Register |
FAQ |
#1
Can anyone tell me the correct name and where I can purchase this connector. It goes in the square connector housing of the stereo speaker adapter on head unit side. Thanks!
__________________
95 Red/Gray Leather ATX. Built AX4S, Earls transmission cooler w/aux fan, Gen 3 subframe conversion, Tokicos/ Moog CC's, GEN 3 rear subframe bushings (4), GM rear control arms, H-Brace, 11.6" front brakes, Earl's SS lines w/spring delete, Bias plugs, K&N panel, Dynomax cat back. |
#2
That's a JBL bypass connector.
__________________
1990 SHO A few mods: 3.2 conversion, High flow y-pipe, Quaifed tranny, SHOrt shifter, TPR bushings, H-brace, adjustable rear control arms. It's getting better! Check out how nasty my SHO was when I got it! New interior! Not so nasty now! New and improved! Now with 100% more blue! Want to install a digital cluster in your car? |
#3
Yes... but what is the trade name of the pin the that is crimped onto the white wire (the arrow is pointing to it)? You can't see it in the pic, but it's broken in half and useless. Cheers.
#4
All I can tell you is that the connector that is on the radio that is the same gender is made by AMP.
#5
I've searched all evening and think I came up with something, I hope. The terminal is a GM Micro-Pack Series for 22AWG wire, GM OEM P/N 12040902. It can be found HERE, and it looks like this,
![]() Thanks for your help jelloslug
| Thread Tools | |
If you wish to help keep SHOforum running please click the donation button below
