Register |
FAQ |
#1
__________________
3.2L headgaskets in stock! Doug Lewis shoguy89@aol.com Ford Performance Specialists Inc. Atlanta Georgia 770-949-7191 http://www.fordspecialists.com 2001 F-250 Powerstroke- Garrett turbo - 700ft-lbs 1996 TR SHO- Long tubes - bottle fed - low and fast 1989 CR SHO- Shaftdrive supercharger - 400hp Not Racist, Not Violent, Just no Longer Silent. |
#2
I'm doing one right now.
__________________
1990 White/Mocha - 500whp capable 1991 White/Black - DD 2002 SES Sport - First V8 swap in a Gen 4, now moar MTX and Remote Turbo goodness. Quote:
Quote:
#3
Does the install come with a wavetracked 3.2MTX swap?
__________________
engine |
#4
If you want it too... Anything is possible given enough time and money. |
#5
Yeah.. on a gen3? I don't think the tranny would last long.
Be pretty sweet though.
__________________
~Nick 1997 Graphite Black :: Non-welded :: R.I.P. (Rolled) 1997 Tearador Red :: Welded :: Work In Progress :: Nimz Tune :: http://www.cardomain.com/ride/3095900 Quote:
#6
It wouldn't last long on any old ATX SHO. But then you go back to FPS and get a beefed up one... or you get it at the same time. Good business sense. Also the cost to play.
__________________
1997 SHO-catless and clueless |
#7
I don't think the shift kit will help. I mean.. you would have to beef up all the planetary disk's and the braking plates along with it for it to last longer... I mean.. think about it.. ~400 ft/pounds.. that's essentially 100% increase in torque.
#8
I think Doug uses a little valve body voodoo and other tricks but yes ~400 ft/lbs is alot. It may be less bad if the power comes on later in the power band vs from a start. Surely true for MTX, probably true for ATX.
#9
You make a good point. I guess it's just a matter of waiting until someone does it and see how it does.
#10
Fixed
#11
lol.. well that's what I was alluding too.
#12
Quote:
__________________
1997 red/mocha 102k drives like new...STOCK 1997 Black 162Kmiles 95K on motor welded,Jet performance Chip,flowmaster,Third Cat Delete,ASFBs,reinforced transmision,lowered in front with stock setup.... 1995 Red/Mocha 3.2 Mtx,magnaflows, ASFBs, solid motor mounts, H-Brace, New Ford clutch, cold air intake,no cats,KYBs,....more to come |
#13
i don't know how much first hand exp you have with the ATX and their ability to hold power, but if you don't get stupid with boost they will hold 6-8psi just fine as long as you don't over heat them. I can't comment on the V8 engine because I have no first hand exp with them.
And yes 6-8 psi is a lot of fun to kick around with.
__________________
1994 ATX green/mocha Turbo want to turbo your SHO? click here http://www.shoforum.com/showthread.php?t=80983 |
#14
Quote:
I'd expect a later boost onset - like a turbo or centrifugal supercharger - to be more gentle on the trans, but not to the point where I'd expect it to survive for much longer. Especially on a well worn trans. TQ converter doesn't stand much of a chance either.
__________________
Eric Lehmann 97 Ebony Satin 42k - Welded - With the Angels now so I don't have to be - Long live the Garage Queen 97 Toreador Red 74k - Resurrected, Welded 97 Ebony Satin 185k - Resurrected, Welded, experiment successful 96 Charcoal Grey - 145k - resurrected, Welded 96 Rosemist - 2006 Best of SHOw Popular Vote, 2007 Best Gen III - 73k - Welded 96 Medium Willow Green - 122k - resurrected, Welded - Eaton M90 Supercharged - Bad bad man! |
#15
Quote:
#16
mazda 6 tranny? with work done from the people at the mazda forums?
#17
Quote:
#18
doug from FPS (SHO Dude) told me to not run more than 8psi if I wanted a reliable fun setup. 4 transmissions and 40K (miles) later I realize that I should have listened. from what I have learned our transmissions are just not up to taking a huge amount of power. 8psi is a blast to drive. it is not 400tq but it will keep a smile on your face and that little turbo would probably do well through the top end too at the lower boost.
| Thread Tools | |
If you wish to help keep SHOforum running please click the donation button below
