SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 07-13-2010, 10:22 AM
flyinbri57 flyinbri57 is offline
Registered
flyinbri57 is unknown at this point
Default Crankshaft position sensor/Timing belt
I have a 95 SHO, 3.0L with 97K miles on it, and recently it has started to buck while driving. Eventually it goes away and the check engine light goes out. I've pulled the code on it and gotten a 214 - CID. Everything leads me to believe it is the CPS. Is this assumption accurate before I take it in to get replaced? I'd do it myself but just don't have the proper tools. If anyone in the St. Louis area has any mechanics they trust/recommend, please let me know. Also, while it is taken apart, should I go ahead and replace the timing belt? The one on it is the original. Thanks for any help!
  #2
Old 07-13-2010, 10:36 AM
rubydist rubydist is offline
Registered
rubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud ofrubydist has much to be proud of
Default
If I get a code for the cam sensor, then I change the cam sensor, not some other part. The symptoms you describe can be caused by the cam sensor failing, so why not change the part that the code tells you is bad?
__________________
96 Pearl White Mark VIII 4.6 dohc
90 Red RX-7 convertible project.....
96 White w/ Grey F250 4x4 OffRoad extended cab
98 Green Mountaineer awd 5.0 - for sale!
03 Tan Subaru Outback 3.0
former SHOs include 94 re atx, 94 wh atx x2, 93 gr atx, 94 bl mtx, 97 bk, 98 bk, 95 gr atx->mtx, 93 bl mtx, 93 bl atx, 95 bl atx, 95 gr atx, 92 wh mtx
  #3
Old 07-13-2010, 10:50 AM
Registered
Default
Pardon my ignorance....I've been told both could cause it, so I'm not just deciding to change another part because I feel like it. That's why I'm asking questions on here from people with a higher level of intelligence and experience than myself. Thanks again for the advice
  #4
Old 07-13-2010, 11:15 AM
gmorrell gmorrell is offline
Never been a noob...
gmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid onegmorrell is a splendid one
Default
Try driving it for a bit with the CID unplugged - really.
It will start and run, you may have to try to crank it a few times for the DIS and EEC to "guess" the injector and ignition synchronization - it's designed to do that if the CID goes TU. If the bucking goes away, then you probably have a bad CID.
Yeah, it could be the crank sensor, but the CID replacement "level of difficulty" is 1, the crank sensor replacement "level of difficulty" is near 1 0. Let's verify or rule-out the CID first.
The procedure for starting with the CID disconnected:
1. Key-on, crank.
2. If it doesn't start, key-off. Go back to 1.
You must key-off in between cranking attempts.
__________________
Gary Morrell
1985 SVO Mustang, light and fast.
1989 Taurus SHO (supercharged), heavy and fast.
1999 SVT Contour (Sedanus-Grocerygetteris-Rapidus)
"If thine IAC offends thee, pluck it out!"
  #5
Old 07-13-2010, 11:25 AM
riden2low riden2low is offline
Registered
riden2low is unknown at this point
Default
Well I just did my crankcase sensor. I replaced the timing belt and cam and crankshaft seals while I had it opened up. The water pump was replaced and why the previous owner did not do the other I have no idea. My crankshaft seal was starting to leak, the camshafts, two were ok but the camshaft sensor was leaking to the point I thought it was the power steering as the camshaft sensor sits just above the pump. So yes, if you can do it, do it all at once and be done with it. I am a first time owner of a 93 SHO and found this site which has help out a lot. Take their advice.
  #6
Old 02-10-2011, 01:23 AM
SHOtime2511's Avatar
SHOtime2511 SHOtime2511 is offline
CGP
SHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond repute
Default
I think you will find replacing the cam sensor will fix the issue.
__________________
2009 Cheby Corvette ZR-1
2009 Honda Accord V6 MTX
1990 Ford Taurus SHO turbocharged 3.2L
________________________________________
Brian
The following user says thank you to SHOtime2511 for this post:
walser (02-11-2011)
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
