SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Maintenance & Troubleshooting
Reply
Thread Tools
  #1
Old 05-11-2012, 06:27 PM
LJRuddy's Avatar
LJRuddy LJRuddy is offline
Pop lock n drop
LJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond reputeLJRuddy has a reputation beyond repute
Thumb Down Delayed and violent 1-2 shift *new problems video uploaded*
Just got the car back from the shop and I have a very delayed and then hard shift into 2nd gear. I remember reading something about a sticking accumulator piston (i think?) causing this issue. FWIW, right before I made it back home after the accident Sunday, the O/D light started to flash. I'm assuming this was due to the lost fluid which caused the remaining to overheat? Tranny has like 20,000 miles on it and had no issues before my accident.
__________________
96 ATX 245k - A.K.A. The Vomit Comet
  #2
Old 05-11-2012, 06:55 PM
93rev2sev's Avatar
93rev2sev 93rev2sev is offline
Registered
93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute93rev2sev has a reputation beyond repute
Default
Make damn sure there's enough fluid in it now. Check while idling hot.
__________________
Potential: Bob can spot it.
Quote:
Originally Posted by Bob Gervais View Post
It's like we all had a premonition that he'd be less stupid some day....:laugh_ti:
23 year old Taurus
  #3
Old 05-11-2012, 07:15 PM
LJRuddy's Avatar
Pop lock n drop
Default
Its plenty full... First thing I did when I came back home today.
FWIW I tossed in a new filter and the fluid is brand new.
  #4
Old 05-11-2012, 09:06 PM
Inkertinker's Avatar
Inkertinker Inkertinker is offline
Inkertinker is a beacon of lightInkertinker is a beacon of lightInkertinker is a beacon of lightInkertinker is a beacon of lightInkertinker is a beacon of lightInkertinker is a beacon of light
Default
I just realize I did not send the side pan, sorry about that, this week has been a blur.
__________________
97 Ebony Satin/Gray -Welded
94 Rare Green/Gray MTX not sold
91 White/Black "Formerly a James Car"
68 Chevy C-20 Orange Crate
in Restoration
  #5
Old 05-11-2012, 09:23 PM
LJRuddy's Avatar
Pop lock n drop
Default
No worries. Thanks anyway!
  #6
Old 05-12-2012, 01:13 AM
Liquid_force's Avatar
Liquid_force Liquid_force is offline
Registered
Liquid_force is on the right road
Default
mine has done that since I bought it at 91.5k
When it's cold the first couple 1-2 shifts are nasty, after that it is very smooth and RARELY happens when it's warmed up.
Ambient temp doesn't seem to make much difference.
I now have 124k+ and the condition has been consistent from day 1.
I've gotten into the habit of running the rpm's up to the shift point, then lifting so it shifts at low rpms to keep it from slamming into 2nd.
  #7
Old 05-12-2012, 12:59 PM
SHOhopefull's Avatar
SHOhopefull SHOhopefull is offline
Registered
SHOhopefull is a name known to allSHOhopefull is a name known to allSHOhopefull is a name known to allSHOhopefull is a name known to allSHOhopefull is a name known to allSHOhopefull is a name known to all
Default
Accident induced shift kit?
__________________
1990 SHO "BREAKDOWN"
Eibachs/Tokico's,Fidanza flywheel,ALSFB's, 96 brakes
1990 SHO...Silver Banshee
96 brakes, rod shifter, DD
2001 SEL "Alice"
Black/Grey Leather Duratec...Wife's ride
I love going to the Pull-a-Part because the dollar admission is cheaper than most car shows and you almost always see cooler cars.(stolen from someone on grassroots motorsports, but so true!)
  #8
Old 05-14-2012, 06:28 PM
LJRuddy's Avatar
Pop lock n drop
Default
New problem developed last night. When the tranny goes to engage a new gear (up or downshifting) it will go into the new gear, slip for a second and then tighten back up. If I go WOT at a speed that will not allow for a gear change, the tranny holds together perfectly. Here's a video on the highway going from 4th to 3rd gear, with a constant 1/2 throttle input. No CEL or OD lights are illuminated.
  #9
Old 05-15-2012, 11:10 AM
stephen newberg stephen newberg is offline
Moderator
stephen newberg will become famous soon enough
Default
Ouch. That looks like bands slipping to me. Assuming these transmissions still have bands. If not, whatever has replaced them slipping instead.
pax, smn
__________________
'98, Black
Cold air intake, K&N panel, SARC switch, 4 gauge instrumentation cluster, Front Strut Brace, ASFB, Eibach springs, 23mm rear sway bar, Yokohama Advan S.4. tires, wired open secondaries, FPS trans cooler, Magnaflow 99000 cats, Flowmaster 40 mufflers, and welded cam sprockets. Complete body restoration in 2010.
New DD: '11 metallic blue Porsche C4S.
  #10
Old 05-15-2012, 05:54 PM
ThatSHO's Avatar
ThatSHO ThatSHO is offline
v8 SHO
ThatSHO is unknown at this point
Default
My trans acted weird after it was rebuilt somewhat similar to what yours seems to be doing but after looking around i saw that the tps connector was not all the way on and after that it did great. thats strange that it would be doing that with the low miles on the rebuild. If i were you i would look around at some sensors to see if the gets you anywhere
__________________
99 SHO
Cams Welded
Magnaflow Y Pipe, Flowmaster 40 Series
Rebuilt Trans
140k
  #11
Old 05-15-2012, 06:05 PM
LJRuddy's Avatar
Pop lock n drop
Default
Whats weird is if I go WOT from a dig and run it balls out, the tranny works flawlessly. 3rd will go into lock up at 75 instead of the usual 85 but that's the only issue.
Got an OD light last night. Gonna pick up my contacts and stop by an Autozone if theres one close and get the codes pulled.
  #12
Old 05-15-2012, 07:20 PM
DrCheeto's Avatar
DrCheeto DrCheeto is offline
Lurking
DrCheeto has a little shameless behavior
Default
That flare seems more like an electrical / sensor issue...
__________________
2012 Fusion SEL
94 MTX
Quote:
Originally Posted by platoribs View Post
I fellate dogs!
  #13
Old 05-16-2012, 05:09 PM
LJRuddy's Avatar
Pop lock n drop
Default
Got codes:
p0411- secondary injection incorrect upstream flow (pump has always been funky. Works but always sets this code)
p0733- gear 3 incorrect ratio
p0734- gear 4 incorrect ratio
p1519- IMRC stuck closed bank 1 (IMRC relay box has been removed and the secondaries are wired open)
ThatSHO: Put my volt meter to the tps and the voltages look good so we can rule that out. All electrical connections are good and tight on the tranny.
  #14
Old 05-17-2012, 04:27 AM
Dubeckyj Dubeckyj is offline
Registered
Dubeckyj is unknown at this point
Default
When my tranny died, I was getting incorrect ratio codes. What happened to me was the valve body would stick somewhere, and cause it to not shift into 3rd, or 4th (or eventually 2nd) so it would think that "4th" gear had the same ratio as 1st. If you are getting all your gears, then that probably isn't the issue.
You didn't happen to change the chain ratio, did you?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
