SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 10-13-2009, 09:57 PM
siebert37 siebert37 is offline
Registered
siebert37 is unknown at this point
Default Oil cooler gasket
Hey guys, wondering if anyone has attempted to locate a replacement gasket for the oil cooler. Its the one that goes in between the oil cooler adapter and engine. I called up my local ford dealer and he said that they no longer make it and he could not find one anywhere. Also anyone had any luck fixing the leaky o-ring in the oil cooler. I know there was a write up on v8sho.com but the o-rings mentioned do not seem to do the job. Thanks in advance!
  #2
Old 10-13-2009, 10:26 PM
E1 v2 E1 v2 is offline
crash tested
E1 v2 is spectacular!E1 v2 is spectacular!
Default
http://www.v8sho.com/SHO/RepairingaLeakyOilCooler.htm
5 years and the O rings mentioned in this link are still sealed tight.
There WAS a problem with the teflon rings mentioned in this thread -
http://www.v8sho.com/SHO/OilCoolerOring.htm
You DON'T want the white ones.
__________________
Eric Lehmann
97 Ebony Satin 42k - Welded - With the Angels now so I don't have to be - Long live the Garage Queen
97 Ebony Satin 185k - Resurrected, Welded, experiment successful
96 Charcoal Grey - 145k - resurrected, Welded
96 Rosemist - 2006 Best of SHOw Popular Vote, 2007 Best Gen III - 73k - Welded
96 Medium Willow Green - 122k - resurrected, Welded - Unsupercharged :( pending M 112 Project
  #3
Old 10-14-2009, 12:39 PM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
Default
Looks like the poster is looking for the adapter to block not cooler to adapter O rings.
I may have one.
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
  #4
Old 10-20-2009, 09:37 PM
Registered
Default
Thats exactly what Im looking for shoz. If you do have one how much do you want for it?
  #5
Old 10-21-2009, 12:46 PM
SHOZ123's Avatar
Registered
Default
I guess I need to see what it looks like to be sure. The gaskets I have are not identified.
  #6
Old 10-22-2009, 12:28 AM
midnightauto's Avatar
midnightauto midnightauto is offline
THE CHOP SHOP
midnightauto will become famous soon enoughmidnightauto will become famous soon enough
Default
The last new ones I had came in complet gasket sets from ford. A year ago they were $1350 I reuse them if they are not damaged spray it down with Hi-Tack after cleaning.
__________________
Ray Davis
98 Silver frost (new project)
Black 99 project car (sold)
http://www.cardomain.com/ride/2556346
Black 95 Mustang GT conv. (sold)
http://www.cardomain.com/ride/2563006/1
  #7
Old 05-13-2010, 11:04 PM
joeynovak joeynovak is offline
Registered
joeynovak is unknown at this point
Default Is the 3.2L Oil Cooler Similar?
Hey Guys,
I am using a 3.2L from a '93 in a project car, and a lot of oil is leaking from between the block, and the oil cooler. I went to the link in the above, and the part with the 30mm nut looks very similar to what I have. Can it be removed the same way and a new gasket installed?
Thanks!
Joey
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
