SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 10-10-2011, 11:41 PM
jimtash's Avatar
jimtash jimtash is offline
Registered
jimtash is spectacular!jimtash is spectacular!
Default Positive battery cable keeps corroding.
No matter how often I clean it, the positive battery cable always ends up corroding at the battery post within a short period of time. I've tried battery grease, silicone spray, the felt washers and it makes absolutely no difference. Within a few weeks there will be major build up at the battery post. Anyone here have any suggestions on how to neutralize the acid and keep it from corroding? It's starting to affect the battery's ability to charge.
  #2
Old 10-11-2011, 07:17 PM
My_Silver_SHO's Avatar
My_Silver_SHO My_Silver_SHO is offline
Registered
My_Silver_SHO is on the right road
Default
Do you have a crack in your battery?
  #3
Old 10-11-2011, 08:34 PM
Off Road SHO Off Road SHO is offline
Moderator
Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!Off Road SHO is brilliant!
Default
What he ^ said.
Also keep in mind batteries outgas more when they are being charged or dis-charged. So if your alternator is not working or overworking, that could be the problem.
Tom
__________________
Sometimes, I am as confused as a baby in a Topless Bar.
All your polished parts are belong to me!
" The Other Woman "
12.16@116mph on BFG Mud Terrains
To see her in action:
http://www.youtube.com/watch?v=sG16m2e4O6I&feature=fvw
AZSHO.com
  #4
Old 10-11-2011, 08:46 PM
notbange's Avatar
notbange notbange is offline
notbange will become famous soon enoughnotbange will become famous soon enough
Default
Some batteries just seem to corrode. Either keep on cleaning, or replace it.
__________________
Sam T.
Current shos:
1992 silver/gray, 220k
1993 Black/black 180k
Sold shos:
1995 white/gray ATX
1994 Green/tan ATX
1989 red/destroyed
  #5
Old 10-11-2011, 10:24 PM
jimtash's Avatar
Registered
Default
Quote:
Originally Posted by Off Road SHO View Post
What he ^ said.
Tom
No cracks in it from what I can tell. I will say that is discharges rather quickly too. Replaced the power antenna mast the other day and with just the key on to power the antenna motor, it drained the battery. Granted it was on for 15 minutes while trying to get the mast to go into the motor, but still that shouldn't drain it to the point it couldn't start the car.
  #6
Old 10-11-2011, 10:26 PM
Ishodu's Avatar
Ishodu Ishodu is offline
Moderator
Ishodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid one
Default
The seal around the post is likely gone, causing corrosive gases or liquids to get to the terminal.
__________________
95 MTX
3.2 High Comp forged pistons and Custom Cams plus more.
312hp 266tq
Drag Vid
  #7
Old 10-11-2011, 10:38 PM
jimtash's Avatar
Registered
Default
Then it's battery time.
  #8
Old 10-17-2011, 12:35 AM
dqdude dqdude is offline
Registered
dqdude is unknown at this point
Default
I had the same issues hard core in my old 77 F-150 way before I had my SHO. I switched to an Optima and ended that issue totally. Now every vehicle I own gets an Optima on it's way home.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
