SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 12-10-2010, 12:18 PM
xxxtommyxxx16's Avatar
xxxtommyxxx16 xxxtommyxxx16 is offline
Slide or Die
xxxtommyxxx16 is unknown at this point
Angry I need help!!! Sho wont run
Hello all.
Here is my problem, I bought my SHO a few months ago and when i bought it, it needed a rely control module. (the little box above the radiator) since then i have replace spark plugs, wires fuel pump fuel filter TPS Cam shaft position sensor i have cleaned the MAF . i have taken it to 3 different mechanics and none of them can tell me whats wrong.
NOTHING HAS FIXED THIS CAR!!!
The car will not do anything but idle, When you touch the gas, it bogs or shuts off. I dont get any smoke, it doesnt run hot or smell like gas. and the only code it throws is 85.
CAN ANYONE HELP ME?????
Always appreciated!!
__________________
[keep][FORD][alive]
91 TAURUS SHO PLUS [WHITE]
  #2
Old 12-10-2010, 01:06 PM
SHObill's Avatar
SHObill SHObill is offline
'The Collector'
SHObill is a splendid oneSHObill is a splendid oneSHObill is a splendid oneSHObill is a splendid oneSHObill is a splendid oneSHObill is a splendid oneSHObill is a splendid one
Default
does it idle indefinitely? can you light feather the gas pedal to rev it out of idle a bit while in neutral? Sounds like too much fuel is getting dumped in & she bogs & dies OR not enough fuel so she bogs & dies. Did you change out fuel filter? That new CCRM could be bad as it controls the injectors(but I think just power) &/or air temp sender in airbox is bad telling engine its -30* outside dumping in fuel. OR even MAF is bad!
__________________
248-842-5911 Bill
95ATXwhite/mocha 114K-Memphis06Convention=Gold Winner,-2010SHO reveal participant. --TOTALLED-10/18/10!! :(
89 red/black/grey 114K-HockeyPuck-SFB's 'Y'pipe,MtrMts,AC gone,full SFC,UP 60K,gasket match,HL/DL on relays,Tokico/Eibach,new exhaust,newClutch,REenforced/rebuiltTranny-new SF w/comp new frt susp,96Brks.
91+ white/black 108K-In storage-Full 60K @ Standstill!
89 red/grey 225K
'Rust Free'
  #3
Old 12-10-2010, 06:09 PM
mrecoolgar's Avatar
mrecoolgar mrecoolgar is offline
SHO NUP
mrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to allmrecoolgar is a name known to all
Default
TPS, throttle position sensor ?
__________________
Current Rides
SHOs: 1989 Currant Red-Titanium, 1989 Titanium-Titanium, 1989 Oxford White-Titanium, 1990 Electric Red-Sandlewood, 1991 Deep Jewel Green-Mocha, 1996 Rose Mist-Graphite
Others: 1968 Cougar XR7, 1988 Mazda RX7 Vert, 1989 Cougar XR7 SC, 1995 Contour SE My Lil-Sho, 1997 Ranger XLT, 2005 F150 King Ranch 4WD
  #4
Old 12-10-2010, 06:26 PM
itwonder itwonder is offline
Registered
itwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid oneitwonder is a splendid one
Default
Have you checked the fuel pressure? Not much to go on, but maybe fuel pump or clogged fuel filter. One other thing to try that is easy. unplug the MAF and see if it runs better.
Is the idle smooth , and does it start easy.
__________________
Bob
1992 Black/Black
Original Owner - 245K
  #5
Old 12-10-2010, 09:33 PM
rubydist rubydist is offline
Registered
rubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud of
Default
unfortunately, there is a long list of possible issues you could be facing. you can help narrow it down by pulling codes and letting us know what those are.
the two that popped into my head as I read your symptoms are:
1. tps (as suggested above) - if this is bad it usually sets a code
2. cam timing is wrong - I have seen cars act just like you describe if the cam timing is off a few teeth. this can occur due to sloppy mechanic who doesn't realize how critical cam timing is, or if the belt gets loose and jumps time.
you can check cam timing by pulling the upper timing cover and then turning the engine over until the 0 degree mark on the crank pulley lines up with the lower cover arrow. then look to see if the cams are turned so the marks line up with the line stamped into the rear timing cover.
__________________
96 Pearl White Mark VIII 4.6 dohc
90 Red RX-7 convertible project.....
96 White w/ Grey F250 4x4 OffRoad extended cab
98 Green Mountaineer awd 5.0 - for sale!
03 Tan Subaru Outback 3.0
former SHOs include 94 re atx, 94 wh atx x2, 93 gr atx, 94 bl mtx, 97 bk, 98 bk, 95 gr atx->mtx, 93 bl mtx, 93 bl atx, 95 bl atx, 95 gr atx, 92 wh mtx
  #6
Old 12-15-2010, 01:44 PM
Slide or Die
Default
Ive done the TPS and CPS, My mechanic said my timing is fine. Here's what ive found out. I put a ton of fuel injector cleaner in and it doing a little better and i also seem to have a leak in my upper intake manifold, it sounds like its coming from above the fuel rail.
Another thing, when i go over a bump, my tach comes on then off. it seems to run a little better when the tach is on, is there any connections that could come loose other than the ground on the fire wall. i will get a video of what is doing and post it on youtube if it will help you guys.
Thanks again
  #7
Old 12-15-2010, 02:01 PM
frosho's Avatar
frosho frosho is offline
WOLFMAN
frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!
Default
Quote:
This points toward a connection problem with the cam position sensor or its wiring. Try wiggling the wires while the car is idling to see if you can make the problem come and go. Look for worn spots, make sure connectors are fully seated, etc. Check the DIS connectors while you're at it.
__________________
Matt N
2006 Volvo V50 T5 AWD
1994 Ford Taurus SHO
  #8
Old 12-15-2010, 02:57 PM
Eric VerValin's Avatar
Eric VerValin Eric VerValin is offline
PiMPSKiLLET
Eric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud of
Default
Quote:
x2.. Id start at that sensor, and make sure those wires going wherever they are going are ok, and not looking shorted out or anything odd. I hit a bump a month or two ago and my car did the same thing your talking about. Turned it off, then back on and it was gone. I had a TPS code, and I think a CID code but all I can think of, is I have a little short somewhere... never happened again..
Maybe double check the bolts on the DIS.... I had a SHO not start once, and then it finally did, and the only thing I did was unplug and replug in a bunch of connectors.. ?? Stranger things have happened.... also check the little mini fuses under the hood as well.
Id say your looking for something loose or crunchy... and take care of that intake leak.. that makes problems a lot worse..
__________________
Car Domain My work
  #9
Old 12-16-2010, 08:50 PM
Registered
Default
Is the ground strap from the back of the intake to the body in place? Are the two bolts that secure the intake crossover tube (DIS mounts onto it) to the intake in place? It is critical for DIS ground.
  #10
Old 12-17-2010, 10:02 PM
SHObill's Avatar
'The Collector'
Default
Quote:
Correct! Unless you do a proper DIS ground by running a separate wire from the 2 lower DIS screws right to a strut tower screw!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
