SHOForum
Go Back   SHOForum > Troubleshooting & Performance Upgrades - V8 (96-99) > V8 - Performance Upgrades
Reply
Thread Tools
  #31
Old 03-23-2012, 11:27 AM
illSHOyou illSHOyou is offline
Registered
illSHOyou is spectacular!illSHOyou is spectacular!illSHOyou is spectacular!
Default
Hey Paul, Couple of questions...
I really believe that my transfer function maybe off. Right now I am flowing 23.5 lb/min air at 6100 rpm. The STFT are commanding .86/(12.59:1) AFR.
Car starts at .82 around 2000 rpm and steadily moves up to .86 at 4000 rpm.
STFT .86 is commanded from 4000 rpm on....
23.5 lb/min air should be at least 235 hp at the crank. The car has some pretty good mods at this point and dynoed 219 corrected whp on a mustang dyno at school w/ stock tune. Car currently has a xcal3 with unknown tune.
I know fans come on at 206 degree/commands a leaner WOT than stock/IMRC open 2,200 rpm/trans TCC mods/More drawn out shifts.
As far as timing goes it easily presues low to mid 30's degree when the engine is around 190 degree F from 4000 rpm on. At redline I have recorded 40 degree advance on a couple of data logs untill the car gets into the 200 degree and starts pulling timing.
Too me, the transfer function has to be off. That 23.5 lb/min seems fit for a stock 235hp v8 SHO.
  #32
Old 03-23-2012, 11:34 AM
SHOZ123's Avatar
SHOZ123 SHOZ123 is offline
Registered
SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!SHOZ123 is brilliant!
Default
Do you have an A/F gage? Also tune the A/F in 1st gear only. There are A/F modifiers for 2nd and 3rd gear.
__________________
Paul Nimz
2010 Genesis Coupe 2.0L track
Quote:
We have an Insolvent nation
We have Insolvent banks
And then we have the Insolvent nation bailing out the Insolvent banks
  #33
Old 03-23-2012, 01:04 PM
Registered
Default
Quote:
Not yet, Thats next on the list of things to get...
I do have the data logs. I will try to either post or email them to you.
Can I attach them to the forum somehow?
  #34
Old 03-23-2012, 01:08 PM
SHOZ123's Avatar
Registered
Default
Without an A/F gage then just going by the commanded values is not realistic. No way should you be trying to modify the MAF curve without one.
  #35
Old 03-23-2012, 03:42 PM
Registered
Default
I don't yet have the capabilities to mod the pcm. Just trying to interpret the data and gain a understanding of what this tune I have acquired is doing. I have reverted back to stock again and while the bottom end is lacking it has more pulling force above 4000 rpm. I would imagine the PCM should be calling for the stock WOT enrichment of .75 and probably is enough fuel for safety if the transfer function is off.
I like the trans mods on the tune but I rather not risk running the engine lean at this time until I get a wide band and make sure the transfer function is correct.
  #36
Old 03-26-2012, 07:33 PM
Dubeckyj Dubeckyj is offline
Registered
Dubeckyj is unknown at this point
Default
What's the function for changes in the Closed Loop Bias table? I can increase/decrease by 0.0150, which if lambda, barely changes the AFR. Is the leanest I can go really 14.9 in closed loop?
  #37
Old 03-26-2012, 08:21 PM
SHOZ123's Avatar
Registered
Default
I wouldn't mess with it. Never did me anything.
  #38
Old 04-02-2012, 06:46 PM
Registered
Default
Hey Paul, I came across this thread the other day and I was wondering if you still had the MPH-to-shift values for this: Ford's Cruel Irony
Also, are some spikes normal in data logging, or do I have a noise issue I need to address?
  #39
Old 04-02-2012, 08:18 PM
SHOZ123's Avatar
Registered
Default
You can't go by the actual value that you put into the table. You just have to pick a number then see if it shifts at the rpm you want it to. If it's too low then raise the mph. I can't remember what the actual numbers were. I ran smaller tires anyway at 225/50/16s.
  #40
Old 05-14-2012, 06:46 AM
Registered
Default
Hey Paul, what exactly did you do to tune for secondaries removal? Do you remember if you felt a noticeable difference afterward (the tuning, not the removal). I've had mine out for ever, and while 2k+ is fantastic, light cruise at 1500 seems lacking. If I hit a slight uphill, I have to give it significantly more gas than I think I should & sometimes it'll downshift.
Also battling random misfire; need to change coil packs. But still.
  #41
Old 05-14-2012, 07:58 AM
SHOZ123's Avatar
Registered
Default
The only thing I did was for the cold start and warm up for the secondary removal.
It sounds like you need to increase the Intake Manifold volume as far as the 1500 rpm issue.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2012, SHOForum.com
This forum is not affiliated with Ford Motor Company
