SHOForum
Go Back   SHOForum > Generation 4 SHO (2010) > Generation 4 - General Discusson
Reply
Thread Tools
  #1
Old 09-17-2009, 02:56 PM
beefcake beefcake is offline
Registered
beefcake will become famous soon enoughbeefcake will become famous soon enough
Default ???? I was thinkin!!! I wonder if my drag wheels will fit???
the more i think about it, it's the same bolt pattern. I gotta think the 17" front alumastars oughta fit for sure, if they can clear an 03/04 cobra brake right?
i don't know about the rears though, being 15" with that suspension they'll probably hit
anything for a 12 though lol
maybe i'll test fit tonight
other questions is, how much power goes where?????
who knows??
will the skinnies just spin. gotta be a hell of a weight reduction off the front
__________________
My Site - http://www.beef-cake.net
Worlds first and fastest 12sec SHO Video - http://www.youtube.com/watch?v=m6u3lUxwl_o
  #2
Old 09-17-2009, 03:26 PM
sho2see sho2see is offline
sho2see
sho2see is a jewel in the roughsho2see is a jewel in the roughsho2see is a jewel in the rough
Default
So are you saying your gonna run 2 different tire sizes? Front diff. From the rear
__________________
94 MTX Green-119k
  #3
Old 09-17-2009, 03:38 PM
Racer X Racer X is online now
SHO Pilot
Racer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud ofRacer X has much to be proud of
Default
If the wheels are different diameters between front and rear, the AWD system is going to have a fit.
If it doesn't break outright, that is.
__________________
1992 Taurus SHO 3.2L MTX
- Modded.
1992 Ford Taurus SHO MTX - Isabel
Quote:
Originally Posted by Mels View Post
I'd rather make a paper airplane out of my money and toss it off a bridge into the water than waste it on any Accel ignition product - at least I'd be able to enjoy watching it do what I'd intended it to...
  #4
Old 09-17-2009, 04:26 PM
Registered
Default
yeah, if the overall height is not the same, that'll be a problem, didn't think about that
the 20's are prob 28" tall and i know the skinnies around around 26", wouldn't work unless the slicks would clear too
  #5
St Louis SHO's Avatar
St Louis SHO St Louis SHO is offline
Sig lines suck!
St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!St Louis SHO is brilliant!
Default
It aint gonna make it any faster with sticky tires. IT's already AWD and weighs 4000lbs.
__________________
There are two things in life where penetration is really important.....and one of them is welding.
Quote:
Originally Posted by Bob Gervais View Post
You're thinking outside the box. Which, in turn, will almost guarantee you'll never touch one.
Quote:
Originally Posted by SHOCH View Post
This thread is like riding behind Ryan in the Ninja Turtle in NH, everyones off track now!
The Following 2 Users Say Thank You to St Louis SHO For This Useful Post:
jthod (09-17-2009), zblackbeast (09-17-2009)
  #6
Old 09-17-2009, 04:59 PM
Registered
Default
Quote:
this isn't my first go round down the dragstrip.
weight is everything, every 10lbs of rotational weight you pull is like pulling 100lbs of fixed weight off the car to a certain point.
if you can pull 20-25lbs off each front tire and 15 or so off each rear, your talking about pulling 70-80lbs of rotational weight
that could easily translate into 2-3 tenths maybe more
The following user says thank you to beefcake for this post:
slickn56 (09-18-2009)
  #7
Old 09-17-2009, 05:23 PM
tardboy21's Avatar
tardboy21 tardboy21 is offline
Registered
tardboy21 will become famous soon enoughtardboy21 will become famous soon enough
Default
if the diameter of the tires is different, won't the AWD always think the smaller pair is slipping.
where are the sensors that control this?
they will be rotating at a quicker speed than the larger set. How it will adjust is a good question. Would putting a little bit bigger tires on the back cause the AWD to try and put more force to the back wheels?
try it out and let us know if something breaks.
__________________
92 Black/Black - 185k
98 Red/Tan (stock) (RIP)
99 Red/Grey - 220k
Life is short so go on and live it, cause the chicks dig it!
  #8
Old 09-17-2009, 05:49 PM
pitaSHO's Avatar
pitaSHO pitaSHO is offline
Right on...
pitaSHO is spectacular!pitaSHO is spectacular!
Default
To OP. Do you have a 10 FT SHO or a 2010 SHO? Hyphen's in the wrong spot in your sig pic, dude.
Chris K.
__________________
94 Opal Frost ATX - Sold
91 Black/Black Plus - Sold
89 Current Red - Sold
95 White MTX - 2008 Convention Silver Award Winner - R.I.P 7/29/08
93 Black/Black MTX - Current DD
91 Oxford White Plus - Quaife, TwEECer, Coil-overs, 3.2L
Quote:
Originally Posted by SuperHO View Post
you, sir, are an asshat.
Quote:
Originally Posted by hawkeye18 View Post
Bumblebee called.
He wants his illegitimate love child back.
  #9
Old 09-17-2009, 06:02 PM
Sig lines suck!
Default
Thanks for the unneccessary explanation, but its not my first rodeo either....
You aint gonna get 2-3 tenths that way.
The following user says thank you to St Louis SHO for this post:
SHODWN (09-19-2009)
  #10
Old 09-17-2009, 06:42 PM
Registered
Default
if you don't think knocking nearly 100 pounds of weight off your tires will get you at least .2 then you can't have done much serious racing
100 lbs of fixed weight should get you .1 rotational that will at least double, at least
  #11
Old 09-17-2009, 06:58 PM
SHO U UP's Avatar
SHO U UP SHO U UP is offline
SHO Guru
SHO U UP will become famous soon enough
Default
Dude, if this guy has a Termi and has been to the track, then he basically knows his stuff. Being a fellow SVT owner, I can vouch for shaving off weight bro. Lose some poundage on that SHO and let 'er ass eat! Then, like the other guy(s) said, let us know what breaks. Good luck beefcake, BEEFCAKE!!
  #12
Old 09-17-2009, 07:08 PM
hawkeye18's Avatar
hawkeye18 hawkeye18 is online now
LPWS Master
hawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond reputehawkeye18 has a reputation beyond repute
Default
how exactly do you figure losing weight doesn't convert into a lower time...?
__________________
Jason H, AT1(AW), USN 2002-present (95 ATX)
Quote:
Originally Posted by Shoaz View Post
When all you have is a hammer, all problems look like nails.
Wanna know what I'm doing right now? I'm operating what's behind this link.
  #13
Old 09-17-2009, 07:15 PM
kikkinasphalt's Avatar
kikkinasphalt kikkinasphalt is online now
WTHDamnGuy
kikkinasphalt has much to be proud ofkikkinasphalt has much to be proud ofkikkinasphalt has much to be proud ofkikkinasphalt has much to be proud ofkikkinasphalt has much to be proud ofkikkinasphalt has much to be proud ofkikkinasphalt has much to be proud ofkikkinasphalt has much to be proud of
Default
hmmmm
how many sun 12 second cars have you had?
funnay
stock wheels on my z28 DR's - 11.30
draglights on my z28 with DR's - 11.31
back to back passes
i doubt you will pick up 3 off the wheels. but if you do.. cool
afwiw St Louis SHO has spent plenty time on the tarmac
__________________
"Do You Have a Cheese Grader?"
  #14
Old 09-17-2009, 07:16 PM
SHO U UP's Avatar
SHO Guru
Default
Uh, I hope you aren't directing that to me there bro. I'm agreeing with the guy for crying out loud. Maybe you're asking that other guy. Yeah, that's gotta be it.....
  #15
Old 09-17-2009, 07:17 PM
WTHDamnGuy
Default
it du.
but going to lighter wheels isnt likely going to net him 3 10's
  #16
Old 09-17-2009, 07:40 PM
Registered
Default
Quote:
Quote:
Originally Posted by kikkinasphalt View Post
hmmmm
funnay
back to back passes
how many 12 sec cars, not too many to be honest with you.
i did have a 99 cobra than ran 10.50's
and an 01 lightning that ran 11.8's @ 5200 lbs, oh yeah, and i won 4 national events with that one back in 02 and was featured on espn a few times
then there was my 90 s/c gt that ran 11.9's
oh wait, then my 04 cobra than went 11.2's
shit i forgot, then i had my other 01 lighning that ran 10.7's at around 5100 lbs
lets see what else, oh yeah, my 06 gt than ran 11.9's, then there was the 08 gt500 after that, i think it went 11.17's, then my 08 corvetter that went 10.8's, then the 04 mystic cobra i just sold that went 11.0's.
oh yeah, and the 2 hayabusas than went 9.9's, to 9.8's, and lest we not forget the turbo hayabusa that went 8.6's.
so your right, no 12 sec cars
Toolman (09-18-2009)
  #17
Old 09-17-2009, 08:09 PM
Registered
Default
right click and save as
http://beef-cake.net/beefcake1051.mpeg
10.8
http://videos.streetfire.net/video/B...run_641181.htm
the 10.9 the car sounds better here though
http://videos.streetfire.net/video/B...run_641218.htm
http://www.youtube.com/watch?v=ypOH5aOBBsY
here is the 10sec lightning, it went 10.9's driving it to the track on dr's, it was pretty sick, built motor, stage 3 heads and cams, ported blower @ 16psi plus 100 shot, no vids though. i removed the factory interior and put in corbeaus, and then tapped the holes in the floor and put an expedition console in (the expy's have the same chassis, so the holes were there, just needed tapping)
this is all i could dig up real quick, maybe i'll find some more later
SHO U UP (09-17-2009)
  #18
Old 09-17-2009, 08:18 PM
Registered
Default
hmmmm
funnay
back to back passes
found a couple of espn vids
here was an interview they did with me
right click and save these please
http://www.svt-lightning.com/richmedia/espngeorgia.mpg
here is another win on espn
http://beef-cake.net/espnmaplegrove.mpg
and another
http://beef-cake.net/espnms2002.mpg
this was a nice one from that same race
http://beef-cake.net/2002modshootout.mpg
maybe i can join your club now kik
  #19
Old 09-17-2009, 08:20 PM
SHO U UP's Avatar
SHO Guru
Default
SICK ass rides bro! And that L looks just like mine. Fast and silver....
  #20
Old 09-17-2009, 09:08 PM
hawkeye18's Avatar
LPWS Master
Default
It is. Don't worry about it lol.
it du.
Now that I can agree with. It's not impossible, just highly improbable.
  #21
Old 09-17-2009, 09:30 PM
SinisterSHO's Avatar
SinisterSHO SinisterSHO is online now
Registered
SinisterSHO is a name known to allSinisterSHO is a name known to allSinisterSHO is a name known to allSinisterSHO is a name known to allSinisterSHO is a name known to allSinisterSHO is a name known to all
Default
someone say gangbang?
__________________
Steven
93 Black/Grey MTX - winter beater with '96 brakes
92 Black/Black - trunk full of expensive parts
The following user says thank you to SinisterSHO for this post:
frosho (09-17-2009)
  #22
Old 09-17-2009, 10:54 PM
Sig lines suck!
Default
My dick is bigger.....
  #23
Old 09-17-2009, 11:06 PM
Registered
Default
i was going to say this.
St Louis SHO (09-27-2009)
  #24
Old 09-17-2009, 11:21 PM
NEp8ntballer NEp8ntballer is offline
Registered
NEp8ntballer is a name known to allNEp8ntballer is a name known to allNEp8ntballer is a name known to allNEp8ntballer is a name known to allNEp8ntballer is a name known to allNEp8ntballer is a name known to all
Default
from what I've heard the 2010 has a front end bias so skinnys up front isn't the greatest idea ever. I'd get a set of lighter, fairly wide wheels and shorten the diameter to get a gear reduction that way. the speedo will be off though.
  #25
Old 09-18-2009, 12:26 AM
SHO Pilot
Default
Quote:
The '10 SHO has a 90% rear bias, from what I recall being discussed by the drivetrain engineers.
  #26
Old 09-18-2009, 12:38 AM
SHOspazz92's Avatar
SHOspazz92 SHOspazz92 is offline
Banned
SHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond repute
Default
James, I want to have your children and all, But I don't agree with you one bit.
I would bet a SAMMICH that Dumping 20'' 35 Pound wheels for a set of 18'' 20pound wheels on all four corners would certainly give him .2 tenths or more at the strip. On my a old White 92 I had, I ran it with a set of 18'' wheels...I don't recall the weight....but they were HEAVY. I ran a 15.2@96.1 MPH with a 2.3 60' Time. The next week i went back with a set of Slicers on and ran a 15.0@94.9 (Lost some MPH by going with the Smaller 16'' wheels) with a exact 60' of 2.3. The weather was even spot on with the previous week. This happened more then once.
I'm not trying to say you don't know what your talking about James but I probably have 100+ Runs down the strip with all kinds of different setup's in SHO's. Doing stuff as simple as pulling out a 50+ Pound passenger seat has always netted me times at least 1-2 tenths faster. Saving nearly 60 pounds of weight from the wheels will certainly make a difference.
-Sam
__________________
92 Emerald Green 3.0 MTX - Caged, Cam's, Gutted and Sprayed with never enough Tire - His - **Click here to see it!**
92 Emerald Green 3.2 MTX - Oil Burning, Daily driven, smooth shifting - Hers
89 Titanium 3.0 MTX - Lightly Modded and damned near perfect - Ours
03 Nissan Frontier - Daily Driven
  #27
Old 09-18-2009, 01:53 AM
WTHDamnGuy
Default
too long did not read.
but i had a typo, it should have said sub 12 second cars.
and re read what i said. i said i doubt you will but if you did cool.
  #28
Old 09-18-2009, 02:28 AM
bigblock bigblock is offline
Registered
bigblock is spectacular!bigblock is spectacular!
Default
im sorry, but that was some serious pwnage up above beefcakes post... just saying
__________________
93 red/gray mtx 3.2:restoring with some extras :)
90 red/tan mtx:sho shop y pipe, 70k miles!
http://california.shoclub.net/forum/..._vehicle&VID=5
http://california.shoclub.net/forum/..._vehicle&VID=6
  #29
Old 09-18-2009, 03:02 AM
All-Or-Nothing All-Or-Nothing is offline
Registered
All-Or-Nothing has a little shameless behavior
Default
LMAO Kikkinasphault got owned again....
  #30
Old 09-18-2009, 10:32 AM
Registered
Default
well, unfortunately i'm not psychic to know what you "meant" to type, i can only comment on what you actually typed.
when i was competing with my lightning nationally i regularly kept 200lbs of ballast with me. i would look at sat days qualifying weather and estimated weather of sunday to determine when and where to use the ballast.
i'd use those ballast in 50lb increments. weight is the same as elevation. everything affects whats going on. every 100 ft of elevation is roughly .01 in the quarter, 1000ft is roughly .1
why do you think heads up classes run weight requirements.
weight has a ton to do with what your gonna run, and thats just common sense. and rotational mass affects it even more. why do you think guys do things like lightweight brakes, alum driveshafts, drag wheels. it's all for e.t.
and again, on a heavy 20" wheel. a halfway decently light wheel would def get you a minimum of .2,
i'd say a set of even 20" forged wheels in the same size would get you .1
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2009, SHOForum.com
This forum is not affiliated with Ford Motor Company
