SHOForum
Go Back   SHOForum > Performance Upgrades - Gen 1 (89-91) & Gen 2 (92-95) > Tuning ~ Supercharger ~ Turbo ~ Nitrous Upgrades
Reply
Thread Tools
  #31
Old 03-01-2010, 08:35 PM
SuperchargedSHOguy's Avatar
SuperchargedSHOguy SuperchargedSHOguy is offline
Got 1000 hp?!?
SuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud ofSuperchargedSHOguy has much to be proud of
Default
Keep an eye on spacecoastspeedshop.com. Been busy with opening up and getting the website going and all. Once things smooth out I'll have time to post pics and all and have prices. Cheaper than a typical wiesco build and we have solved the rod bearing issue associated with these engines.
__________________
Outlaw SHOforum member
1994 Taurus SHO 3.2 T5 The FIRST EVER functional RWD conversion in a SHO- DEAD
1996 Dodge Viper GTS
1992 GMC Typhoon
1986.5 Toyota Supra
  #32
Old 03-01-2010, 09:16 PM
yamahaSHO yamahaSHO is offline
Perma-BAN
yamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond reputeyamahaSHO has a reputation beyond repute
Default
I'm curious now...
__________________
1995 SHO - 14.4 @ 110 (1/4)
2005 STi - 8.4 @ 82 (1/8)
Launching > ME
  #33
Old 03-02-2010, 05:47 PM
somedude_001 somedude_001 is offline
Registered
somedude_001 is awesome!somedude_001 is awesome!somedude_001 is awesome!somedude_001 is awesome!
Default
Quote:
Originally Posted by yamahaSHO View Post
I'm curious now...
i was thinking that too. what a cliff hanger. I am a week or so away from buying pistons and he says that. sheeesh
__________________
1994 ATX green/mocha Turbo
want to turbo your SHO? click here http://www.shoforum.com/showthread.php?t=80983
Quote:
Originally Posted by Racer X View Post
Can there even be too much win in one thread?
Because if there can, this thread is dangerously close to that threshold.
  #34
Old 03-03-2010, 09:14 AM
shomethe$$$'s Avatar
shomethe$$$ shomethe$$$ is offline
Registered
shomethe$$$ will become famous soon enough
Default
So basically I have to put like 80 pounders to replace my 48's if I want to run E85?
  #35
Old 03-03-2010, 10:30 AM
Perma-BAN
Default
(48*.3) + 48 = 62.4
  #36
Old 03-03-2010, 06:15 PM
Registered
Default
I was looking at 120lb for my camaro build. Think that is too big? a separate feed for each fuel rail to a common regulator. Start with 1 255lph pump with the possibility of adding a second later on.
  #37
Old 03-09-2010, 11:50 AM
Devon Devon is offline
Registered
Devon is on the right road
Default 16:1 compression E85?
why not 16:1 compression E85?
I have read a lot about E85 and don't mind running it in my car. check this out, this might give you an Idea what you can get away with on E85!
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
  #38
Old 03-09-2010, 05:04 PM
92sho16's Avatar
92sho16 92sho16 is offline
boosted
92sho16 will become famous soon enough92sho16 will become famous soon enough
Default
Browsed through the pages there dont see where it says hes going to put boost on it, thats why he can run such a high cr.
__________________
-Rob's SHO-
Gen3 subframe swap,Turbonetics 62-1 turbo, Toolman Hot pipes,Stainless 3" exhaust, urethane MM's, AL SFB's, Long SFC's, Intrax Spring, Tokico Struts, Cobra R brakes, TD PR1.2 17x8 wrapped in 245/45 sumitomos, and TD PR1.2 17x9, 275/40 Hoosier R6
  #39
Old 03-10-2010, 10:06 AM
sho_sc's Avatar
sho_sc sho_sc is offline
Registered
sho_sc is a jewel in the roughsho_sc is a jewel in the roughsho_sc is a jewel in the rough
Default
Don't read too much into static compression ratios , cams have a lot to do with what you can get away with. In the motorcycle world, we commonly have 13:1 compression ratios and run 89 octane.
__________________
"I've been kicked off of the east coast Land Speed Racing tracks for going too fast and now I don't have the $$$ to bring the SHO up to 200 mph tech status."
  #40
Old 03-10-2010, 11:47 AM
Registered
Default
some one in there made the comment of putting a blower on top of 13:1 static compression ratio.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright ©2000 - 2009, SHOForum.com
This forum is not affiliated with Ford Motor Company
