SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Engine, Exhaust, Drive Line & AC systems
Reply
Thread Tools
  #1
Old 08-01-2003, 12:45 PM
B Fa SHO B Fa SHO is offline
Registered
B Fa SHO is on the right road
Clicking Gas Pedal??
Anyone ever experience a clicking vibration in the gas pedal when trying to accelerate while in low rpm's (below 2000)? It happens when I try to pull of, unless I rev past 2k and the car will sometimes jerk if I try to pull off fast under 2k rpm's. I really dont think it's the clutch because that was just replaced in January, and it doesn't slip, etc. No matter what gear I'm in, if I'm under 2k rpm and try to accelerate I'll hear a clicking noise coming from whatever is behind the gas pedal, a connector or something in the transmission maybe?? Someone help me out, this is a really annoying problem headbang
__________________
I have never been wrong in my whole life except once...that's when I thought I was wrong but I actually was right.
  #2
Old 08-01-2003, 01:00 PM
SHO#7 SHO#7 is offline
Registered
SHO#7 is spectacular!SHO#7 is spectacular!
I may not quite understand your problem... But when you say clicking, and hard to start out with light acceleration, do you mean that the gas pedal is hard to push? I know that in my 98 that if I do not clean out the throttle body every once and a while, I will get a carbon ring around the intake butterfly, causing it to hang up under a light acceleration. Almost like the pedal fights back, not wanting to move. I may be way off. It's been a while since I have had a Gen1 or 2, so I may be way off. Hope it works out.
__________________
Mike Yeager
Because You asked:
2013 Audi R8 V10
2009 911 Turbo
2011 911 GT3
2013 Cayenne Turbo
2003 Mexi-Beetle
2013 Denali Duramax
2010 Beetle Vert
1998 Taurus SHO
2008 911 Cabriolet
2013 RR Sport SC
www.transmissionrepairshopcincinnati.com
  #3
Old 08-01-2003, 01:15 PM
Registered
No, the gas pedal resistance is the same and not the problem. It's just that when I accelerate, I can actually feel a clicking vibration in the pedal, and I'm not sure if it's something the pedal is connected to that causing this or something further down the line towards the engine causing it. shrug
~BW~
  #4
Old 08-01-2003, 02:25 PM
FOSHO94's Avatar
FOSHO94 FOSHO94 is offline
Chillin
FOSHO94 is on the right road
Sometimes my clutch pedal makes a clicking sound, I think this has something to do with the pedal itself. Prolly the same on your gas pedal.
__________________
Jeff
1995 Green/Grey MTX 88k
-K&N Panel Filter
-Silvania Superstar Headlights
-Tinted 20% Front, 5% Rear
Next Up: Walbro 155 LPH Fuel Pump
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
