SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 10-20-2009, 12:09 PM
JVANBUREN's Avatar
JVANBUREN JVANBUREN is offline
Registered
JVANBUREN is on the right road
Default TCC electrical Fault code
I just finished putting an engine in a 98 SHO and I am getting the TCC electrical fault code. The car was sitting for quite some time but the tranny appears to be a fresh rebuild, with all new seals and it is very clean and the fluid was new but now that the car is running the O/D light flashes and I get this code, so I swapped The TCC solenoid and that is not the problem and the car is still like jerking at a constant 55 or any speed around there when your cruising at the same speed. Thanks for any input!
__________________
[/SIGPIC]Justin Van Buren
96 Ebony Satin, welded, tinted
96 Rose mist, welded
91 MTX Plus, eibachs
97 welded, black everything, true duals.
http://www.cardomain.com/ride/2812143/1
94 MTX LPM programmer, catless y-pipe
97 welded (modded) SOLD
http://www.cardomain.com/ride/2460264/1
92 MTX stock R.I.P.
  #2
Old 10-20-2009, 12:12 PM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Tire Wall
Mr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond reputeMr Anonymous has a reputation beyond repute
Default
Quote:
Which TCC solenoid did you use?
'98 & '99's require the solenoid with the blue connector. Using a solenoid with the white connector will cause the symptoms and DTC you describe.
__________________
Chris - 2002 V8 MTX Black, 2001 F-250 V-10 Black
Click here to read and understand EEC-IV Diagnostic Trouble Codes by yourself!
Never buy a phone that is smarter than you are...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
