SHOForum
Go Back   SHOForum > Performance Upgrades - Gen 1 (89-91) & Gen 2 (92-95) > Tuning ~ Supercharger ~ Turbo ~ Nitrous Upgrades
Reply
Thread Tools
  #1
Old 07-29-2009, 09:15 AM
SHOWYA SHOWYA is offline
TurboSHO Member
SHOWYA will become famous soon enough
Default Lightning 90mm MAF on Turbo SHO. HELP!
Plugged the Calibration on the Tweecer and it just wont stay running.
Can anybody send me a working calibration just so i can at least get it running and work from there.
Thanks!
__________________
MOD'S:
YUP! its BOOSTED!
(and still missing a few mods)
http://www.cardomain.com/ride/408668/1994-ford-taurus
  #2
Old 07-29-2009, 11:02 AM
yamahaSHO yamahaSHO is offline
E85 whore
yamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond repute
Default
What else have you done with the tune? Are you SURE you have the right MAF curve?
__________________
-Jason
No mo SHO.
Want to run on E85?
Click for my YouTube videos
  #3
Old 07-29-2009, 11:59 AM
Sho Amo's Avatar
Sho Amo Sho Amo is offline
SmkTyresntDrugs
Sho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud ofSho Amo has much to be proud of
Default
what injectors are you running? also, try putting the tune on selection 4. i had mine on 1 and it would never work. i dunno why i tried 4 but it worked.
__________________
NE FI Sho's count rising...
  #4
Old 07-29-2009, 04:03 PM
Toolman's Avatar
Toolman Toolman is offline
Toolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond reputeToolman has a reputation beyond repute
Default
What type of connector are you using? Did you wire one in, are buy an adapter?
  #5
Old 07-29-2009, 04:35 PM
E85 whore
Default
For the MAF? Cut and OBD-II MAF connector off of a junk yard car, cot off stocker, solder and heatshrink into place. It is a straight through design. I did this back when I first SC'd my car in 2005. I originally had the line long enough to go to across the engine bay and into the fender (draw-thru MAF).
  #6
Old 07-29-2009, 10:23 PM
ycode90's Avatar
ycode90 ycode90 is offline
Registered
ycode90 will become famous soon enoughycode90 will become famous soon enough
Default
Thread jack . How was the draw thru ?
__________________
DD 89' CresSupra.
WT 85' F-350 Diesel.
SHO- several in the yard.
  #7
Old 07-30-2009, 05:03 PM
92sho16's Avatar
92sho16 92sho16 is offline
boosted
92sho16 is spectacular!92sho16 is spectacular!92sho16 is spectacular!
Default
Thanks!
Im using the 90mm lightning. I havent had that problem, have you tried raising the idle? Another thing to try is turn the tweecer switch to another position and then back to the one being used then write the tweecer.
__________________
'12 Volt
- Daily
'65 Factory Five Roadster
- SHO powered
'92 Blue MTX
- Running again, misfiring at the moment
  #8
Old 07-31-2009, 06:17 PM
TurboSHO Member
Default
I have 50lb injectors 50/60 for low and high slopes.. And have the adapter from shonut performance. My idle is at 1050rpm ... What it does is that it hunts for the idle then it eventually dies.
Can any body with a turbo sho post the original maf calibration and maybe one that has been calibrated so i can see the difference.
  #9
Old 07-31-2009, 06:24 PM
E85 whore
Default
Have you had a look at this thread? http://www.shoforum.com/showthread.php?t=100584
  #10
Old 07-31-2009, 11:15 PM
TurboSHO Member
Default
i just did ... went and raised the idle to 1200 and changed the maf calibration to what i calll the jagged maf curve. which keeps it running. seems the sweet spot is between 1v and 1.5v for the idle. i was able to drive it but when i comes to a stop it starts searching for the idle till a come to a complete stop.
plus it runs pig rich. i cant boost it.
  #11
Old 08-01-2009, 11:22 AM
92sho16's Avatar
boosted
Default
Did you start having these problems once you changed the maf? Also how did you wire the maf, with a plug n play adapter or did you cut the harness?
  #12
Old 08-01-2009, 01:22 PM
TurboSHO Member
Default
Quote:
plug and play adapter ... yes once i switched MAF.
Another thing that i knowticed is then when the car starts going rich my water temp starts climbing like crazy!
  #13
Old 08-04-2009, 05:38 PM
ycode90's Avatar
Registered
Default
Sounds like a ground or sensor issue.
  #14
Old 08-05-2009, 09:28 AM
TurboSHO Member
Default
Im going to try Tim's recommendation of going to a draw through instead of blow through. I will have to check on my ground that goes from the engine to firewall.
Question ... when an engine is in boost and you lift off, no matter what the MAF is reading ( being a blow thru or a draw thru setup) it will cut off fuel correct?
  #15
Old 08-05-2009, 11:27 PM
ycode90's Avatar
Registered
Default
Yes .
  #16
Old 08-05-2009, 11:52 PM
somedude_001 somedude_001 is offline
Registered
somedude_001 is a beacon of lightsomedude_001 is a beacon of lightsomedude_001 is a beacon of lightsomedude_001 is a beacon of lightsomedude_001 is a beacon of lightsomedude_001 is a beacon of light
Default
if you have a blow off valve instead of a bypass valve won't your part throttle maf signals be screwy with a draw through setup because you will be venting a lot of unused air that was metered?
__________________
1994 ATX green/mocha Turbo
want to turbo your SHO? click here http://www.shoforum.com/showthread.php?t=80983
Quote:
Originally Posted by Racer X View Post
Can there even be too much win in one thread?
Because if there can, this thread is dangerously close to that threshold.
  #17
Old 08-06-2009, 12:09 AM
TurboSHO Member
Default
i think its the same since you will be letting off the throttle in order for the system to vent or recirculate... the system (ecu) is still going to cut off fuel ... right? Part throttle should be ok.
  #18
Old 08-06-2009, 10:26 AM
Toolman's Avatar
Default
Quote:
The worst problem I have ever had with my vent to atmosphere/draw-through setup is that every great once in a while, when you go from full throttle to part throttle very quickly, there would be a hickup. And that only happened when I first got the car. After I leaned out the ridiculously rich SHOSHOP tune, the car had nary an issue. After the Tweecer, and a much better tune, the car drove near perfect. The absolute best case scenario would be to have a draw-through setup with a recirc valve, or a drop in MAF that is meant to be in heated/pressurized air (the 80 and 90 mm FORD MAF's that we all use are not intended for this).
My belief is that nearly ALL the idle issues that S/C SHO's have can be linked to using a draw-through MAF in a blow-through setup. It is certainly a less ideal setup than a draw through and vent to atmosphere valve.
  #19
Old 08-06-2009, 02:52 PM
Sho Amo's Avatar
SmkTyresntDrugs
Default
whats a good blow through maf?
  #20
Old 08-06-2009, 03:29 PM
Toolman's Avatar
Default
Pmas hpx
  #21
Old 08-06-2009, 03:40 PM
Lupo's Avatar
Lupo Lupo is offline
Registered
Lupo is on the right road
Default
Quote:
Originally Posted by Toolman View Post
Pmas hpx
Which MAF are you currently using for your draw-through?
__________________
94 Green MTX SHO
Aftercooler by Hangar18 fabrication. www.hangar18fabrication.com
94 Blue MTX SHO "Bluey" R.I.P. 9-22-2007
Clutchmasters stage 1 with Quaife and 17lb Billet flywheel
Konis with Intrax springs, ASFBs, and subframe connectors
"Drunk by noon, but that's OK, I'll be president someday.."
  #22
Old 08-06-2009, 08:02 PM
Toolman's Avatar
Default
I have only ever used linc 80mm. I have not decided which route to go on my track car yet, either a 90L or the PMAS HPX.
  #23
Old 08-07-2009, 10:28 AM
Lupo's Avatar
Registered
Default
The Linc 80 is a good MAF, but what do you do when you peg it (which I'm sure you do quite easily!)?
  #24
Old 08-07-2009, 11:25 PM
Toolman's Avatar
Default
Actually, I don't think I ever pegged it. It flowed 400whp with some room to spare. Keep in mind, it takes less airflow for a turbocharged SHO to make the same power as an S/C SHO, and when you use a draw-through MAF in a blow-through design, I have heard you lose as much as 30% of it's metering ability. The only reason I have ever considered a 90L is because I plan making an insane amount of power with this new setup (well north of 550whp), and the only reason I considered blow-through designs is because of the pain of trying to package the huge 90L and it's associated filter within the limited space I have (based on my current turbo placement).
  #25
Old 08-13-2009, 12:51 PM
Lupo's Avatar
Registered
Default
I can't imagine that you would lose any metering ability with a blow-though setup, you would simply be reading the wrong amount of air.
These MAFs read from 0-5v for their signal.
If the same amount of airflow is getting 2 different voltage signals from the same MAF on draw-through versus blow-through, then the ECU is getting the wrong information on one of them.
What you would need to do is use a different MAF curve on blow-through systems which are using MAFs designed for draw-through.
Now figuring out the new proper MAF curve on a blow-though setup would be the hard part.
  #26
Old 08-15-2009, 11:30 AM
TurboSHO Member
Default
I was in town last week and started checking out the SHO to try to figure out how to do the draw through setup, and simply enough, my current setup doesnt allow that big of a MAF to go right before the turbo.
So while looking at the spare parts i have in the garage i saw the old 55mm MAF and decided to throw it on to see if it would make a difference knowing that the MAF curve is already stored on the ECU.
Turned the car on and it idles really good. As i rev'ed it up while parked, it seems like if it was still naturally aspirated... good! Only thing is that when i did that the MAF numbers on calcon shot up to 500 and this maf is only meant for 800 max!
I have 50lb injectors and by what all you guys have been posting for 47lb injectors, i just winged it and put 50/85 for the injector slopes.
Im back in Texas so i couldn't do anything else and i really dont know how the car runs on the street.
  #27
Old 08-17-2009, 03:43 PM
Lupo's Avatar
Registered
Default
Well I bit the bullet and went with a draw-through setup using the lightning 80mm. Car runs pretty good, and idles steady.
Now I have 2 MAFs on my car, the lightning 80mm, and the lightning 90mm. It's just that one of them isn't hooked up right now
I'll need to make some piping to delete the current unplugged 90 in the intake tract , but I'm too lazy right now.
  #28
Old 08-17-2009, 04:06 PM
Toolman's Avatar
Default
Very interesting. Look forward to pics, as everything you do on that SHO is top-notch. Also looking forward to your driving results.
Did you change anything else in the tune, or just swap out the MAF xfer?
  #29
Old 08-17-2009, 06:31 PM
Lupo's Avatar
Registered
Default
I swapped out the MAF transfer to the 80mm Lightning. Take in account that the 80-90mm lightning MAF transfers from Caledit are assumed to be draw-through. So they really wouldn't work 100% correct for a blow-through setup.
SHOShop simply manipulated the WOT fuel multiplier to make up for the inaccuracies of the blow-through, not to mention pegging the MAF signal well before the car stops making power.
While that worked good enough for a dyno run at WOT, it made the drivability in closed loop and partial throttle suffer, and never work 100%.
So far, the car runs great. Rock steady idle, and PT seems a little crisper.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
