SHOForum
Go Back   SHOForum > Generation 4 SHO (2010-present) > Generation 4 - General Discusson
Reply
Thread Tools
  #1
Old 06-10-2011, 01:19 PM
Race Coach Race Coach is offline
Registered
Race Coach is unknown at this point
Default Ford Sync / Jukebox / MP3 / USB / CD / DVD
I have spent a little time experimenting with different ways to manage music in my new SHO. So, I though I would pass on my learnings, to save people some effort.
I was a little excited to have a 10GB Jukebox to play with, and wanted to get some of my (120GB) MP3 music loaded.
I quickly discovered that the 10GB jukebox is virtually useless (to me), since all you can do is insert a standard CD (not MP3) and rip it onto the hard drive using the Sync "record" button. The inability to load MP3's from a DVD/CD/USB was very disappointing. I decided that if I couldn't get my music on this way, I would abandon the Jukebox and leave it empty.
Next solution:
1) USB Thumb Drive
The USB thumb drive worked very well and displayed all the basic MP3 tag information (song name, artist, album). It also supported "folder mode", allowing me to put different music into different folders, while showing me which folder the music was residing in. Ideally, I would like to put different playlists into unique folder. But, I was not able to find a way to tell the audio system to stay in one folder, or to quickly jump from one folder to another.
- If anyone has figured this part out, please let me know.
2) CD / DVD disks
I tried copying MP3 files to blank disks using the standard Windows 7 utility. The Sync system did not like these disk and rejected them as "incorrect format".
However, when I use iTunes (V 10.3.1) to "burn playlist to disk" I found success. BOTH CD-R and DVD-R disks worked. This means that if you use a DVD, you can get 4.38GB of music onto a single disk. MP3 tags are displayed, just like they were with the thumb drive.
But, since iTunes will only burn one playlist at a time, you are limited to burning separate disks for each playlist. Not the end of the world.
As an aside, I also used a free utility from DVDVideoSoft called "Free Audio Converter" to resize my MP3 files, allowing me to put more music onto a single disk. It is a great utility.
Hope this helps someone.
  #2
Old 06-10-2011, 02:56 PM
Unknown_Driver's Avatar
Unknown_Driver Unknown_Driver is offline
V6TwinTurboAWD
Unknown_Driver will become famous soon enough
Default
i throw all my music onto a USB thumb drive and place each album in its own folder or copy a bunch of random mp3's into a folder, if it doesn't recognize all your music explore the usb stick and pick a song, scroll using the right knob to change folders it will pop up saying what folder only problem is the list plays alphabetically.
never had an issue creating data cd's or dvd's for music (treat it the same way as a usb) even worked using windows media player on windows 7, i don't really bother with it anyway, i'll just burn random music videos and movies to a dvd-r using VSO convertXtoDVD
the best way for large libraries is to just get an external hard drive that can be powered by the usb and load all your music onto that
__________________
2010|Taurus SHO|13.6@101 Luskville Dragway QC
Mods: K&N Air Filter
Oil: Royal Purple 5w20
Winter Rollers: 19" Bremmer kraft BR05 wrapped with Michelin Pilot Alpin PA3
CONS: Every option possible but lacking HID's WTF Canada?
  #3
Old 06-10-2011, 04:39 PM
Registered
Default
@Unknown_Driver
Thanks for the idea of using a USB Hard Drive. I will look into that. I can pick one up for under $50 and put everything onto it.
I have a Centon 16GB USB DataStick and my SHO doesn't like it, while my smaller generic USB Flash Drive does work. Hopefully the USB HD will work.
I was not able to change folders on the thumb drive using any dial. Can you please elaborate? I was able to use the "explore disk" to isolate a folder. And that is good enough for me.
Off to TigerDirect.
  #4
Old 06-10-2011, 08:26 PM
V6TwinTurboAWD
Default
Quote:
Originally Posted by Race Coach View Post
@Unknown_Driver
Off to TigerDirect.
i'm using a Patriot Xporter XT
with the external hard drive just make sure its set for the right format
  #5
Old 06-13-2011, 12:34 AM
zeus268's Avatar
zeus268 zeus268 is offline
Maple Leaf SHO
zeus268 will become famous soon enough
Default
I'm using a WD Passport 500gb because of my 100gb collection and having grown out of my 80gb ipod. Just make sure that the drive is formatted as a FAT32 format and the SYNC system should be able to read it just fine
__________________
Andrew
2011 Black on Black
*Full load and tinted all around
*Mobsteel Grille
*AirRaid CAI
*Livernois Tuned Stage 3
*Magnaflow Exhaust
*De-badged & soon to be "Re-badged"
The following user says thank you to zeus268 for this post:
Unknown_Driver (06-13-2011)
  #6
Old 06-13-2011, 07:29 AM
Registered
Default
UPDATE:
I picked up a 500 GB Western digital USB 2.0 had drive on the weekend, and used a free utility to format it to FAT32. Then I used iTunesExport (free utility) to export and copy all my music to the hard drive (from iTunes), making sure that the M3U files remained in "simple" format. The M3U files are on the root directory of the drive, while the music is organized into sub-directories (just like on my home drive). I also used a utility to strip out the drive letter from all the path names of the songs within the M3U files.
When first plugged into the USB port, the SYNC system indexes all the music. This takes quite some time. Once it is done, you are able to explore the drive and select playlists from the menu. All my playlists are there and can be selected. It brings up a list of the songs in the playlist, and I select one of these songs. SYNC then stays within this playlist whether in SHUFFLE mode or not. Basic MP3 tag information come up, too.
This is awesome. It's exactly what I wanted.
  #7
Old 06-14-2011, 04:16 PM
Registered
Default Indexing & no voice command warning driving me nuts
A couple of questions for anyone out there:
1) Is there any way to avoid INDEXING the drive every time I turn the car on? You'd think if there are no changes, then indexing should not be necessary.
2) Is there any way to get the women to stop telling me that, "due to the number of files on the media, voice commands are not available for the media"? She feels that it is necessary to tell me this about 2 minutes into every car ride.
Thanks.
  #8
Old 06-14-2011, 05:00 PM
N8rfastback N8rfastback is offline
Registered
N8rfastback is on the right road
Default
mine doesnt index every time, but im only using a thumb drive,
it probably has something to do with the drive having to turn on and spin up every time you start the car, then the car recognizes it, and tries to index it.... where as a thumb drive is instantly ready to go with power applied....
-Nate
__________________
2010 Candy Red Sho, 402A, 20's, Nav, countoured seat, Curt class III hitch, custom exhaust, Airaid intake, and SCT XCal III tuner with Livernois tunes.
  #9
Old 06-14-2011, 06:18 PM
V6TwinTurboAWD
Default
-Nate
werd
you could always try a not so cost effective solid state drive
  #10
Old 06-14-2011, 06:26 PM
Registered
Default
Indexing, I can live with, as it still plays while indexing. However, "that woman" is driving me crazy!
  #11
Old 06-14-2011, 08:46 PM
hawkeye18's Avatar
hawkeye18 hawkeye18 is offline
Sorta cares
hawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond repute
Default
Sync can only deal with so many files. If you don't want her to ***** at you every time you turn the car on, take some music off. You can't possibly be listening to that much anyway.
I have a tiiiny little 8gb USB key that only sticks out about 4mm from the port. Works wonderfully. I'll try to find the link to the one I got.
__________________
Jason H ('95 ATX, '13 Focus Titanium)
My radar sees farther than your SHO can drive on a tank.
  #12
Old 06-14-2011, 08:50 PM
hawkeye18's Avatar
Sorta cares
Default
Here it is: http://www.amazon.com/gp/product/B0041O200O
  #13
Old 06-14-2011, 09:22 PM
Registered
Default
Different people. Different music styles. Different playlists. Lack of repetition. Different moods. It all adds up to a lot of music. A lot more than 8GB. That's why Apple makes a 160GB iPod.
I don't need to be told that voice commands are not available every time I get into the car. I should be able to disable the warning somehow.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
