SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 08-01-2002, 11:27 AM
NiNeTy Fo SHO NiNeTy Fo SHO is offline
No-mo-SHO Man
NiNeTy Fo SHO will become famous soon enough
Water pump replacement
My new water pump came in yesterday for my 1994 MTX. I wanted to put it on myself tonight, but was wondering what all I would have to remove in order to get the water pump out. It would save me a lot of time to not take off extra parts just to put them back on. I know it wont be quick, but I do have to go to work on friday. Its making this nice grinding sound, and I figure it would be smart to replace it.
__________________
Brandon
Current Fleet:
'06 Mercury Milan Premier
'06 Ford Freestyle Limited
'01 Kawasaki EX500
Past SHO's
'94 MTX - Moonlight Blue - Sold 7-31-07
'93 ATX - White
'93 ATX - Red
  #2
Old 08-01-2002, 11:58 AM
SilverSHO SilverSHO is offline
Registered
SilverSHO is on the right road
Ah, water pump replacement. I did this about two months after I got my SHO, and at that time I knew less than nothing about car engines, and still managed to do it right. Of course, I had help from SHOtimes.com (and Natural Light :D ), so I wasn't completely in the dark.
Link to SHOtimes water pump/CPS replacement: http://www.shotimes.com/SHO3timingCPSWPreplace.html
__________________
"This SHO is no more. It has ceased to be. It is a late SHO."
  #3
Old 08-01-2002, 12:02 PM
luigisho luigisho is offline
Registered
luigisho is a splendid oneluigisho is a splendid oneluigisho is a splendid oneluigisho is a splendid oneluigisho is a splendid oneluigisho is a splendid one
Depends on whether you got the whole unit or the partial reman. unit. I would say if you're going in there you should replace the main seal, timing belt and the crank position sensor since it's all right there already.
__________________
1990 SHO lots of wasted time and money for bolt on's-Gone to Carolina
1997 SHO-catless and clueless- Gone to the same place as my '90
1994 SHO MTX in rare green
  #4
Old 08-01-2002, 01:03 PM
No-mo-SHO Man
Thanks a lot guys. I forgot all about shotimes.com I am going to start tonight, we will see how it goes...hopefully not too bad.
I'll let ya know how it goes tomm.
A few beers might not be a bad idea... beer :D
  #5
Old 08-05-2002, 02:05 PM
No-mo-SHO Man
In a little under 6 hours, and the new water pump is installed. Thanks for the links! It helped out a lot when I got stuck. :D
  #6
Old 06-10-2013, 04:35 AM
MacEwen MacEwen is offline
Registered
MacEwen is unknown at this point
Default
Hey,
I started about doing the CPS (crank sensor) and found a seeping water pump.
I see a few options online. Does anyone have a newer working link to this water pump replacement proceedure. I got upper and lower timing covers off.
I also am geared to replace the power steering pump, as I have power steering cut out intermittantly, I've had it also spray out the resevoir.
It all looks like a pain. Can anyone respond with a picture and/or part number of water pump? I've seen different pictures on Rock Auto, and ebay.
Can Crank seal be replaced without a fancy tool? Cam seals as well?
I did get the balancer off! Holy PITA to break it loose. FYI, It is really RH threads, lol.
I own a 1994 ATX 3.2L.
-Ryan
__________________
1994 3.2L ATX SHO White on Gray. Stock. 112K miles.
  #7
Old 06-10-2013, 10:00 AM
Frisbeeguy Frisbeeguy is offline
Registered
Frisbeeguy is on the right road
Default
Go to http://shophoenixproject.com and follow the 60k maintenance procedures.
The following user says thank you to Frisbeeguy for this post:
Tommy's SHO (06-12-2013)
  #8
Old 06-10-2013, 03:46 PM
Irish Pride's Avatar
Irish Pride Irish Pride is offline
Irish Inside
Irish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond reputeIrish Pride has a reputation beyond repute
Default
Quote:
Originally Posted by MacEwen View Post
Hey,
-Ryan
You get the "Bumping The Deadest Thread Back To Life Award"! Eleven year bump. LOL
In the future dont bump a thread like this one. Just start a new and go from there. Typically, if a thread has not been posted in for a over a year they want it to stay dormant.
Now on to your problem, the link posted above for shophoenix is the best place to go to see what you are getting into. Refer to it and if you have any other questions start your own thread and we will give you all the help/info that you need.
__________________
South East SHO Club
SESHO Decals
1991 SHO + - White/Black. Fully Modded.
1989 SHO - 1 of 318 in White. 3.3 HC, Ported Heads, Tri-Flows, BBBs, EH Runners. New restoration project.
The following user says thank you to Irish Pride for this post:
TimboSHO (06-10-2013)
  #9
Old 06-12-2013, 09:33 AM
Tommy's SHO's Avatar
Tommy's SHO Tommy's SHO is offline
SHO Member #535
Tommy's SHO will become famous soon enough
Default
Wow, I remember reading this thread 11 years ago!!
Thanks for the updated link.
__________________
'95 SHO ATX, Vibrant white/mocha cloth interior, 111k miles, build date 12/13/94, LED fish-tank's & LED rear lights, remote start, mostly stock, Summer driven on Sundays....
2008 Honda Odyssey DX Taffeta white/grey cloth interior, 64k km's, daily driver.
  #10
Old 06-12-2013, 01:46 PM
msteiny's Avatar
msteiny msteiny is offline
Registered
msteiny is on the right road
Default
Hey, At least he knows how to use the search option. Kuddos.
  #11
Old 12-06-2013, 02:47 PM
theone42 theone42 is offline
Registered
theone42 is unknown at this point
Default
shotimes has been taken down but the article can be found here
http://web.archive.org/web/200509160...thold=0&sid=64
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
