SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 05-07-2003, 09:33 PM
haydenm315 haydenm315 is offline
Registered
haydenm315 is on the right road
Intake Manifold Getting Very Hot
I finished putting my car back together today and drove it for no more than 10 minutes. The crappy inside temperature gauge read a comfortable number, however the manifold was too hot to touch. Acceleration was good but the car seemed to be lacking low end. I just found out that I forgot to plug in the plug that controls the secondaries. Will this cause my manifold to get hotter than it should? I also noticed that I could remove my radiator cap and there wasn't any pressure in there. I did let it cool for atleast 10 minutes before opening up the cap. How long should there be pressure in there?
__________________
93 hwyte mtx SHO
  #2
Old 05-07-2003, 09:42 PM
SolidState SolidState is offline
No Mo SHO
SolidState is a name known to allSolidState is a name known to allSolidState is a name known to allSolidState is a name known to allSolidState is a name known to allSolidState is a name known to all
I noticed that when my car is moving, or immediately after (!) the manifold is cool to the touch.
However, leave it sit for a while and it heats up nice. I am guessing that this is because no cool, fresh air is flowing through it, around it and the heat fromt he engine is rising...
__________________
Teg
2008 Taurus X Limited AWD - 50k
2002 Volkswagen GTI 1.8T - 115k
  #3
Old 05-07-2003, 09:43 PM
Machspeed's Avatar
Machspeed Machspeed is offline
Infiniti I30t
Machspeed is on the right road
Im assuming having the secondaries closed would restrict airflow there fore making your manifold hotter. Even when your secondaries are open your intake gets pretty hot normally. As for your radiator cap, there should be pressure for at least 30 minutes. I remeber opening my cap after 2 hours and there was pressure.
__________________
I drive an 2000 infiniti I30t now...
  #4
Old 05-07-2003, 10:02 PM
Registered
Quote:
FOR SHO:
I'm a little concerned about the lack of pressure. Maybe I've got a minor leak somewhere, though I didn't notice a loss of coolant before taking it apart this time. If the plug for the secondaries is not plugged in, do the butterfly valves stay open or do they close?
  #5
Old 05-07-2003, 10:09 PM
rendyx rendyx is offline
Registered
rendyx is on the right road
Quote:
haydenm315:
Quote:
FOR SHO:
Open, so I don't think that would cause it. I'd check the coolant hoses to the intake and make sure they are okay. Good luck!
__________________
-Pat
05 Brilliant Red Audi A4 1.8T Ultrasport - From all the way in the back of the food stamp line
  #6
Old 05-07-2003, 10:36 PM
shojuan shojuan is offline
Registered
shojuan is on the right road
My intake gets very hot after driving and it has always been like that. When the car was new the intake got hot. Yeah sometimes I think that maybe my intake gets hotter than it should. But I'm sure it's OK. If I ever get pissed enough about it I'll just get some phenolic intake spacers and a machined intake manifold from Josh at SHONUT Performance. Hot intake means it's acting as a good heatsink though! :D
Re: the pressure in the cooling system hoses. Not just the SHO but with other cars I've noticed a variety of behaviors. Sometimes it will hold pressure for a good length of time, sometimes it won't. Of course a leak in the system will cause the pressure to drop quickly, but assuming you have no leaks there are several variables at work hear. The most important is how much heat flow do you have between the coolant and the metals the coolant is exposed to. With scaled up cooling passages in the heads heat flow will be relatively slow. With nice clean, scale free passages the heat flow will be much greater. A hot intake suggests to me good heat flow from the coolant to the metals. I know it might be counter-intuitive but assuming you don't have any leaks the behavior you're describing might just be an indicator that your cooling system is in good health. You are right for being concerned. It's a wake up call to check for leaks:
  • <font size="2" face="Verdana, Helvetica, sans-serif">Is the coolant in the recovery bottle getting lower by any noticible amount day to day?
  • <font size="2" face="Verdana, Helvetica, sans-serif">If the recovery bottle doesn't change did you check to make sure the radiator is full when the car is cold? You shouldn't have any air space in there.
  • <font size="2" face="Verdana, Helvetica, sans-serif">Is your cap in good shape even if the other stuff checks out? If in doubt get a new cap. They're cheap.
<font size="2" face="Verdana, Helvetica, sans-serif">If those things check out and you're not running coolant that is more than a couple years old then relax. Your cooling system is probably in good health.
__________________
Rick
89 MTX 200,000 miles. | Quaife, CAI, SS pipe, Hidden Hitch | Tokico sluts, Eibach swings, FPS arms, Jose Shift|
*____________| ruined paint, fresh leather, and lead junk in the trunk |TPR bush, blowup roof rack, and popo grill up front|
*____________| CF hoody, extrude ho, BBB | Kirk's mounts, Al SFB, and TCE
94 ATX 121,000 miles. "The White Beater" pristine paint and leather. Stock except for tiny 96 brakes.
SHOforum TOS*_ ___ _
SHOforum Guidelines*__*"How To" Guides
SHOforum FAQs*_ ____ _ *How to read SHO diagnostic codes
  #7
Old 05-07-2003, 11:22 PM
Registered
Quote:
rendyx:
Quote:
haydenm315:
Quote:
FOR SHO:
I believe more coolant than I thought leaked out when I took the manifold off to do some work. THe level kept dropping slowly with the radiator cap off with the car off. I kept filling it and it seems to hold pressure now and the manifold doesn't get as hot. The plenums get warm but the runners are still getting hot. I believe this is normal though. My loss of down low power was most definately the unplugged secondary line. All seems cool now.
  #8
Old 05-07-2003, 11:35 PM
Registered
Quote:
shojuan:
My intake gets very hot after driving and it has always been like that. When the car was new the intake got hot. Yeah sometimes I think that maybe my intake gets hotter than it should. But I'm sure it's OK. If I ever get pissed enough about it I'll just get some phenolic intake spacers and a machined intake manifold from Josh at SHONUT Performance. Hot intake means it's acting as a good heatsink though! D
I feel better now, though it seems cooler now that the coolant level has evened out and I plugged the thing in the allows the secondaries to function correctly. Thanks for the info. Sometimes I get senile and think things were different before I messed with it.
As you should know from my sig, I've put some time into making the motor work harder with the stage II cams, ud pullies, and the ypipe. When I did this, I was sure to do a very thorough cooling system flush with a seperate heater core flush as per the helms manual instructions. This seemed to make my car run a bit cooler. THere is still some scaley stuff visible at the neck of my radiator, but I did my best to clean the system out. I think it's working just fine for now. Maybe a new radiator is in store a year or so down the road.
My father's favorite saying when I was a kid.... "get your head out of your ass!!!!" Constant grilling like this has caused me to become more alert of my surroundings and responsibilities. I'm very responsible when it comes to maintaining cars and detecting problems. I can attribute some of this to him, some to shoforum, and some to my love of cars.
Quote:
[*]Is the coolant in the recovery bottle getting lower by any noticible amount day to day?
It has always remained fairly consistent.
Quote:
[*]If the recovery bottle doesn't change did you check to make sure the radiator is full when the car is cold? You shouldn't have any air space in there.
Every morning before I set off on whatever the day holds, I check oil and the level in the radiator. It's never been low, with the exception of today after I put everything back together. I topped it off a few times and it kept dropping a tiny bit. I think it may just be air though. I'm about to go out again. I'll make sure to check it. thumb
Quote:
[*]Is your cap in good shape even if the other stuff checks out? If in doubt get a new cap. They're cheap.
The coolant cap was a low blow to me. I just read and saw on tv recently that it should be replaced every 2 years? I've never replaced my cap. It's probably a good idea to do so. Who knows what the previous owner did.
[quote
If those things check out and you're not running coolant that is more than a couple years old then relax. Your cooling system is probably in good health.[/QUOTE]
I think my cooling system is ok. On a hot day, if I'm sitting still for a while and am doing city driving, the gauge will get up to the bottom of the O in normal before the fan turns on. The gauge temperature level drops fairly quickly and the fan shuts off in maybe 30 seconds. If I'm driving at a moderate pace or on the highway, the needle will sit around or slightly below the M in normal. Where the gauge on the cluster sits is usually not a good indicator due to accuracy discrepencies. I've been meaning to get an aftermarket gauge cluster soon. I want oil pressure, exhaust temperature, oil temperature, and/or water temperature. Do you recommend any gauge sets?
  #9
Old 05-08-2003, 05:04 PM
sdpatt sdpatt is offline
sdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to allsdpatt is a name known to all
There will always be a certain amount of thermal energy (heat) that is conducted from the very hot heads up through the intake runners that are solidly bolted to the heads with a metal, heat transferring gasket. While the engine is running and cool air is being drawn in to feed the cylnders and flow over the external surfaces of the intake manifold, the plenum chambers will usually stay quite cool, but never cooler than ambient air temperature.
After the hot engine is shut down, a significant amount of thermal energy is conducted through the runners and additional heat is convected up from the hot block and exhaust manifolds to cook everything under the hood as the engine tries to dissipate its heat. This is usually called "heat soak" and takes a great deal of heat transfer to resolve.
If you start a cold engine and drive on the highway where a constant supply of fresh air is supplied to the intake path and under the hood, the intake will be comfortably cool to the touch if you quickly pull over and lift the hood. Let the car idle for a few minutes and the intake will most likely become too hot to touch.
If the cooling system was not liquid solid, the pressure may be reduced more rapidly than expected due to the contraction of the vapor space. Another possibility is that the extra pressure from the cooling system due to the heat soak after engine shut down caused the radiator cap to do its job and vent the expanding fluid to the expansion bottle. It is not until the coolant lowers its heat and contracts sufficiently to create a vacuum that the coolant will be again drawn back into the system from the expansion bottle.
Unless you see fluid on the ground, your cooling system is doing just what physics tells it to do. Relax.
__________________
Helping to keep the SHO on the road,
Scott
1991, 432K miles, and rolling...
In-car Track Video: Laps at TWS
  #10
Old 05-08-2003, 09:20 PM
Registered
Thanks scott. I'm now resting easy.
  #11
Old 05-08-2003, 09:24 PM
Bluto Bluto is offline
Registered
Bluto is on the right road
What would you guys think of a CO2 discharge that can lower the intake temp to -75* F?
This is just a brain far..storm.
I ran across a intercooler cooler, that could actualy work on our intakes. The CO2 would be discharged onto the intake, not in it.
__________________
94 ATX 161,000 emerald green.
Transgo kit -Super large ATX cooler-Rad Aluminum SFB's-Butler Naca duct- cold air delivery to a shielded cone filter. Oh...and the purple pill.
15.43 @ 91.29 N/A
14.06 @ 99.91 N2o
  #12
Old 05-08-2003, 10:39 PM
93EmeraldMTX 93EmeraldMTX is offline
Registered
93EmeraldMTX is on the right road
usually the only part of my intake that is warm at all after i drive it is the runners, the rest is cool to the touch, unless it has been idling for an extended period or been shut off for a while.
__________________
SHOless
  #13
Old 05-08-2003, 11:18 PM
Quote:
Bluto:
Temperatures to that extreme would cause tremendous thermal stresses on the intake and heads due to the temperature difference between the 200+F heads and the -75F intake. You could actually crack the metal from these stresses.
  #14
Old 05-09-2003, 08:00 AM
Registered
Thanks for the voice of reason scott.
It would certainly cool down the air in the runners.
They do put this on aluminum intercoolers, but they don't have the same structural stress.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
