SHOForum
Go Back   SHOForum > Performance Upgrades - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Electronics & Audio
Reply
Thread Tools
  #1
Old 07-14-2010, 12:24 PM
Mossdahaus Mossdahaus is offline
Registered
Mossdahaus is on the right road
Default what screws to use - sub enclosure
I just bought a JL Audio 8w0-4 to replace my old, tired, blown sub and was wondering what kind of screws to use? Also, should I drill some pilot holes for the screws when installing the sub. This is my firs ever experiance with subwoofers so please excuse my ignorance!
__________________
'95 MTX - Green on Tan
SS catted Y-pipe, Dynomax catback, K&N, removed snorkel, BBB, ported runners, 80mm MAF, LPM, UDP
Pioneer speakers & JL 8W0-4 in stock enclosure
Monroe sensa-trac with Moog CC (-1 & -.5)
Soon: SFCs, STBs, H-brace and 96+ brakes.
  #2
Old 07-17-2010, 01:46 AM
pb2themax pb2themax is offline
Registered
pb2themax is unknown at this point
Default
Depends what wood you are using. I assume it's MDF. Are you just screwing in the 8 screws around the perimeter of the sub? I'd use 1-1/4" coarse drywall screws. Try not to strip out the holes by overtightening.
  #3
Old 07-17-2010, 01:54 AM
Eric VerValin's Avatar
Eric VerValin Eric VerValin is offline
PiMPSKiLLET
Eric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud ofEric VerValin has much to be proud of
Default
Yep... I was going to say drywall screws too... might want 1 1/2 depending if that ring is fat... who knows... but drill a baby size hole... and screw it in by hand.. you can't screw it up that way.. and it would take a sledge hammer to get it out once you get 15 of those in there like that. They'll be squeaky and hard to turn in there.. but it'll hold.
__________________
Car Domain My work
  #4
Old 07-17-2010, 07:15 AM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
It's pretty easy to break the heads off of drywall screws when they bottom out on the MDF. It's what I'd use, but pilot holes are essential. Make sure the drill is in low gear (if you have a choice) and don't use a lot of speed.
If you are trying to put the sub in the stock sub box, you will need to enlarge the hole and fabricate a mounting ring that you will screw and glue to the lip of hole in the box.
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
  #5
Old 07-18-2010, 12:58 AM
the4biddendonut's Avatar
the4biddendonut the4biddendonut is offline
Hurry up meow.
the4biddendonut is spectacular!the4biddendonut is spectacular!
Default
Drywall screws work. I like to use pan head screws though.
The best thing to use are t nuts and bolts, especially if the sub is really heavy or you're going to remove the sub frequently. This is overkill for most people though.
__________________
"The computer beat me at Chess once, but it was no match for me at Kickboxing. "
  #6
Old 07-19-2010, 09:39 PM
Registered
Default
I like hurricane nuts, but they are kinda hard to install if the sub box is already built. Its best to install them before the front panel is screwed on.
http://www.parts-express.com/pe/show...umber=081-1084
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
