SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 11-10-2010, 12:46 AM
Terrorizer's Avatar
Terrorizer Terrorizer is offline
SHO or GTFO
Terrorizer will become famous soon enough
Default Cruise control doesn't work, light does not come on
The cruise control doesn't work on my car, it hasn't since I bought it. ITs a 1990 5 speed. When I turn cruise control on the light doesn't light up on the dash. (im assuming there is a light, lol). I checked the plastic clip that commonly breaks on the throttle but that is in tact. Anyone have any ideas?
__________________
1990 5 Speed SHO
  #2
Old 11-10-2010, 12:51 AM
jmpSHO2nd jmpSHO2nd is online now
Registered
jmpSHO2nd is spectacular!jmpSHO2nd is spectacular!
Default
Quote:
I don't think there is a dash light for the cruise control, at least not for the Gen 2 SHOs.
  #3
Old 11-10-2010, 12:54 AM
xshoel93x's Avatar
xshoel93x xshoel93x is offline
SHO driver
xshoel93x is unknown at this point
Default
im gonna check tomorrow but im fairly certain mine has a light.
__________________
1993 ATX- silver on black, full leather, alpine type s up front, kicker ks out back, rockford fosgate 400watt amp, jvc hd radio head unit. 60k done 2/26/11 @ 130k miles. no cats, no silencer cone, stang gt muffs
  #4
Old 11-10-2010, 01:13 AM
Terrorizer's Avatar
SHO or GTFO
Default
Either way, the cruise control isn't working.
  #5
Old 11-10-2010, 02:42 AM
xshoel93x's Avatar
SHO driver
Default
check fuse? start small is the best way to go
  #6
Old 11-10-2010, 06:10 AM
beaudeen's Avatar
beaudeen beaudeen is offline
BEAUDEEN
beaudeen is on the right road
Default
If your in a rust belt area, check the v-clamp that holds the 2 halves together on the vacuum can. Mine was rusted out and lost vacuum..just follow the cable down under front bumper drivers side.My 95 mtx doesn't have a cruise indicator light.
__________________
95MTX
235 km
shoshop high flow y-pipe
Quickflow Mufflers..sounds like ASS above 3800
  #7
Old 11-10-2010, 06:32 AM
SHOred SHOred is offline
Registered
SHOred is unknown at this point
Default
Do you have athird brake light? On some cars if it burns out the cruise will stop working. Also if you have a bad clockspring the cruise will quit. My cruise quit and when I replaced the clockspring it started working again.
SHOred
  #8
Old 11-10-2010, 10:28 AM
rubydist rubydist is offline
Registered
rubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud of
Default
cruise will also not work if the vss is bad, or if the switches on the steering wheel are bad. you will need to follow the troubleshooting to get this taken care of, since there are so many possibilities.
__________________
96 Pearl White Mark VIII 4.6 dohc
90 Red RX-7 convertible project.....
96 White w/ Grey F250 4x4 OffRoad extended cab
98 Green Mountaineer awd 5.0 - for sale!
03 Tan Subaru Outback 3.0
former SHOs include 94 re atx, 94 wh atx x2, 93 gr atx, 94 bl mtx, 97 bk, 98 bk, 95 gr atx->mtx, 93 bl mtx, 93 bl atx, 95 bl atx, 95 gr atx, 92 wh mtx
  #9
Old 11-10-2010, 11:42 AM
TopGunnYFZ TopGunnYFZ is offline
Registered
TopGunnYFZ is a jewel in the roughTopGunnYFZ is a jewel in the roughTopGunnYFZ is a jewel in the rough
Default
No cruise light in any of my SHO's.
__________________
1994 ATX Green/ Grey~Gone~
1990 MTX Black/Black~Plaything~
1994 ATX Blue/Grey~Ladies~
Quote:
the craptastic design of our suspension coupled with a powerful engine is not condusive to forward motion- SuperHO
  #10
Old 11-10-2010, 11:25 PM
oboytroyman's Avatar
oboytroyman oboytroyman is offline
Troy
oboytroyman is unknown at this point
Default
my cruise stopped working for a while and It was simply where the throttle cable hooks onto something. so if you see a cable that looks detached, there you go!
__________________
92 sho mtx 173k daily driver.
  #11
Old 11-11-2010, 01:54 PM
Terrorizer's Avatar
SHO or GTFO
Default
Quote:
You're probably talking about the black plastic clip that connects the cruise control thingy to the throttle cable. I'm pretty sure mine is attached, unless I'm looking at the wrong thing.
  #12
Old 11-11-2010, 03:17 PM
Registered
Default
Nope thats it both cables run to the throttle body. My '90 always has a problem with it staying hooked so i just leave it off lol.
  #13
Old 11-12-2010, 09:15 AM
Terrorizer's Avatar
SHO or GTFO
Default
Quote:
SHOred
Yeah I have a third brake light, but it is working. What's the clock spring and how can I check it?
  #14
Old 11-12-2010, 09:17 AM
Terrorizer's Avatar
SHO or GTFO
Default
Quote:
I see. Do you know of a way to test the VSS and other various switches? Or have a possible link to testing info? I have a ford service manual but it doesn't show how to test sensors and electrical stuff. I think there is separate book for that kind of stuff.
  #15
Old 11-12-2010, 10:42 AM
Registered
Default
if the vss is bad, you will get a pcm code, so check those.
the service manual has a troubleshooting section for the cruise, just follow that.
  #16
Old 11-12-2010, 09:55 PM
xshoel93x's Avatar
SHO driver
Default
ok i tested my cruise control. works but no light in dash which is weird cuz i thought i saw one before. oh well thats not the problem anyways
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
