SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 11-23-2010, 09:49 AM
Skybox2288's Avatar
Skybox2288 Skybox2288 is offline
SHO Driver
Skybox2288 is unknown at this point
Default bubbling coolant
Coolant boils/bubbles after hard driving/ thermostat reads that its not overheating though. also, i have to refill the antifreeze/coolant every couple of days. any idea what this could mean?? thank you
  #2
Old 11-23-2010, 09:54 AM
frosho's Avatar
frosho frosho is offline
WOLFMAN
frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!frosho is brilliant!
Default
Is it boiling out of the overflow tank? Sounds like it's probably a bad radiator cap.
__________________
Matt N
2006 Volvo V50 T5 AWD
1994 Ford Taurus SHO
  #3
Old 11-23-2010, 10:52 AM
gmorrell gmorrell is offline
Never been a noob...
gmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid one
Default
^^^ What he said.
Best case:
If it boils after shutdown, it's very probably a bad radiator cap. If the cooling system isn't up to pressure, the boiling point is lower than it should be, but it will usually be OK as long as there's air moving through the radiator. Once you shutdown, the latent heat in the block and heads boils the coolant, and it bubbles into the recovery reservoir, usually overfilling it, which is why you're adding coolant occasionally. Get a new radiator cap and inspect the upper and lower sealing surfaces in the radiator neck, check for debris, cracks or gouges.
Worst case:
Blown head gasket. Find a high cliff, do your best Thelma and Louise end of movie reenactment.
__________________
Gary Morrell
1985 SVO Mustang, light and fast.
1989 Taurus SHO (supercharged), heavy and fast.
1999 SVT Contour (Sedanus-Grocerygetteris-Rapidus)
"If thine IAC offends thee, pluck it out!"
  #4
Old 11-24-2010, 08:34 AM
Skybox2288's Avatar
SHO Driver
Default
ok, and when it boils it starts to burn coolant, and you can see/smell the smoke come up from the coolant tank. and the radiator cap is the one that says 'do not remove' in the front?
  #5
Old 11-24-2010, 09:11 AM
RAYJAY's Avatar
RAYJAY RAYJAY is offline
WHO ME ?
RAYJAY is a jewel in the roughRAYJAY is a jewel in the roughRAYJAY is a jewel in the roughRAYJAY is a jewel in the rough
Default
does the over flow tank smell like exhaust fumes ??? do a hydro carbon test on the coolant,
sounds like a head gasket not common but they do happen
my 1993 atx did it
__________________
1994 3.2 ATX DEEP JEWEL
1994 BLUE/GREY atx KONI /EIBACH TPR BUSHINGS H BRACE ATX
  #6
Old 11-24-2010, 10:58 AM
Default
Quote:
Yep, "Do not remove when hot", heed this or you may get steam burns. When the engine is completely cool, you can remove the radiator cap and inspect the cap gaskets and the surfaces they seal to in the radiator neck. Take the cap to an auto parts store, preferably by driving another car, and get a new one.
  #7
Old 11-24-2010, 05:31 PM
gmail gmail is offline
Registered
gmail is a jewel in the roughgmail is a jewel in the roughgmail is a jewel in the rough
Default
i vote do a leak down test on the rad.. they are more common to get a pin hole in them then anything else... at least in my experience and if it dont build proper pressure it will boil... a way to see that is use a rag and when hot take the cap part way off see if there is a bunch of pressure shooting steam and coolant out... be careful and do not remove the cap all the way just part way to see if there is pressure...
could also be the cap as stated above
  #8
Old 11-24-2010, 05:53 PM
kevinspann's Avatar
kevinspann kevinspann is online now
87 Octane
kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!kevinspann is brilliant!
Default
Quote:
Oddly enough, the Motorcraft cap on my car just says "DO NOT REMOVE", he must have a similar one.
But really, don't remove it when the coolant is hot, especially if it's boiling in there.
__________________
15s in 2015
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
