SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Suspension, Brake Systems, & Body
Reply
Thread Tools
  #1
Old 04-10-2010, 06:07 PM
oboytroyman's Avatar
oboytroyman oboytroyman is offline
Troy
oboytroyman is unknown at this point
Default replaced tie rods;but car still shakes going 65+mph
I replaced the two front outer tie rods and aligned my sho but the car still shakes pretty bad going 65+mph. Also aligned the car, the only problems I can think of are.
1. When I aligned the car the front right camber was off by a bit and I didn't have a good enough drill bit to fix the camber.
2. While going down the road the steering wheel has maybe an inch of play before actually turning the wheels. I read something about tightening a nut under the steering column and I think i'm going to try that to see if it's loose. Another thing about the steering is that soemtimes it feels like when i turn left it's nice and tight, but when i turn right it doesn't feel as tight and feels like something is wrong with the steering.
any ideas on what's going on with my front end? I'm getting my tires balanced on monday also..maybe they're just not balanced good?
  #2
Old 04-10-2010, 06:32 PM
SHOspazz92's Avatar
SHOspazz92 SHOspazz92 is offline
Banned
SHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond reputeSHOspazz92 has a reputation beyond repute
Default
Rotate an Balance your Tires.
Check your wheel bearings as well.
-Sam
__________________
92 3.0 MTX - Autocross prepared - 13.1@107
2013 BRZ Limited - Daily Driver
02 SVT Focus - Her Daily Driver / Auto-X toy
07 Cherokee SRT-8 - Hauls the mail
Spending money I don't have, to buy parts I don't need, to impress people I don't know since July of 2002! Welcome to SHOforum.
  #3
Old 04-10-2010, 06:48 PM
Troy
Default
wheel bearings were good by the way.
  #4
Old 04-10-2010, 07:20 PM
zach44102's Avatar
zach44102 zach44102 is offline
ALL MOTER
zach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud ofzach44102 has much to be proud of
Default
did you balance your tires from the inside or the outside? checkthe weights to see if they are missing or re-balance
__________________
1995 Moonlight blue MTX- 13:1 3.3L, 2690lbs Quickest ALL MOTOR SHO 13.5 @ 106mph (stock internals)
2002 Taurus SES, V8/MTX
www.SHONUTPerformance.com
  #5
Old 04-10-2010, 07:40 PM
dward dward is offline
Registered
dward is unknown at this point
Default
make sure they take a good look at the wheels themselves while balancing. A slightly bent wheel can cause unwanted vibration. Put the worst to the back ie most weight bent wheel.
  #6
Old 04-10-2010, 10:21 PM
Shoman594's Avatar
Shoman594 Shoman594 is offline
Moderator
Shoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to allShoman594 is a name known to all
Default
A bad tire will also cause this. The older they are the better chance its them.
__________________
Ryan
Founder - BringbacktheSHO.com
Chicago SHO Club - SHOCAGO.com
1989 Light Titanium 40k Miles (Cabin Fever)
1989 Orange & Red with a little green #32 (Raphael)
1996 Charcoal Grey 1st 5-Speed Conversion (SOLD)
  #7
Old 04-11-2010, 11:19 AM
Troy
Default front end
Well the tires are about 7 years old and the 2 back tires are pretty much worn out. The front 2 are actually decent, I'll change all of them maybe mid summer. I'll go to discount tire and have them balance and check the wheels out.
  #8
Old 04-11-2010, 01:21 PM
shospeed143's Avatar
shospeed143 shospeed143 is offline
Registered
shospeed143 is on the right road
Default
When I first got my SHO I had play in the steering wheel and later found out that the sub frame bushings where bad. It will not cause the front end to shake bud it will cause the play. To check them open the hood and turn the wheel wile you do watch the intake and see if it moves back a forth, If it does then you need new sub frame bushings.
  #9
Old 04-11-2010, 05:13 PM
Troy
Default front end
would you say any movement by the intake would be bad and i would need to fix the subframe bushings?
  #10
Old 04-11-2010, 08:05 PM
94SHO_Norfolk 94SHO_Norfolk is offline
Registered
94SHO_Norfolk is on the right road
Default
Based on what you've already done, my vote is wheel balance and tire balance. I had a Jeep Cherokee that wobbled something fierce between 55-60, and putting on new tires and balancing them cured it. 'Course I also had new Bilstein shocks installed along with a new steering stabilizer, but from what a lot of other Cherokee owners have said, making sure the rims and tires are balanced is the trick.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
