP SHO U UP is offline
SHO Guru
SHO U UP is a jewel in the roughSHO U UP is a jewel in the roughSHO U UP is a jewel in the rough
Default
The engine is supposed to cut off when the door is opened. Safety feature so the car isn't stolen. Of course you would think the key fob would need to be present before it were to move but that somehow must have been overlooked by the designers. There may be a way around it not shutting down but you'd have to do a search.
__________________
Mick
-2010 Silver Gen 4-arrived 10-6-2009!
-1996 Medium Graphite MTX Gen 3...soon to be Supercharged
-1997 Supercharged Gen 3....FINALLY!!
*SOLD* to STL SHO 2-11-2011
-6 other SHOs sold to new homes....
-2006 BMW X5 - 4.4i
-2003 Ford Explorer Sport Trac 4x4 (5" and 33" Toyos)
-2001 Lightning SVT- Low&Lethal - 695 rwhp/705rwtq on 19#s. *SOLD* 12-8-2012
-1997 F-150 4x4 Monster truck *SOLD* 5-7-2010
  #3
Old 12-16-2011, 11:27 AM
hawkeye18's Avatar
hawkeye18 hawkeye18 is offline
Sorta cares
hawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond repute
Default
Seems to me that you could simply disconnect the door state input wire to the remote start module. How? Not a clue, but there's got to be a discrete input that can be disabled.
__________________
Jason H ('95 ATX, '13 Focus Titanium)
My radar sees farther than your SHO can drive on a tank.
  #4
Old 12-16-2011, 12:09 PM
10SECSHO's Avatar
Registered
Default
Can't find the answer. Guess will have to live with it for now. Also I guess it only let's the car run for 10 minutes then shuts it off but I think you can change that to a max of 15 minutes..
  #5
Old 12-16-2011, 01:49 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Registered
Johnny Langton is unknown at this point
Default
I know that there is an option on the Flex to disable the engine shutoff when the door is opened after remote starting. There's a long thread about this on fordflex.net, and IIRC, a dealer must change the setting, but most are clueless on how to do it.
JL
__________________
1997 Thunderbird-4.6L/4R70W.....12.16@111.77(N/A NPI)
2010 MKT AWD EcoBoost Elite 14.41@96.27(bone stock)
  #6
Old 12-16-2011, 08:12 PM
LotusDriver's Avatar
LotusDriver LotusDriver is offline
Registered
LotusDriver will become famous soon enoughLotusDriver will become famous soon enough
Default
The problem is, once you get in and step on the brake, the car will shut down because it is running off the remote starter. It would need some sort of input to change it over to a normal operating ignition state.
__________________
2011 SHO - Kona Blue, Loaded
2013 Explorer Sport - Tinted Red
2008 - Haro Sport "Retro"
2010 - SE Quadangle "Retro"
Various other PK Rippers and Haros
  #7
Old 12-16-2011, 10:17 PM
10SECSHO's Avatar
Registered
Default
I'm still trying to figure it out..
  #8
Old 12-19-2011, 07:44 PM
beefcake beefcake is offline
Registered
beefcake is spectacular!beefcake is spectacular!
Default
actually you guys are incorrect.
the reason the remote start shuts off when the door is opened is because of the mykey feature.
the remote start does not know if a mykey is being used, therefore opening the door and disengaging the engine, forces you to physically start the vehicle using either a regularly programmed key, or a programmed mykey, so that the vehicle knows if it is supposed to be limiting speed, radio, etc...
i believe we can disable this at the dealership, but the mykey feature will be disabled when using remote start
__________________
First Gen 4 in the 12's!!!!
2011 Mustang GT 5.0 - 1003 rwhp - 9.03 @154 Daily Driver
http://www.teambeefcakeracing.com
  #9
Old 12-20-2011, 01:13 AM
10SECSHO's Avatar
Registered
Default
So the dealer has to disable the mykey? It's not something I can do?
  #10
Old 12-20-2011, 10:13 AM
Registered
Default
Quote:
Your not disabling my key, you are reprogramming bank 2 option 7 i believe.
the doors disabling the remote start are an option and can be turned off.
If you know what your doing, you can do it yourself
  #11
Old 12-22-2011, 06:03 PM
10SECSHO's Avatar
Registered
Default
Well the dealer won't make the changes so I'll either have to do it myself or find another dealer. Thing is I'm not sure where the over ride button is. The dealer has a big hangup with the push button start.
  #12
Old 12-23-2011, 07:57 PM
10SECSHO's Avatar
Registered
Default
Trying to find the over ride button and no luck. I'm guessing its under the dash on the driverside but can't locate it. Time to ask the dealer I guess.
  #13
Old 01-01-2012, 09:18 PM
10SECSHO's Avatar
Registered
Default
Quote:
JL
RIP Johnny. You never know when it's your turn.
  #14
Old 01-01-2012, 10:03 PM
hawkeye18's Avatar
Sorta cares
Default
Wait, what!?
  #15
Old 01-01-2012, 10:16 PM
10SECSHO's Avatar
Registered
Default
Quote:
Originally Posted by hawkeye18 View Post
Wait, what!?
Johnny was killed a few days ago in a 5 car accident when another driver crossed the centerline. Truly sad.
  #16
Old 01-02-2012, 12:44 AM
hawkeye18's Avatar
Sorta cares
Default
Holy crap, that is truly awful. :( RIP Johnny.
  #17
Old 01-02-2012, 11:41 AM
esfoad esfoad is offline
Esfoad
esfoad is on the right road
Default
That is truly too bad and incredibly sad. RIP Johnny.
__________________
2010 SHO Cinnamon on umber/black, fully loaded, only mod is Dynomax axle back exhaust (sound improvement only no power add at all)
  #18
Old 01-06-2012, 07:58 PM
Registered
Default
Suppose you disable the door kill feature. Then you jump it and drive off. What is keeping the car from shutting down after the 15 minutes times out? It's more than just a door switch folks.
  #19
Old 01-07-2012, 02:08 AM
10SECSHO's Avatar
Registered
Default
Quote:
Yep sure is.
  #20
Old 01-07-2012, 10:37 AM
Esfoad
Default
I've been using my starter for almost 2 years now. It's really no issue to restart the car. If you use Bluetooth it also makes the connection upon restart, otherwise you have to press Phone and re-establish the connection. I know many people with this type of remote start and no one has had any issues with the starter or anything like that.
  #21
Old 01-07-2012, 01:41 PM
10SECSHO's Avatar
Registered
Default
Quote:
Ok cool..thanks
  #22
Old 01-08-2012, 06:16 PM
GigaHz's Avatar
GigaHz GigaHz is offline
Registered
GigaHz is on the right road
Default
Why doesn't the car know I am not in it (stereo blares). Why doesn't the car know it is cold outside. (Turn on heat and defroster).
My 2006 Pontiac knew to turn off the radio (remote start) and start heat or air conditioning as required by outside temperature.
The whole remote start looks like an after thought on this car.
__________________
2012 Taurus SHO
2008 Corvette Sold
2006 Grand Prix supercharged Sold
2004 GTO 392 RWHP Sold
  #23
Old 01-08-2012, 06:38 PM
Laminar Laminar is offline
NO SHO
Laminar is on the right road
Default
Are you suggesting that no auto company has a solution to this? I had a rental Cruze that would stay running when I opened the door. It just had me hit the Engine Start button to confirm that I was in the car.
  #24
Old 01-08-2012, 08:29 PM
Registered
Default
So what would happen if you didn't hit the button?
  #25
Old 01-09-2012, 04:47 AM
NO SHO
Default
I never tried and the owner's manual doesn't discuss the possibility. I imagine it would keep the car in park or kill the engine if you try and shift. Either way the instrument screen made it clear that I needed to press the start button.
  #26
Old 01-09-2012, 08:20 AM
Esfoad
Default
That Chevy sounds more integrated than what we have. Ours is truly a factory "aftermarket" system. An add-on if you will. So it is not as well integrated.
Regarding the defrosters turning on, that doesn't happen even if you start the car with the fob in it. Requires a manual push of the front and rear defroster buttons. So the operation with remote start is no different. I agree it's a pain to have to remember to leave the windshield defroster button pushed. There is no way to have the rear defroster start automatically. Or the seat heaters .
  #27
Old 01-09-2012, 06:32 PM
NO SHO
Default
Ah, that's too bad. Supposedly the Cruze will check the outside ambient temp and, if necessary, turn on the defroster and seat heaters.
It was a pretty good car, drove really well, but it was small, cramped, and slow.
  #28
Old 01-19-2012, 06:16 PM
TRBOSHO TRBOSHO is offline
Registered
TRBOSHO is unknown at this point
Default
I installed it myself. I can tell you that there is an individual wire for EACH door, the trunk and a hood switch that all kill the starter. If I recall, the taps are all behind the glove box door, but it's been a while. The car does require you to step on the brake to shift from park and the car will die to prevent theft, but you can't simply turn on the key like any normal car, so you would likely have to stall the car after entry when you shift out of park. Test this by starting the car while you are already in it, and see if you can figure out how to drive away without restarting it.....
  #29
Old 12-08-2012, 01:49 AM
10SECSHO's Avatar
Registered
Default
The 13's have the factory installed remote start which is how they all should have been. Still have not figured out how to make the car run longer or keep it from dieing when the door is open. This is on my 12.
  #30
Old 12-09-2012, 09:49 AM
Registered
Default
I have a 2013 Explorer Sport with factory remote start. The engine stays running when you open the door, and then prompts you to step on the brake and press the start button. If a key is detected, it will switch over and remain running in normal mode. If no key is detected (someone stealing the car) it won't switch over and will not allow the transmission to be shifted out of park.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
