SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Emergency Issues - Help & Maintenance
Reply
Thread Tools
  #1
Old 07-30-2011, 11:56 PM
Randall's Avatar
Randall Randall is offline
Registered
Randall is on the right road
Default brake pedal to the floor off and on
Hello,
The other day while just driving normally, I was nearly smashed by a semi truck as when I came to a red light, my brake pedal went nearly all the way to the floor out of the blue. It caught me off guard, but I let off the brake and pumped it quickly, and the car stopped just in time, and the pedal stayed about an inch and a half from the floor. I immediately pulled over and checked the brake fluid, which was full to the brim, and the vacuum hose to the booster was intact and fine. What was funny is that the brakes acted normally again immediately after that incident. I drove it back to work, and through maybe 20 different stops, it was fine. Then, as I came to a stop at the light near my work, it happened again. This time I just let all the way off the pedal and it was like a reset button, and the pedal worked normally. It has happened a few more times at random since, and "pumping" the brakes seems to not make a difference half the time. It never goes all the way to the floor, as it stops and gets firm at about an inch and a half from there.
Still, this is alarming, and I have no idea what it could be. I talked to Eric Dominguez, and he thinks it may be the ABS motor/pump. I need your help in finding a way to diagnose this ASAP as this is my only car currently, and although I am still driving it, I would much rather be able to solve this and no longer have the "white knuckle" experience continue.
Additional info: Probably unrelated, but the clutch pedal suddenly changed it's feel while driving on the freeway a week ago, and now it's really hard to shift into all gears.
Also, during one or two of the stops where the pedal became squishy, I heard a clicking noise from the front of the car on the driver's side. I think it's really weird how this comes and goes, but any advice is appreciated!
thanks!
__________________
'68 Mustang GT, an ALL aluminum 351w, heavily modded AOD, axle, brakes, & frame, 11.0 second e.t.'s
'92 SHO MTX wh/bl, 186,000, '96 brakes, Eibachs & GR-2's, relayed lighting, 3.2 swap w/ 3.0 cams, rear headrests, TSW hockenheims, SHOShop catless Y, custom welded exhaust, lots of electrical mods
WOW, I need to update these pics, I am down to two cars now!
  #2
Old 07-31-2011, 01:10 AM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
Sharp car. Send it to Michigan when you're done with it...LOL...
I'd also guess the ABS pump is at fault. Did you feel any sort of pulsation when the pedal dropped? That would be the ABS pump cycling. It basically think's you're sliding when it does this. The first thing I'd do is put it on jackstands with the wheels removed and inspect all of the ABS sensor rings.
If it had only happened once, I'd say the rear brakes could be the cause. You can lose all rear brake functionality and hardly notice a difference if you drive "normal". In addition, you could pop a rear brake hose and not lose fluid....but then your foot wouldn't go to the floor and it certainly wouldn't happen more than once.
Nope. Your problem MUST be electronic. For there are no parts of the brake system that can fail, allowing the pedal to go to the floor and then return to normal.
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
The Following 2 Users Say Thank You to 93rev2sev For This Useful Post:
auto.guru (08-06-2011), Randall (07-31-2011)
  #3
Old 07-31-2011, 01:32 AM
Randall's Avatar
Registered
Default
Thanks for the advice! I hadn't thought of that yet about eliminating it to electrical, but that makes total sense! Is there a way to run a diagnostic on that ABS pump? I've got no light coming on for the "anti lock".
Thanks!
  #4
Old 07-31-2011, 03:21 PM
Randall's Avatar
Registered
Default
So, I am still afraid to drive the car, and I need a little more help if possible. All I really want is to be able to narrow the problem down to what component is bad. Right now, I think it is possible that the ABS pump could be bad, the master cylinder possibly, the booster possibly, or something I have yet to think of....
Anyway, is there any certain way to eliminate the booster or the master cylinder from being bad?
Thanks!
  #5
Old 07-31-2011, 06:19 PM
93rev2sev's Avatar
Registered
Default
Did you feel any pulsations in the pedal when this occured?
  #6
Old 07-31-2011, 06:22 PM
zach44102's Avatar
zach44102 zach44102 is offline
ALL MOTER
zach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud of
Default
Surely you would of noticed if you had a caliper sticking right? I just know from my experience when i had my pedel go to the floor I had a caliper sieze and my brake fluid started boiling.
__________________
1995 Moonlight blue MTX- 13:1 3.3L, 2690lbs Quickest ALL MOTOR SHO 13.5 @ 106mph (stock internals)
2002 Taurus SES, V8/MTX
www.SHONUTPerformance.com
  #7
Old 07-31-2011, 08:02 PM
Randall's Avatar
Registered
Default
I didn't feel a pulsation really, just a super soft pedal down to about an inch and a half above the floor board. I did hear a clicking noise twice during the soft pedal incidents that I could feel in the pedal, but it was more of a click or two and that was it each time.
No, I don't think I have a seized caliper, I did check the rotors out and they appear fine, and also, this pedal stuff only happens at about 1 in 20 stops. Really weird. I am going to try and short the diagnostic pins for the ABS and see if I get anything, no Anti Lock lights yet though, and yes the bulb works.
Thanks for the help so far guys, you're great!
I still am not sure how to rule out a possible bad Master Cylinder or Booster yet, but I know for sure there is no sound of a vacuum leak at the booster, and with the pedal working at about 90% of the time I think it's safe to say it's not the booster. Any more help is greatly appreciated!
  #8
Old 07-31-2011, 08:43 PM
Randall's Avatar
Registered
Default
Ok, so I ran a self diagnostic on the Anti Lock system through shorting the two pins in the red connector, and even though my light is not on at all, there were 4 codes!!!
Here they are in order that they came out:
22-Left hand front inlet valve
44-left hand rear sensor
43-right hand rear sensor
63-Pump motor speed sensor
Does this make any sense to anyone here when combined with the issues I am having?
  #9
Old 08-04-2011, 02:48 AM
Randall's Avatar
Registered
Default
ping... anyone?
It is still happening at the same rate, about one in every 20 stops, and it seems more common at slow speeds. I just need some help in figuring out how to deal with the codes I pulled, and if I have a bad ABS pump or motor. Any tips are appreciated!
  #10
Old 08-05-2011, 04:25 PM
ViPER1313 ViPER1313 is offline
Registered
ViPER1313 is spectacular!ViPER1313 is spectacular!
Default
I can't help with your ABS codes, but how are the condition of your wheel bearings and front axle nuts? Does the soft pedal happen directly after you take a corner (ex.. coming off of a highway offramp?) Try this out in a parking lot - make several semi-quick 360-degree left circles and then hit the brakes, then do the same while turning right. Does the pedal remain firm after both?
It is just something else to think of, because a loose front axle nut or bad wheel bearing can cause symptoms like you describe (it would be pronounced after a corner though.) The loose bearing allows the caliper piston at that wheel to depress while taking a corner, and when you straighten the wheel the piston is actually some distance from the rotor. When you hit the brakes, you are greeted by a soft pedal (because the piston has to come back out towards the rotor.) Hit the brakes again, and they firm up (because the piston is now at the rotor's surface.) This happened on my Talon a few times before I figured it out - it was quite a scary feeling. It took me a while to realize it was only happening after left cornering. The right-front wheels axle nut was finger-tight - tightening it resolved the issue completely.
__________________
12' Mustang V6 Premium
90' Eagle Talon TSI AWD - B00ST!
(SOLD) 92' MTX Red/Black - Sold
(SOLD) 94' MTX Green/Tan - TrakHor
www.mmsports.org
The following user says thank you to ViPER1313 for this post:
Randall (08-06-2011)
  #11
Old 08-05-2011, 05:47 PM
93rev2sev's Avatar
Registered
Default
This can happen when one of the tone rings gets caked with dirt/grease/mud or gets damaged. The ABS pump will activate when it's not supposed to.
Have you inspected them yet? Because I told you to do that already. If someone gives advice and you ignore it, don't expect more advice. It's really unbeleivable that so many people do this.
  #12
Old 08-06-2011, 04:53 AM
Randall's Avatar
Registered
Default
Thanks Viper, I tried that and it didn't seem to help or hurt the situation, I did have the wheels off and I didn't notice the spindle nuts being loose, but I can easily check that again. It seems to happen mostly on straight stretches at low speeds, so it makes very little sense. I seem almost certain its the ABS pump, so my next step is going to be just to replace it.
What happened 93rev? Did you have a bad day or something?
I don't like being called out when it's not warranted.
I did take your advice, and I thought it was helpful! I have easy access to a lift, so taking the wheels off and on is a snap. I pulled off the wheels and checked for any obvious signs of damage to the wiring at the sensors, and even sprayed a full can of brake cleaner spray on the sensors/rings to clean them and it made no difference. I agree with you that a lot of people ask for help and then ignore it, but I've been on this forum for quite some time, technically longer than you even, so give me the benefit of the doubt, huh
  #13
Old 08-06-2011, 08:39 AM
93rev2sev's Avatar
Registered
Default
Well...there's no doubt now that you reported your findings.
Moving along...
I've seen tone rings with hairline cracks in them that allow the ring to slip on the axle. Tap them with a screwdriver and a hammer to eliminate them as your culprit.
While you're tracking this down, disconnect a sensor to disable the ABS so you don't rear end anyone.
The following user says thank you to 93rev2sev for this post:
  #14
Old 08-06-2011, 11:50 AM
auto.guru auto.guru is offline
Village Idiot
auto.guru is on the right road
Default
why has no one offered the suggestion of a brake booster???
jeezz. my old dodge daytona had a brake booster go out on it and it acted exactly like this. i mean... to the nose hair. It always clicked when the pedal squished to the floor, not sure what the clicking was, but i remember it.
get your brake booster checked before you do anything else. How to test? i have no clue. But thats where i would start. Junkyards work best
__________________
95 MTX
Diff, Trans, & Stage 1 Clutchmasters
14.93 1/4 Mile :)
The following user says thank you to auto.guru for this post:
  #15
Old 08-06-2011, 10:48 PM
Randall's Avatar
Registered
Default
Thanks Rev, you've been a star in my book for a long time
I just had the wheels off again, and I missed your post before I did it, but I'll check again as the driver's side front did appear to have a crack in it. All of the sensors were intact and free of grease upon initial inspection, but I sprayed them down anyway. Then today, I took the wheels back off just to make sure I didn't miss something like Viper mentioned where a wheel nut could be loose - - but they were nice and tight too.
Anyway, thanks so much for the tip about disconnecting the sensors, I never thought of that, and you're right, it can be scary even when you're ready for the pedal to work or not. I have noticed that when the pedal goes down to near the floor that if I use much force, the front driver's side tire skids audibly, and yet still no ANTI LOCK light! I will disconnect the rear sensors, and thanks again for your advice, I really do appreciate it!!
Auto guru, I also was thinking it could be the booster, but I ran a vacuum pump to the large check valve and there was no leaking or spikes in pressure, so I think it may be good. When I have had one fail in the past, they get loud and vacuum pressure seems to fall off at idle, but it does have nearly 200,000 miles on it! Thanks for the suggestion!
  #16
Old 08-07-2011, 12:01 PM
Village Idiot
Default
see i never checked mine in the daytona.... so i couldnt tell you about falling vacuum at idle. But if this is an intermittent issue wont your falling vacuum be intermittent as well? it could be, and it may not be. Who knows....
And you wont get an ABS light when your pedal reaches the floor. The ABS system comes on when it detects wheel slippage. Thus it reads all 4 tires and uses that info to pulsate the brakes.
But when your pedal is to the floor, you trip a sensor, and it clicks. This is one of the clicks youve been hearing - and it turns on that brake light on the dash. When you activate that light, it shuts down the ABS system.
WHY?
well think about this. If your braking and locking up your wheels, thats a harsh force. Now think about the ABS pump pulsating the brakes - from locked to unlocked - to locked - to unlocked very very fast. Thats alot of sudden inertia that has to go somewhere. Your tires are going to get chewed up faster than belief, you are going to break lug nuts depending on your speed, or your CV halfshaft is going to break. Either way all that momentum and force has to go somewhere and something is gonna break.
Thats why you put your foot to the floor and lock em up. What would you rather do? lock your tires up and stop or break your halfshaft and be stuck in the road?
  #17
Old 08-08-2011, 01:04 AM
Randall's Avatar
Registered
Default
Okay, major update here!!
I removed the 40 amp fuse from the distribution box for the ABS motor and the Anti Lock light came on, but the exact same problem persisted. Then I kept the engine running and pumped the brakes repeatedly while stopped, and it still happened at about 1 in 15 tries, usually two in a row.
Then, I turned the car off, and repeated. I got the same results, even with no engine running, about 1 in every 15 complete pumps, the pedal goes down to nearly the floor.
Now I am totally stumped again, but at least it seems it is not the ABS pump/ motor. Does anyone have any ideas with this new info?
  #18
Old 08-08-2011, 02:46 AM
Village Idiot
Default
youve got to be losing brake pressure in your lines somewhere....
a leak maybe?
its got something to do with the psi drop off... we know that now
  #19
Old 08-08-2011, 02:50 AM
Village Idiot
Default
whens the last time you changed the brake fluid???
ill bet money your master cylinder is starting to take a shitter on you. It sounds like the seals are shot, and like to "leak" after repeated use.
You could replace your seals, but im unsure they sell those separate. You might have to buy or get a whole new one
Randall (08-08-2011)
  #20
Old 08-08-2011, 09:54 AM
Registered
Default
I had a bad brake booster on my 97 Taurus - the pedal would not go to the floor, but would become very stiff if you depressed it 2 times in quick succession. You could also hear a hissing down by the brake pedal, and there was a clicking noise involved when you pressed the pedal as well. If I recall correctly, the way to check for a bad brake booster is to press the brake pedal to the floor with the motor running and then shut the motor off. If the brake pedal immediately starts to push back against your foot when the car is turned off, it means the booster is leaking somewhere internally (it should hold vacuum.)
  #21
Old 08-08-2011, 07:41 PM
Randall's Avatar
Registered
Default
Thanks Guru, I haven't changed the fluid in at least 4 years, but it isn't losing any, but I think you're onto something about the master cylinder
Thanks too Viper, I did the test you recommended and the pedal just stayed still mostly. If I pump it completely down and up it eventually does the squishy pedal symptom one every ten to fifteen times, so I'd like to think it can all be traced to the master cylinder but I am stumped because when I have had one fail before on different cars, they usually just fail and do not go back and forth between working great most of the time to not working. Anyway, thanks for the input!
  #22
Old 08-14-2011, 01:03 AM
Randall's Avatar
Registered
Default
with two jobs and almost no free time lately, I haven't had a chance to dive into this issue, but it is still there:( At the same time, my clutch has decided to fail, and first gear is no longer usable, so I've got a few other things on the burner. I still am totally stumped on what could be the cause, and due to a tight budget since I will need a clutch much earlier than anticipated, I refuse to just throw on a few different parts in hope of fixing this, maybe. Given what I have posted here in this thread, is there any other suggestions you guys out there might have?
Since the pedal issue happens when the car is sitting still with the engine off the same as when it's driving around town, it's very hard to pinpoint. I thought I was a SHO master, having owned 4 now, and fixing several different types of problems over the years, but this one has my butt kicked. I've searched this forum to exhaustion trying to find a similar issue and have had no luck.
If anyone knows of any tests to rule out various parts of the braking system please let me know, I am nearing a braking point of frustration (pun intended)!
  #23
Old 08-14-2011, 09:22 AM
kevinspann's Avatar
kevinspann kevinspann is offline
87 Octane
kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!
Default
Look at the booster, directly under the master cylinder - if it's wet there, the seals in the master cylinder are leaking.
__________________
15s in 2015
  #24
Old 08-14-2011, 01:18 PM
SeanMc SeanMc is offline
NoMoSHO
SeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud ofSeanMc has much to be proud of
Default
If you talked with Eric, he is probably right. This happened to my parent's blazer recently (while I was driving it), and it ended up being both the master cylinder and the pump.
__________________
2014 Focus ST.
  #25
Old 08-14-2011, 04:09 PM
Village Idiot
Default
actually its easier to diagnose with it failing while the car is driving and is not driving.
this leads me to think the seals in the master cylinder are shot.... being as it doesnt make a difference if car is on or off.
  #26
Old 08-21-2011, 04:27 AM
Randall's Avatar
Registered
Default
thanks for all the replies, I bought a new Master Cylinder and should have it installed in the next few days. Eric felt the pedal after we dropped a new clutch in the car, and he said it had to be the MC. It was only 39$ at AutoZone with a lifetime warranty! Hope this fixes the problem!
Thanks again everyone!
  #27
Old 08-22-2011, 01:01 AM
Randall's Avatar
Registered
Default
Final update
Bought a new master cylinder from AutoZone after three attempts due to their system having the wrong info about SHO brake parts, got home, installed it, problem gone!
The brakes feel as if the whole system was replaced, the pedal feels better than most of the newer cars I drive at work!
Anyway, thanks for all the help guys, I really appreciated it!
(Just a tip for those of you who are going to replace a Master Cylinder with an aftermarket version--- Take the two roll pins that hold the reservoir onto the MC, take the large O-ring on the back of the MC, and buy lots of brake fluid!
It actually was much easier than I thought it would be to replace the MC, and if you have all the parts you need at the start of the job, given that the parts store actually knows what they are doing, it should be a breeze, especially with the Thexton 133 brake bleeding tool!
Thanks again all!
  #28
Old 08-22-2011, 07:19 PM
icemaneric icemaneric is offline
Registered
icemaneric will become famous soon enoughicemaneric will become famous soon enough
Default
Glad you got it taken care of Randy, told you it was an easy job. All you need to do now is, replace the racing slicks you have out back.
__________________
91+ white/black "PROJECT 195"
95 MTX green/mocha 17" wheels, 13" snake brakes, koni/eibach, Delrin SFB, SFC, 24/26mm SB, Magnaflow Y pipe, and then some!
98 SHO White/mocha, welded cam's 235/45/17 OZ Wheels
  #29
Old 01-16-2012, 09:34 AM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
Default
I will add my case to this topic since it was through this discussion that I determined my master cylinder was also at fault for the identical symptoms. I replaced the the master cylinder (MC) with the remanufactured Fenco M2613 from AutoZone. The new part is the NM2613, with the "N" statnding for new. This part reuses the reservoir from the old MC. To remove the tank from the cylinder, tap out the roll pins from the side opposite the tank's plastic tab. I used the shank end of the appropriately sized drill bit to mate against the roll pins and tapped lightly with a hammer. The tank must be pulled with significant force to extract it from the rubber bushings on which it is mounted. There are two nozzles with ribbed ends that extend into the bushings. I used two hands on the tank and a foot on each end of the MC.
After careful "bench bleeding" with the supplied fittings and tubing before reinstalling, and purging any remaining air from the two brake line connections upon reinstallation in the car with the wife's help on the pedal, both per the good instructions packaged with the new part, I found the pedal to be as firm as before the swap without additional bleeding. I contentedly drove back to AutoZone and returned the core for my refund with the brakes working as designed. All seemed well on my return home as I slowed to pull into the driveway. Upon application of the brakes, the pedal once again sunk smoothly to the floor. How disappointing! And dangerous! I am still searching for the solution to my brake system malfunction.
__________________
Helping to keep the SHO on the road,
Scott
1991, 433K miles, and rolling...
In-car Track Video: Laps at TWS
  #30
Old 01-16-2012, 12:06 PM
Aqua Roach's Avatar
Aqua Roach Aqua Roach is offline
Deadly Insane
Aqua Roach is on the right road
Default
Well check the master cylinder again, all the brake lines, the power-booster and even the calipers for any indication of leaks.
If it's the MC again, I'd be tearing some autozone employees a new one.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
